Feature request - cloudshell XU4
johnvick
Legend
Re: Feature request - cloudshell XU4
Post by johnvick »
This was done when the eMMC was repsorted as not active:
/dev/mmcblk0p2 29G 11G 18G 38% /
udev 10M 0 10M 0% /dev
tmpfs 399M 6.8M 392M 2% /run
tmpfs 996M 4.0K 996M 1% /dev/shm
tmpfs 996M 0 996M 0% /sys/fs/cgroup
/dev/sda1 110G 3.6G 101G 4% /mnt/usb_2
tmpfs 10M 1.3M 8.8M 13% /DietPi
tmpfs 996M 12K 996M 1% /tmp
/dev/mmcblk0p1 71M 33M 39M 46% /boot
/dev/sdb1 15G 5.9G 8.0G 43% /mnt/usb_1
192.168.1.4:/pi 8.2T 4.7T 3.5T 58% /mnt/pi
192.168.1.4:/Multimedia/Music/John's iTunes/Music 8.2T 4.7T 3.5T 58% /mnt/Music
192.168.1.4:/Multimedia/Movies 8.2T 4.7T 3.5T 58% /mnt/Movies
192.168.1.4:/TV Series 8.2T 4.7T 3.5T 58% /mnt/TV Series
192.168.1.4:/TV Documentaries 8.2T 4.7T 3.5T 58% /mnt/TV Documentaries
192.168.1.4:/Triathlon 8.2T 4.7T 3.5T 58% /mnt/Triathlon
192.168.1.4:/Music Videos 8.2T 4.7T 3.5T 58% /mnt/Music Videos
192.168.1.4:/Multimedia/Photos 8.2T 4.7T 3.5T 58% /mnt/Photos
Fourdee
Post by Fourdee »
Thanks John,
Bizarre. When executing the source code based on the above df export, all seems fine:
root@DietPi-XU4:~# store_path='/'
root@DietPi-XU4:~# cat test | grep "$store_path$"
Was there any of the following entries in the log file?:
"$(date) | df failed to respond"
note to self:
kill df process not waiting for termination?
johnvick
Legend
Post by johnvick »
Hi Fourdee,
Just tried again all drives reported as mounted - no errors anywhere.
And the mount not active message still appears seemingly randomly.
John
Fourdee
Post by Fourdee »
johnvick wrote:Hi Fourdee,
John
Hi John,
Thanks for update.
I'am still unable to replicate this my end, so this may need to go back and forth for a while before we find the cause.
If the 'Mount not active' message appears, please copy/paste the whole logfile contents:
/var/log/dietpi-cloudshell.log
Also, if you can, please paste results of:
ps aux
johnvick
Legend
Post by johnvick »
HI Fourdee,
The log is here:
http://pastebin.com/1qgRtZ1b
ps aux is below
root@odroid:~# ps aux
USER       PID %CPU %MEM    VSZ   RSS TTY      STAT START   TIME COMMAND
root         1  0.1  0.1   5448  3116 ?        Ss   07:05   0:08 /sbin/init
root         2  0.0  0.0      0     0 ?        S    07:05   0:00 [kthreadd]
root         3  0.2  0.0      0     0 ?        S    07:05   0:13 [ksoftirqd/0]
root         5  0.0  0.0      0     0 ?        S<   07:05   0:00 [kworker/0:0H]
root         7  0.0  0.0      0     0 ?        S    07:05   0:00 [migration/0]
root         8  0.5  0.0      0     0 ?        S    07:05   0:24 [rcu_preempt]
root         9  0.0  0.0      0     0 ?        S    07:05   0:00 [rcu_bh]
root        10  0.0  0.0      0     0 ?        S    07:05   0:00 [rcu_sched]
root        11  0.0  0.0      0     0 ?        S    07:05   0:00 [watchdog/0]
root        12  0.0  0.0      0     0 ?        S    07:05   0:00 [watchdog/1]
root        13  0.0  0.0      0     0 ?        S    07:05   0:00 [migration/1]
root        14  0.0  0.0      0     0 ?        S    07:05   0:00 [ksoftirqd/1]
root        16  0.0  0.0      0     0 ?        S<   07:05   0:00 [kworker/1:0H]
