Pi 4 not booting Topic is solved
Deleted User 7758
Re: Pi 4 not booting
Post by Deleted User 7758 »
Same result again. I'll buy a new sd card later today but that card seems to be working fine
Here's a short clip showing the LED activity when power is applied with a fresh rasping lite on the card
https://app.box.com/s/i9kw8kk02szdw21fsr8r1i5f1ksunlpe
honestly I'm not sure how many flashes are this. Do you have any USB device connected? If yes, maybe you can remove them and try again. But if even Raspbian is not booting, something wrong on your device.
Deleted User 7758
No. There is nothing else connected.
:cry:
Where to from here?
I guess I need to try my new sd card and then try recovery on the eprom
Deleted User 7758
Update:
tried the new sd card with Raspian Lite and same result.
Then I followed the eprom recovery instructions (which seemed to work fine), to double check the eprom is ok
LED activity is exactly the same as in the above video
Basically you could try to place your problem on a Raspberry Pi specific board. Maybe there someone has an idea why your SBC is not booting anymore. Probably there are some hardware issues?
