Internal Server Error on NextCloud after updating DietPi Topic is solved
Re: Internal Server Error on NextCloud after updating DietPi
First let's fix your issue before removing any folder
mk33
Post by mk33 »
sudo journalctl -u mariadb
-- Logs begin at Tue 2020-07-14 21:11:03 BST, end at Tue 2020-07-14 21:30:38 BST. --
Jul 14 21:11:50 DietPi systemd[1]: Starting MariaDB 10.3.22 database server...
Jul 14 21:11:51 DietPi mysqld[670]: 2020-07-14 21:11:51 0 [Note] /usr/sbin/mysqld (mysqld 10.3.22-MariaDB-0+deb10u1) starting as p
rocess 670 ...
Jul 14 21:11:54 DietPi systemd[1]: mariadb.service: Main process exited, code=exited, status=1/FAILURE
Jul 14 21:11:54 DietPi systemd[1]: mariadb.service: Failed with result 'exit-code'.
Jul 14 21:11:54 DietPi systemd[1]: Failed to start MariaDB 10.3.22 database server.
cat /var/log/mysql/error.log outputs nothing, it's empty...
yeah the file was truncated.
pls restart maria db and check the error.log afterwards
systemctl restart mariadb.service
mk33
Post by mk33 »
$ systemctl restart mariadb.service
Job for mariadb.service failed because the control process exited with error code.
See "systemctl status mariadb.service" and "journalctl -xe" for details.
$ cat /var/log/mysql/error.log
2020-07-14 23:37:55 0 [Note] InnoDB: Using Linux native AIO
2020-07-14 23:37:55 0 [Note] InnoDB: Mutexes and rw_locks use GCC atomic builtins
2020-07-14 23:37:55 0 [Note] InnoDB: Uses event mutexes
2020-07-14 23:37:55 0 [Note] InnoDB: Compressed tables use zlib 1.2.11
2020-07-14 23:37:55 0 [Note] InnoDB: Number of pools: 1
2020-07-14 23:37:55 0 [Note] InnoDB: Using generic crc32 instructions
2020-07-14 23:37:55 0 [Note] InnoDB: Initializing buffer pool, total size = 128M, instances = 1, chunk size = 128M
2020-07-14 23:37:55 0 [Note] InnoDB: Completed initialization of buffer pool
2020-07-14 23:37:55 0 [Note] InnoDB: If the mysqld execution user is authorized, page cleaner thread priority can be changed. See the man page of setpriority().
2020-07-14 23:37:55 0 [Note] InnoDB: 128 out of 128 rollback segments are active.
2020-07-14 23:37:55 0 [Note] InnoDB: Creating shared tablespace for temporary tables
2020-07-14 23:37:55 0 [Note] InnoDB: Setting file './ibtmp1' size to 12 MB. Physically writing the file full; Please wait ...
2020-07-14 23:37:55 0 [Note] InnoDB: File './ibtmp1' size is now 12 MB.
2020-07-14 23:37:55 0 [Note] InnoDB: 10.3.22 started; log sequence number 46552664; transaction id 115418
2020-07-14 23:37:55 0 [Note] InnoDB: Loading buffer pool(s) from /mnt/dietpi_userdata/mysql/ib_buffer_pool
2020-07-14 23:37:55 0 [Note] Plugin 'FEEDBACK' is disabled.
2020-07-14 23:37:55 0 [Note] Recovering after a crash using tc.log
2020-07-14 23:37:55 0 [ERROR] Bad magic header in tc log
2020-07-14 23:37:55 0 [ERROR] Crash recovery failed. Either correct the problem (if it's, for example, out of memory error) and restart, or delete tc log and start mysqld with --tc-heuristic-recover={commit|rollback}
2020-07-14 23:37:55 0 [ERROR] Can't init tc log
2020-07-14 23:37:55 0 [ERROR] Aborting
2020-07-14 23:39:24 0 [Note] InnoDB: Using Linux native AIO
2020-07-14 23:39:24 0 [Note] InnoDB: Mutexes and rw_locks use GCC atomic builtins
2020-07-14 23:39:24 0 [Note] InnoDB: Uses event mutexes
2020-07-14 23:39:24 0 [Note] InnoDB: Compressed tables use zlib 1.2.11
2020-07-14 23:39:24 0 [Note] InnoDB: Number of pools: 1
2020-07-14 23:39:24 0 [Note] InnoDB: Using generic crc32 instructions
2020-07-14 23:39:24 0 [Note] InnoDB: Initializing buffer pool, total size = 128M, instances = 1, chunk size = 128M
2020-07-14 23:39:24 0 [Note] InnoDB: Completed initialization of buffer pool
2020-07-14 23:39:24 0 [Note] InnoDB: If the mysqld execution user is authorized, page cleaner thread priority can be changed. See the man page of setpriority().
2020-07-14 23:39:24 0 [Note] InnoDB: 128 out of 128 rollback segments are active.
2020-07-14 23:39:24 0 [Note] InnoDB: Creating shared tablespace for temporary tables
2020-07-14 23:39:24 0 [Note] InnoDB: Setting file './ibtmp1' size to 12 MB. Physically writing the file full; Please wait ...