root        17  0.0  0.0      0     0 ?        S    07:05   0:00 [watchdog/2]
root        18  0.0  0.0      0     0 ?        S    07:05   0:00 [migration/2]
root        19  0.0  0.0      0     0 ?        S    07:05   0:00 [ksoftirqd/2]
root        21  0.0  0.0      0     0 ?        S<   07:05   0:00 [kworker/2:0H]
root        22  0.0  0.0      0     0 ?        S    07:05   0:00 [watchdog/3]
root        23  0.0  0.0      0     0 ?        S    07:05   0:00 [migration/3]
root        24  0.0  0.0      0     0 ?        S    07:05   0:00 [ksoftirqd/3]
root        26  0.0  0.0      0     0 ?        S<   07:05   0:00 [kworker/3:0H]
root        27  0.0  0.0      0     0 ?        S    07:05   0:00 [watchdog/4]
root        28  0.0  0.0      0     0 ?        S    07:05   0:00 [migration/4]
root        29  0.0  0.0      0     0 ?        S    07:05   0:00 [ksoftirqd/4]
root        31  0.0  0.0      0     0 ?        S<   07:05   0:00 [kworker/4:0H]
root        32  0.0  0.0      0     0 ?        S    07:05   0:00 [watchdog/5]
root        33  0.0  0.0      0     0 ?        S    07:05   0:00 [migration/5]
root        34  0.0  0.0      0     0 ?        S    07:05   0:00 [ksoftirqd/5]
root        36  0.0  0.0      0     0 ?        S<   07:05   0:00 [kworker/5:0H]
root        37  0.0  0.0      0     0 ?        S    07:05   0:00 [watchdog/6]
root        38  0.0  0.0      0     0 ?        S    07:05   0:00 [migration/6]
root        39  0.0  0.0      0     0 ?        S    07:05   0:00 [ksoftirqd/6]
root        41  0.0  0.0      0     0 ?        S<   07:05   0:00 [kworker/6:0H]
root        42  0.0  0.0      0     0 ?        S    07:05   0:00 [watchdog/7]
root        43  0.0  0.0      0     0 ?        S    07:05   0:00 [migration/7]
root        44  0.0  0.0      0     0 ?        S    07:05   0:00 [ksoftirqd/7]
root        46  0.0  0.0      0     0 ?        S<   07:05   0:00 [kworker/7:0H]
root        47  0.0  0.0      0     0 ?        S<   07:05   0:00 [khelper]
root        48  0.0  0.0      0     0 ?        S    07:05   0:00 [kdevtmpfs]
root        49  0.0  0.0      0     0 ?        S<   07:05   0:00 [netns]
root        50  0.0  0.0      0     0 ?        S<   07:05   0:00 [writeback]
root        51  0.0  0.0      0     0 ?        S<   07:05   0:00 [kintegrityd]
root        52  0.0  0.0      0     0 ?        S<   07:05   0:00 [bioset]
root        53  0.0  0.0      0     0 ?        S<   07:05   0:00 [crypto]
root        54  0.0  0.0      0     0 ?        S<   07:05   0:00 [kblockd]
root        55  0.0  0.0      0     0 ?        S    07:05   0:00 [khubd]
root        59  0.0  0.0      0     0 ?        S    07:05   0:00 [irq/512-s2mps1
root        65  0.0  0.0      0     0 ?        S    07:05   0:00 [ion_noncontig_
root        66  0.0  0.0      0     0 ?        S<   07:05   0:00 [devfreq_wq]
root        67  0.0  0.0      0     0 ?        S    07:05   0:01 [kworker/5:1]
root        68  0.1  0.0      0     0 ?        S    07:05   0:05 [kworker/4:1]
root        69  0.1  0.0      0     0 ?        S    07:05   0:07 [kworker/0:1]
