Unable to force sound to headphone jack RPI 4
gofireworks
Re: Unable to force sound to headphone jack RPI 4
Post by gofireworks »
I switched to root user with sudo su, and then entered the following commands
G_CONFIG_INJECT 'hdmi_drive:0=' 'hdmi_drive:0=1' /boot/config.txt
G_CONFIG_INJECT 'hdmi_drive:1=' 'hdmi_drive:1=1' /boot/config.txt
reboot
cat /proc/asound/cards
I had to switch the backticks on hdmi_drive:0=1 to single quotes because I was getting an error of bash: hdmi_drive:0=1: command not found.
The output of cat /proc/asound/cards doesn't seem to have changed, but the output is here
root@Kodi:/home/joshl# cat /proc/asound/cards
 0 [b1             ]: bcm2835_hdmi - bcm2835 HDMI 1
                      bcm2835 HDMI 1
 1 [Headphones     ]: bcm2835_headphonbcm2835 Headphones - bcm2835 Headphones
                      bcm2835 Headphones
