Argon One Case Fan Topic is solved
Re: Argon One Case Fan
Thanks for sharing. This script seems to be adjusted to fully work with Python 3 and not depend on Raspbian (which probably makes it work on the ARMv7 and ARMv8 Debian based images): https://github.com/meuter/argon-one-case-ubuntu-20.04
papiosaur
Post by papiosaur »
Hello all,
i have bought a RaspBerry Pi4 and an ArgonOne V2 bu impossible to activate Fan with DietPi.
It work on other distribution like Retropie or Batocera.
I have tried all script here without success.
Is there a small tutorial work fine with step by step please ?
What are dependencies to install, maybe i must have another login ?
Thanks for your help!
did you install Python3 from dietpi-software catalogue?
can you share following as well
systemctl status argononed.service
norbiato
Post by norbiato »
papiosaur wrote: Wed Sep 08, 2021 8:42 pm Hello all,
Try run in this order
curl https://download.argon40.com/argonone-setup-osmc.sh | bash
curl https://download.argon40.com/argon1.sh | bash
Check this too
dietpi-config > 4 Advanced Options > i2c State > ON
reboot