root        70  0.0  0.0      0     0 ?        S    07:05   0:00 [kworker/2:1]
root        71  0.0  0.0      0     0 ?        S    07:05   0:01 [kworker/3:1]
root        72  0.0  0.0      0     0 ?        S    07:05   0:00 [kworker/1:1]
root        73  0.0  0.0      0     0 ?        S    07:05   0:01 [kworker/6:1]
root        74  0.0  0.0      0     0 ?        S    07:05   0:00 [khungtaskd]
root        75  0.0  0.0      0     0 ?        S    07:05   0:00 [kswapd0]
root        76  0.0  0.0      0     0 ?        S    07:05   0:00 [fsnotify_mark]
root        91  0.0  0.0      0     0 ?        S<   07:05   0:00 [kthrotld]
root        92  0.0  0.0      0     0 ?        S    07:05   0:00 [irq/529-hdmi]
root        93  0.0  0.0      0     0 ?        S<   07:05   0:00 [g3d_dvfs]
root        94  0.0  0.0      0     0 ?        S<   07:05   0:00 [kworker/u17:0]
root        95  0.0  0.0      0     0 ?        S<   07:05   0:00 [kbase_job_faul
root        96  0.0  0.0      0     0 ?        S<   07:05   0:00 [kworker/u17:1]
root        97  0.0  0.0      0     0 ?        S    07:05   0:00 [irq/530-dwc3_i
root        98  0.0  0.0      0     0 ?        S    07:05   0:00 [irq/531-dwc3_b
root        99  0.0  0.0      0     0 ?        S<   07:05   0:00 [usb_switch]
root       100  0.0  0.0      0     0 ?        S    07:05   0:00 [irq/128-110000
root       101  0.0  0.0      0     0 ?        S<   07:05   0:00 [s5p_mfc/watchd
root       102  0.0  0.0      0     0 ?        S<   07:05   0:00 [s5p_mfc/sched]
root       103  0.0  0.0      0     0 ?        S<   07:05   0:00 [dw-mci-card]
root       104  0.0  0.0      0     0 ?        S<   07:05   0:00 [dw-mci-card]
root       112  0.3  0.0      0     0 ?        S    07:05   0:16 [mmcqd/0]
root       113  0.0  0.0      0     0 ?        S    07:05   0:00 [mmcqd/0boot0]
root       114  0.0  0.0      0     0 ?        S    07:05   0:00 [mmcqd/0boot1]
root       116  0.0  0.0      0     0 ?        S    07:05   0:00 [scsi_eh_0]
root       117  0.0  0.0      0     0 ?        S    07:05   0:00 [usb-storage]
root       118  0.0  0.0      0     0 ?        S    07:05   0:00 [scsi_eh_1]
root       119  0.0  0.0      0     0 ?        S    07:05   0:00 [usb-storage]
root       120  0.0  0.0      0     0 ?        S<   07:05   0:00 [kworker/6:1H]
root       122  0.0  0.0      0     0 ?        S<   07:05   0:00 [deferwq]
root       123  0.0  0.0      0     0 ?        S<   07:05   0:00 [cluster_monito
root       124  0.1  0.0      0     0 ?        S    07:05   0:07 [thread_hotplug
root       125  0.0  0.0      0     0 ?        S<   07:05   0:00 [event-hotplug]
root       126  0.0  0.0      0     0 ?        S<   07:05   0:00 [force-hotplug]
root       156  0.0  0.0      0     0 ?        S<   07:05   0:00 [kworker/4:1H]
root       157  0.0  0.0      0     0 ?        S<   07:05   0:00 [kworker/0:1H]
root       158  0.0  0.0      0     0 ?        S<   07:05   0:00 [kworker/7:1H]
root       159  0.0  0.0      0     0 ?        S<   07:05   0:00 [kworker/5:1H]
root       161  0.0  0.0      0     0 ?        S<   07:05   0:00 [kworker/3:1H]
root       177  0.0  0.0      0     0 ?        S<   07:05   0:00 [kworker/1:1H]