2020-07-14 23:39:24 0 [Note] InnoDB: File './ibtmp1' size is now 12 MB.
2020-07-14 23:39:24 0 [Note] InnoDB: Waiting for purge to start
2020-07-14 23:39:24 0 [Note] InnoDB: 10.3.22 started; log sequence number 46552673; transaction id 115418
2020-07-14 23:39:24 0 [Note] InnoDB: Loading buffer pool(s) from /mnt/dietpi_userdata/mysql/ib_buffer_pool
2020-07-14 23:39:24 0 [Note] Plugin 'FEEDBACK' is disabled.
2020-07-14 23:39:24 0 [Note] Recovering after a crash using tc.log
2020-07-14 23:39:24 0 [ERROR] Bad magic header in tc log
2020-07-14 23:39:24 0 [ERROR] Crash recovery failed. Either correct the problem (if it's, for example, out of memory error) and restart, or delete tc log and start mysqld with --tc-heuristic-recover={commit|rollback}
2020-07-14 23:39:24 0 [ERROR] Can't init tc log
2020-07-14 23:39:24 0 [ERROR] Aborting
root@DietPi:/home/dt# systemctl status mariadb.service
● mariadb.service - MariaDB 10.3.22 database server
   Loaded: loaded (/lib/systemd/system/mariadb.service; disabled; vendor preset: enabled)
   Active: failed (Result: exit-code) since Tue 2020-07-14 23:39:27 BST; 33s ago
     Docs: man:mysqld(8)
           https://mariadb.com/kb/en/library/systemd/
  Process: 892 ExecStartPre=/usr/bin/install -m 755 -o mysql -g root -d /var/run/mysqld (code=exited, status=0/SUCCESS)
  Process: 893 ExecStartPre=/bin/sh -c systemctl unset-environment _WSREP_START_POSITION (code=exited, status=0/SUCCESS)
  Process: 895 ExecStartPre=/bin/sh -c [ ! -e /usr/bin/galera_recovery ] && VAR= ||   VAR=`/usr/bin/galera_recovery`; [ $? -eq 0 ]
   && systemctl set-environment _WSREP_START_POSITION=$VAR || exit 1 (code=exited, status=0/SUCCESS)
  Process: 952 ExecStart=/usr/sbin/mysqld $MYSQLD_OPTS $_WSREP_NEW_CLUSTER $_WSREP_START_POSITION (code=exited, status=1/F
AILURE)
 Main PID: 952 (code=exited, status=1/FAILURE)
   Status: "MariaDB server is down"
Jul 14 23:39:24 DietPi systemd[1]: Starting MariaDB 10.3.22 database server...
Jul 14 23:39:24 DietPi mysqld[952]: 2020-07-14 23:39:24 0 [Note] /usr/sbin/mysqld (mysqld 10.3.22-MariaDB-0+deb10u1) starting as p
rocess 952 ...
Jul 14 23:39:27 DietPi systemd[1]: mariadb.service: Main process exited, code=exited, status=1/FAILURE
Jul 14 23:39:27 DietPi systemd[1]: mariadb.service: Failed with result 'exit-code'.
Jul 14 23:39:27 DietPi systemd[1]: Failed to start MariaDB 10.3.22 database server.
pls do
mv /mnt/dietpi_userdata/mysql/tc.log /mnt/dietpi_userdata/mysql/tc.save
mk33
Post by mk33 »
How did you know that you needed to do that mv? There was nothing in logs about that file "tc.save" ...
DB server is running now. I can access NC, everything looks fine.
# systemctl restart mariadb.service
# cat /var/log/mysql/error.log
2020-07-15  9:08:54 0 [Note] InnoDB: Using Linux native AIO
2020-07-15  9:08:54 0 [Note] InnoDB: Mutexes and rw_locks use GCC atomic builtins
2020-07-15  9:08:54 0 [Note] InnoDB: Uses event mutexes
2020-07-15  9:08:54 0 [Note] InnoDB: Compressed tables use zlib 1.2.11
2020-07-15  9:08:54 0 [Note] InnoDB: Number of pools: 1
2020-07-15  9:08:54 0 [Note] InnoDB: Using generic crc32 instructions
2020-07-15  9:08:54 0 [Note] InnoDB: Initializing buffer pool, total size = 128M, instances = 1, chunk size = 128M
2020-07-15  9:08:54 0 [Note] InnoDB: Completed initialization of buffer pool
2020-07-15  9:08:54 0 [Note] InnoDB: If the mysqld execution user is authorized, page cleaner thread priority can be changed. See the man page of setpriority().
2020-07-15  9:08:54 0 [Note] InnoDB: 128 out of 128 rollback segments are active.
2020-07-15  9:08:54 0 [Note] InnoDB: Creating shared tablespace for temporary tables
2020-07-15  9:08:54 0 [Note] InnoDB: Setting file './ibtmp1' size to 12 MB. Physically writing the file full; Please wait ...
2020-07-15  9:08:54 0 [Note] InnoDB: File './ibtmp1' size is now 12 MB.
