sudo cat /var/log/mysql/error.log
2020-07-14 13:33:14 0 [Note] InnoDB: Using Linux native AIO
2020-07-14 13:33:14 0 [Note] InnoDB: Mutexes and rw_locks use GCC atomic builtins
2020-07-14 13:33:14 0 [Note] InnoDB: Uses event mutexes
2020-07-14 13:33:14 0 [Note] InnoDB: Compressed tables use zlib 1.2.11
2020-07-14 13:33:14 0 [Note] InnoDB: Number of pools: 1
2020-07-14 13:33:14 0 [Note] InnoDB: Using generic crc32 instructions
2020-07-14 13:33:14 0 [Note] InnoDB: Initializing buffer pool, total size = 128M, instances = 1, chunk size = 128M
2020-07-14 13:33:14 0 [Note] InnoDB: Completed initialization of buffer pool
2020-07-14 13:33:14 0 [Note] InnoDB: If the mysqld execution user is authorized, page cleaner thread priority can be changed. See the man page of setpriority().
2020-07-14 13:33:14 0 [ERROR] InnoDB: Operating system error number 13 in a file operation.
2020-07-14 13:33:14 0 [ERROR] InnoDB: The error means mysqld does not have the access rights to the directory.
2020-07-14 13:33:14 0 [ERROR] InnoDB: Cannot open datafile for read-only: './mysql/gtid_slave_pos.ibd' OS error: 81
..... (more lines with the same access rights errors for other directories)
2020-07-14 13:33:14 0 [ERROR] InnoDB: Cannot open datafile for read-only: './nextcloud/oc_webauthn.ibd' OS error: 81
2020-07-14 13:33:14 0 [ERROR] InnoDB: Could not find a valid tablespace file for ``nextcloud`.`oc_webauthn``. Please refer to https://mariadb.com/kb/en/innodb-data-dictionary-troubleshooting/ for how to resolve the issue.
2020-07-14 13:33:14 0 [Warning] InnoDB: Ignoring tablespace for `nextcloud`.`oc_webauthn` because it could not be opened.
2020-07-14 13:33:14 0 [ERROR] InnoDB: Cannot open datafile for read-only: './nextcloud/oc_whats_new.ibd' OS error: 81
2020-07-14 13:33:14 0 [ERROR] InnoDB: Could not find a valid tablespace file for ``nextcloud`.`oc_whats_new``. Please refer to https://mariadb.com/kb/en/innodb-data-dictionary-troubleshooting/ for how to resolve the issue.
2020-07-14 13:33:14 0 [Warning] InnoDB: Ignoring tablespace for `nextcloud`.`oc_whats_new` because it could not be opened.
2020-07-14 13:33:14 0 [Note] InnoDB: 128 out of 128 rollback segments are active.
2020-07-14 13:33:14 0 [Note] InnoDB: Creating shared tablespace for temporary tables
2020-07-14 13:33:14 0 [Note] InnoDB: 10.3.22 started; log sequence number 46552637; transaction id 115418
2020-07-14 13:33:14 0 [Note] InnoDB: Loading buffer pool(s) from /mnt/dietpi_userdata/mysql/ib_buffer_pool
2020-07-14 13:33:14 2 [ERROR] InnoDB: Failed to find tablespace for table `mysql`.`innodb_index_stats` in the cache. Attempting to load the tablespace with space id 2
2020-07-14 13:33:14 2 [ERROR] InnoDB: Operating system error number 13 in a file operation.
2020-07-14 13:33:14 2 [ERROR] InnoDB: The error means mysqld does not have the access rights to the directory.
2020-07-14 13:33:14 2 [ERROR] InnoDB: Cannot open datafile for read-only: './mysql/innodb_index_stats.ibd' OS error: 81
2020-07-14 13:33:14 2 [ERROR] InnoDB: Could not find a valid tablespace file for ``mysql`.`innodb_index_stats``. Please refer to https://mariadb.com/kb/en/innodb-data-dictionary-troubleshooting/ for how to resolve the issue.