root       178  0.0  0.0      0     0 ?        S<   07:05   0:00 [kworker/2:1H]
root       199  0.0  0.0      0     0 ?        S    07:05   0:02 [jbd2/mmcblk0p2
root       200  0.0  0.0      0     0 ?        S<   07:05   0:00 [ext4-dio-unwri
root       245  0.0  0.0      0     0 ?        S    07:05   0:02 [kworker/7:2]
root       252 35.1  0.0      0     0 ?        S    07:05  27:09 [spi1]
root       260 13.4  0.0      0     0 ?        D    07:05  10:20 [irq/534-ads784
root       274  0.0  0.1   8724  2072 ?        Ss   07:05   0:00 /lib/systemd/sy
root       283  0.0  0.0  10452  1396 ?        Ss   07:05   0:00 /lib/systemd/sy
root       429  0.0  0.0      0     0 ?        S    07:05   0:00 [jbd2/sda1-8]
root       430  0.0  0.0      0     0 ?        S<   07:05   0:00 [ext4-dio-unwri
root       434  0.0  0.0      0     0 ?        S    07:05   0:00 [jbd2/sdb1-8]
root       435  0.0  0.0      0     0 ?        S<   07:05   0:00 [ext4-dio-unwri
root       549  0.0  0.0      0     0 ?        S<   07:05   0:00 [rpciod]
root       556  0.0  0.0      0     0 ?        S<   07:05   0:00 [nfsiod]
root       586  0.0  0.0   3660  1024 ?        Ss   07:05   0:00 /sbin/rpcbind -
statd      623  0.0  0.0   3860  1260 ?        Ss   07:05   0:00 /sbin/rpc.statd
root       661  0.0  0.0   2356   596 ?        Ss   07:05   0:00 /usr/sbin/rpc.i
root       666  0.0  0.0      0     0 ?        S    07:05   0:00 [lockd]
root       774  0.0  0.9 134756 19036 ?        Ss   07:05   0:01 php-fpm: master
daemon     775  0.0  0.0   2164   696 ?        Ss   07:05   0:00 /usr/sbin/atd -
root       777  0.0  0.1   6532  2152 ?        Ss   07:05   0:00 /usr/sbin/sshd
root       780  0.0  0.0   2676  1040 ?        Ss   07:05   0:00 /lib/systemd/sy
message+   799  0.0  0.0   4576  1448 ?        Ss   07:05   0:00 /usr/bin/dbus-d
root       866  0.0  0.0  31392  2016 ?        Ssl  07:05   0:00 /usr/sbin/rsysl
www-data   900  0.1  2.1 149972 44136 ?        S    07:05   0:06 php-fpm: pool w
www-data   902  0.1  2.5 150036 52536 ?        S    07:05   0:06 php-fpm: pool w
root       945  2.1  0.0      0     0 ?        R    07:05   1:39 [cfinteractive0
root       953  0.7  0.0      0     0 ?        S    07:05   0:35 [cfinteractive4
root      1011  0.7  1.5 103456 31396 ?        Sl   07:05   0:35 /usr/bin/python
root      1014  0.0  0.7  21100 15752 ?        Ss   07:05   0:00 /usr/bin/perl /
root      1097  0.0  0.0   4444  1300 tty1     Ss   07:05   0:00 /bin/login -f
root      1139  0.6  1.4 230580 28992 ?        Sl   07:05   0:32 /usr/bin/python
root      1192  0.0  0.1   5912  2720 tty1     S+   07:05   0:00 -bash
root      1226  0.0  0.0   4664  1004 ?        Ss   07:05   0:00 /usr/sbin/cron
root      1312  2.5  0.1   5516  2256 ?        SN   07:05   1:56 /bin/bash /Diet
root      1358  0.0  0.2  31084  4680 ?        Ss   07:05   0:01 /usr/sbin/smbd
root      1380  0.0  0.1  31084  2396 ?        S    07:05   0:00 /usr/sbin/smbd
root      1402  0.0  0.1  19564  2280 ?        Ss   07:05   0:00 /usr/sbin/nmbd
www-data  1425  0.1  0.2   9644  4236 ?        Ss   07:05   0:08 /usr/sbin/light
