boot problem Topic is solved
hm123
Re: boot problem
Post by hm123 »
Yes
Still missing
Re: boot problem
ok lt's clone the directory fro GitHub
apt install git
git clone https://github.com/MichaIng/DietPi.git /tmp/dietpi
rm -r /boot/dietpi/
cp -r /tmp/dietpi/dietpi /boot/
apt purge git
reboot
After reboot, you will be ask to perform first setup again.
hm123
Re: boot problem
Post by hm123 »
everything OK
thank you
Re: boot problem
ok good, at least this has been fixed. But no guarantee that all files are ok now. Because you had such a huge amount (more than 3100) of corrupted FSCK* files. ;)