2020-07-14 13:33:14 4 [ERROR] InnoDB: Failed to find tablespace for table `nextcloud`.`oc_authtoken` in the cache. Attempting to load the tablespace with space id 57
2020-07-14 13:33:14 4 [ERROR] InnoDB: Operating system error number 13 in a file operation.
2020-07-14 13:33:14 4 [ERROR] InnoDB: The error means mysqld does not have the access rights to the directory.
2020-07-14 13:33:14 4 [ERROR] InnoDB: Cannot open datafile for read-only: './nextcloud/oc_authtoken.ibd' OS error: 81
2020-07-14 13:33:14 0 [Note] Plugin 'FEEDBACK' is disabled.
2020-07-14 13:33:14 4 [ERROR] InnoDB: Could not find a valid tablespace file for ``nextcloud`.`oc_authtoken``. Please refer to https://mariadb.com/kb/en/innodb-data-dictionary-troubleshooting/ for how to resolve the issue.
2020-07-14 13:33:14 2 [ERROR] InnoDB: Failed to find tablespace for table `mysql`.`innodb_table_stats` in the cache. Attempting to load the tablespace with space id 1
2020-07-14 13:33:14 0 [ERROR] Could not open mysql.plugin table. Some plugins may be not loaded
2020-07-14 13:33:14 2 [ERROR] InnoDB: Cannot open datafile for read-only: './mysql/innodb_table_stats.ibd' OS error: 81
2020-07-14 13:33:14 0 [Note] Recovering after a crash using tc.log
2020-07-14 13:33:14 2 [ERROR] InnoDB: Could not find a valid tablespace file for ``mysql`.`innodb_table_stats``. Please refer to https://mariadb.com/kb/en/innodb-data-dictionary-troubleshooting/ for how to resolve the issue.
2020-07-14 13:33:14 0 [ERROR] Bad magic header in tc log
2020-07-14 13:33:14 0 [ERROR] Crash recovery failed. Either correct the problem (if it's, for example, out of memory error) and restart, or delete tc log and start mysqld with --tc-heuristic-recover={commit|rollback}
2020-07-14 13:33:14 0 [ERROR] Can't init tc log
2020-07-14 13:33:14 0 [ERROR] Aborting
2020-07-14 13:33:14 2 [ERROR] InnoDB: Failed to find tablespace for table `nextcloud`.`oc_appconfig` in the cache. Attempting to load the tablespace with space id 8
2020-07-14 13:33:14 2 [ERROR] InnoDB: Cannot open datafile for read-only: './nextcloud/oc_appconfig.ibd' OS error: 81
2020-07-14 13:33:14 2 [ERROR] InnoDB: Could not find a valid tablespace file for ``nextcloud`.`oc_appconfig``. Please refer to https://mariadb.com/kb/en/innodb-data-dictionary-troubleshooting/ for how to resolve the issue.
2020-07-14 13:33:14 2 [ERROR] InnoDB: Failed to find tablespace for table `nextcloud`.`oc_jobs` in the cache. Attempting to load the tablespace with space id 40
2020-07-14 13:33:14 2 [ERROR] InnoDB: Cannot open datafile for read-only: './nextcloud/oc_jobs.ibd' OS error: 81
2020-07-14 13:33:14 2 [ERROR] InnoDB: Could not find a valid tablespace file for ``nextcloud`.`oc_jobs``. Please refer to https://mariadb.com/kb/en/innodb-data-dictionary-troubleshooting/ for how to resolve the issue.
2020-07-14 13:33:14 0 [ERROR] InnoDB: Cannot open '/mnt/dietpi_userdata/mysql/ib_buffer_pool.incomplete' for writing: Permission denied
2020-07-14 13:33:17 0 [ERROR] InnoDB: Operating system error number 13 in a file operation.
2020-07-14 13:33:17 0 [ERROR] InnoDB: The error means mysqld does not have the access rights to the directory.