root      1444  0.0  0.6 172232 12308 ?        Ss   07:05   0:01 php-fpm: master
www-data  1449  0.0  0.1 172232  3424 ?        S    07:05   0:00 php-fpm: pool w
www-data  1450  0.0  0.1 172232  3424 ?        S    07:05   0:00 php-fpm: pool w
www-data  1451  0.0  0.1 172232  3424 ?        S    07:05   0:00 php-fpm: pool w
www-data  1452  0.0  0.1 172232  3424 ?        S    07:05   0:00 php-fpm: pool w
root      1485  0.0  0.0   1432   488 ?        S    07:05   0:00 /bin/sh /usr/bi
mysql     1988  1.0  3.5 312692 71420 ?        Sl   07:05   0:47 /usr/sbin/mysql
www-data  2070  0.1  0.4  13360  8720 ?        S    07:05   0:07 /usr/sbin/dnsma
root      2122  0.0  0.0   5592  1184 ?        Ss   07:05   0:00 su -s /bin/sh -
root      2126  0.2  0.1 800280  3944 ?        Sl   07:05   0:11 /usr/bin/syncth
emby      2156 14.7 23.9 564876 488268 ?       Ssl  07:05  11:18 /usr/bin/mono-s
root      2159 50.2  2.5 802648 51032 ?        Sl   07:05  38:36 /usr/bin/syncth
urbackup  2167  0.0  0.7  81984 16148 ?        Sl   07:05   0:03 /usr/sbin/urbac
root      2326  3.0  5.5 241344 113628 ?       Sl   07:06   2:20 /usr/bin/python
root      2329  0.2  1.2  31920 25692 ?        S    07:06   0:09 /usr/bin/python
root      2367  3.3  1.3  63492 27748 ?        Sl   07:06   2:34 /usr/bin/python
www-data  3970  0.1  2.1 152020 42872 ?        S    07:06   0:06 php-fpm: pool w
root      3985  0.1  0.0      0     0 ?        S    08:11   0:01 [kworker/u16:2]
root      5465  0.0  0.0      0     0 ?        S    08:12   0:00 [kworker/6:0]
root      5545  0.0  0.0      0     0 ?        S    08:12   0:00 [kworker/0:2]
root      5617  0.0  0.0      0     0 ?        S    08:13   0:00 [kworker/7:0]
root      7600  0.0  0.0      0     0 ?        S    07:42   0:00 [kworker/1:2]
root      7740  0.0  0.0      0     0 ?        S    08:15   0:00 [kworker/4:0]
root      9376  0.0  0.0      0     0 ?        S    08:16   0:00 [kworker/5:2]
root     10665  0.0  0.1  10204  2764 ?        Ss   08:17   0:00 sshd: root@nott
root     10675  0.0  0.0   1952   852 ?        Ss   08:17   0:00 /usr/lib/openss
root     10827  0.0  0.1  10068  2740 ?        Rs   08:18   0:00 sshd: root@pts/
root     10837  0.0  0.1   5908  2688 pts/0    Ss   08:18   0:00 -bash
root     11719  0.0  0.0      0     0 ?        S    08:19   0:00 [kworker/6:2]
root     12494  0.0  0.0      0     0 ?        S    08:19   0:00 [kworker/0:0]
root     13157  0.0  0.0      0     0 ?        S    08:20   0:00 [kworker/4:2]
root     13972  0.6  0.0      0     0 ?        S    08:21   0:00 [kworker/u16:0]
root     14808  0.0  0.0      0     0 ?        S    08:22   0:00 [kworker/5:0]
root     15424  0.0  0.0   3184   468 ?        SN   08:22   0:00 sleep 5
root     15426  0.0  0.0   4440   936 pts/0    R+   08:22   0:00 ps aux
root     26366  0.0  0.0      0     0 ?        S    08:01   0:00 [kworker/3:2]
root     27237  0.0  0.0      0     0 ?        S    08:02   0:00 [kworker/2:2]
root     30218  0.3  0.0      0     0 ?        S    08:05   0:03 [kworker/u16:1]
Thanks again for looking into this.