2020-07-15  9:08:54 0 [Note] InnoDB: 10.3.22 started; log sequence number 46552682; transaction id 115418
2020-07-15  9:08:54 0 [Note] InnoDB: Loading buffer pool(s) from /mnt/dietpi_userdata/mysql/ib_buffer_pool
2020-07-15  9:08:54 0 [Note] Plugin 'FEEDBACK' is disabled.
2020-07-15  9:08:54 0 [Note] Recovering after a crash using tc.log
2020-07-15  9:08:54 0 [ERROR] Bad magic header in tc log
2020-07-15  9:08:54 0 [ERROR] Crash recovery failed. Either correct the problem (if it's, for example, out of memory error) and restart, or delete tc log and start mysqld with --tc-heuristic-recover={commit|rollback}
2020-07-15  9:08:54 0 [ERROR] Can't init tc log
2020-07-15  9:08:54 0 [ERROR] Aborting
2020-07-15  9:11:21 0 [Note] InnoDB: Using Linux native AIO
2020-07-15  9:11:21 0 [Note] InnoDB: Mutexes and rw_locks use GCC atomic builtins
2020-07-15  9:11:21 0 [Note] InnoDB: Uses event mutexes
2020-07-15  9:11:21 0 [Note] InnoDB: Compressed tables use zlib 1.2.11
2020-07-15  9:11:21 0 [Note] InnoDB: Number of pools: 1
2020-07-15  9:11:21 0 [Note] InnoDB: Using generic crc32 instructions
2020-07-15  9:11:21 0 [Note] InnoDB: Initializing buffer pool, total size = 128M, instances = 1, chunk size = 128M
2020-07-15  9:11:21 0 [Note] InnoDB: Completed initialization of buffer pool
2020-07-15  9:11:21 0 [Note] InnoDB: If the mysqld execution user is authorized, page cleaner thread priority can be changed. See the man page of setpriority().
2020-07-15  9:11:21 0 [Note] InnoDB: 128 out of 128 rollback segments are active.
2020-07-15  9:11:21 0 [Note] InnoDB: Creating shared tablespace for temporary tables
2020-07-15  9:11:21 0 [Note] InnoDB: Setting file './ibtmp1' size to 12 MB. Physically writing the file full; Please wait ...
2020-07-15  9:11:21 0 [Note] InnoDB: File './ibtmp1' size is now 12 MB.
2020-07-15  9:11:21 0 [Note] InnoDB: Waiting for purge to start
2020-07-15  9:11:21 0 [Note] InnoDB: 10.3.22 started; log sequence number 46552691; transaction id 115418
2020-07-15  9:11:21 0 [Note] InnoDB: Loading buffer pool(s) from /mnt/dietpi_userdata/mysql/ib_buffer_pool
2020-07-15  9:11:21 0 [Note] Plugin 'FEEDBACK' is disabled.
2020-07-15  9:11:21 0 [Note] Server socket created on IP: '127.0.0.1'.
2020-07-15  9:11:21 0 [Note] Reading of all Master_info entries succeeded
2020-07-15  9:11:21 0 [Note] Added new Master_info '' to hash table
2020-07-15  9:11:21 0 [Note] /usr/sbin/mysqld: ready for connections.
Version: '10.3.22-MariaDB-0+deb10u1'  socket: '/run/mysqld/mysqld.sock'  port: 3306  Raspbian 10
2020-07-15  9:11:21 0 [Note] InnoDB: Buffer pool(s) load completed at 200715  9:11:21
 DietPi-Services
 Mode: status
[  OK  ] DietPi-Services | redis-server         active (running) since Wed 2020-07-15 09:08:53 BST; 8min ago
[  OK  ] DietPi-Services | mariadb              active (running) since Wed 2020-07-15 09:11:21 BST; 5min ago
[  OK  ] DietPi-Services | php7.3-fpm           active (running) since Wed 2020-07-15 09:08:57 BST; 8min ago
[  OK  ] DietPi-Services | lighttpd             active (running) since Wed 2020-07-15 09:08:58 BST; 8min ago
[  OK  ] DietPi-Services | cron                 active (running) since Wed 2020-07-15 09:08:58 BST; 8min ago
[  OK  ] DietPi-Services | dropbear             active (running) since Wed 2020-07-15 09:08:52 BST; 8min ago
[  OK  ] DietPi-Services | dietpi-ramlog        active (exited) since Wed 2020-07-15 00:23:15 BST; 8h ago
[  OK  ] DietPi-Services | dietpi-preboot       active (exited) since Wed 2020-07-15 00:23:15 BST; 8h ago
[  OK  ] DietPi-Services | dietpi-boot          active (exited) since Wed 2020-07-15 09:08:52 BST; 8min ago
[  OK  ] DietPi-Services | dietpi-postboot      active (exited) since Wed 2020-07-15 09:08:52 BST; 8min ago
[ INFO ] DietPi-Services | dietpi-wifi-monitor  inactive (dead)
well the error was described within your error.log
It's stating that the tc.log is corrupted. And we simply moved tc.log to tc.save. It could have been removed as well ;)
mk33
Post by mk33 »
Closing this topic.
Many thanks for helping me make things working again Joulinar :)
