Feature request - cloudshell XU4
Fourdee
Re: Feature request - cloudshell XU4
Post by Fourdee »
johnvick wrote:Hi Fourdee,
Still intermittently getting this message and all drives present with df -h. Sometimes the root fs drive is reported as "Mount not active" which is a bit of a paradox.
John
Hi John,
I've updated the script to provide a little more information. I believe df is failing to respond (timing out). If i remember correctly, are you running any NFS mounts on this system?
We currently allow for 4 seconds, before we terminate the df process if it doesnt respond. As previously, this prevents it locking up the Cloudshell stats in NFS drop situations,
Get new script:
wget https://raw.githubusercontent.com/Fourdee/DietPi/testing/dietpi/dietpi-cloudshell -O /DietPi/dietpi/dietpi-cloudshell
If df fails to respond, error log will be created here, and, you'll also get a "DF failed" print on the scene:
/var/log/dietpi-cloudshell.log
johnvick
Legend
Post by johnvick »
Hi Fourdee,
Thanks for the update - but no change here. Sometime I have a correct display, sometime it is the "Mount not cative message".
I have NFS shares on a QNAP but it doesn't make any difference if this is powered up or not. I drives I reference in Cloudshell are local - a USB flask and an SSD.
John
Fourdee
Post by Fourdee »
Hi John,
Really strange.
Checked the code. It appears df is returning a result, but for some reason, the result is missing your mounted drives. Basically this means the drive isn't mounted at that time, which is bizarre lol.
Lets check dmesg for any mounting information
If you get a chance, could you please paste/upload the results of:
dmesg
johnvick
Legend
Post by johnvick »
HI Fourdee,
Too big for here so here's the link:
http://pastebin.com/WPyL6hUu
John
Fourdee
Post by Fourdee »
johnvick wrote:HI Fourdee,
John
Hi John,
Thanks.
Only appears we have logs for 32 seconds after boot. If any errors occurred afterwards, they should be time stamped.
[ 8.292214] [c7] sdb: unknown partition table
[ 8.340711] [c7] EXT4-fs (sdb): mounting with "discard" option, but the device does not support discard
[ 8.341533] [c7] EXT4-fs (sdb): mounted filesystem with ordered data mode. Opts: discard
Strange, it reports a unknown partition table (note: maybe it doesn't like GPT, prefers MBR?), yet mounts it fine. Can you remember how this drive was originally formatted (eg: through dietpi-drive_manager or elsewhere)?
johnvick
Legend
Post by johnvick »
John
Hi John,
Thanks.
I think I formatted this from the command line but I can't really remember - this is a 120 GB SSD.
I'll reformat through DietPi later today and see if that makes any difference.
John
johnvick
Legend
Post by johnvick »
Hi Fourdee,
Reformatted the SSD with dietpi drive manager and mounted as usb_2.
Still the same "Mount not active" message on the eMMC and SSD drives - the USB flash drive does not show this message. The numbers look as they should be for all three drives.
The dmesg is here:
http://pastebin.com/KNq7qfq7
Thanks for you help with this I am not sure where to go from here.
John
Fourdee
Post by Fourdee »
johnvick wrote: The dmesg is here:
John
Thanks John, I'll take a look and get back to you within a few days (NanoPi's turned up, image'r'us ;) lol)
https://github.com/Fourdee/DietPi/issues/603
https://github.com/Fourdee/DietPi/issues/602
johnvick
Legend
Post by johnvick »
Hi Fourdee,
Thanks for following up on this - the numbers on the display are fine the only irregularity is the "mount not active" error - this doesn't worry me but I know you'll want this working perfectly.
Any other cloudshell users tested this?
John
Fourdee
Post by Fourdee »
Hi John,
Dmesg looks fine.
I've added some extra debug/logging code to the script, should give us some useful information on the cause:
Reboot system.
When you notice the "Mount not active" message, check the log file and paste results please:
cat /var/log/dietpi-cloudshell.log