John
Fourdee
Post by Fourdee »
Thanks John.
Looks like this is occurring alot. Will check it over and hopefully i'll come back with some solutions :)
EDIT:
/mnt/TV Series
Think it may have something to do with the space in your mount targets, as we use AWK to print a specific section separated by whitespace. Lemme run some tests.
johnvick
Legend
Post by johnvick »
Hi Fourdee,
I think you are onto something - in FSTAB I commented out the shares with spaces in their names, rebooted, and no "Mount not active" message.
I change FSTAB back and mount -av and the message reappears.
John
Fourdee
Post by Fourdee »
John
Hi John,
Excellent! I'll create a ticket and take a look: https://github.com/Fourdee/DietPi/issues/618, should be a simple fix (probably jinxed it now lol)
Fourdee
Post by Fourdee »
Hi John,
I cant seem to find your /etc/fstab file in this thread, want to take a look at mounts, any chance you could paste it here please when you get a chance?
johnvick
Legend
Post by johnvick »
Fourdee wrote:Hi John,
Here we go and thanks for looking into this.
#Internal Drives---------------------------------------------------
proc            /proc           proc    defaults							0 0
UUID=96C3-9298 /boot vfat	defaults,noatime,discard						0 2
UUID=e139ce78-9841-40fe-8823-96a304a09859  /   ext4    defaults,noatime,discard		0 1
UUID=923cb99c-a4fd-47e7-99ca-eb260494eea7 /mnt/usb_1 ext4 defaults,noatime			0 1
UUID=219a7a4a-196b-4156-a176-f52e6b11c9c3       /mnt/usb_2      auto     defaults,noatime,nofail,x-systemd.automount  0       0
#/home/john/crypt /home/john/crypt ecryptfs defaults,noatime,nofail 0 0
#QNAP
192.168.1.4:/pi /mnt/pi nfs rsize=8192,wsize=8192,timeo=14,intr 0 0
192.168.1.4:/Multimedia/Music/John's\040iTunes/Music /mnt/Music nfs rsize=8192,wsize=8192,timeo=14,intr 0 0
192.168.1.4:/Multimedia/Movies /mnt/Movies nfs rsize=8192,wsize=8192,timeo=14,intr 0 0
192.168.1.4:/TV\040Series /mnt/TV\040Series nfs rsize=8192,wsize=8192,timeo=14,intr 0 0
192.168.1.4:/TV\040Documentaries /mnt/TV\040Documentaries nfs rsize=8192,wsize=8192,timeo=14,intr 0 0
192.168.1.4:/Triathlon /mnt/Triathlon nfs rsize=8192,wsize=8192,timeo=14,intr 0 0
192.168.1.4:/Music\040Videos /mnt/Music\040Videos nfs rsize=8192,wsize=8192,timeo=14,intr 0 0
192.168.1.4:/Multimedia/Photos /mnt/Photos nfs rsize=8192,wsize=8192,timeo=14,intr 0 0
#/dev/mmcblk0p1  /boot           vfat    defaults,noatime,discard							0 2
#/dev/mmcblk0p2  /               ext4    defaults,noatime,discard							0 1
tmpfs 			/tmp  			tmpfs 	defaults,noatime,nodev,nosuid,mode=1777				0 0
#/var/log DietPi Ramlog Disabled
tmpfs 			/DietPi
