Can't change lighttpd's port for HaProxy reverse proxy Topic is solved
Re: Can't change lighttpd's port for HaProxy reverse proxy
yes that would be possible to create a wildcard certificate using cerbot. However you need to be able to mange your DynDNS record and add a TXT record under the name _acme-challenge. There are a couple of guides on the web how this could be archived.
https://community.letsencrypt.org/t/wil ... ep/58250/4
I guess renewing the certificate might be a challenge as well as you would need to update DynDNS record again.
It might be easier to have a look into capabilities to use lighttpd as reverse-proxy
Rilic
Post by Rilic »
OK, so after learning a few things I realised that HaProxy isn't launching because it doesn't see the binary??
root@Ouroboros:~# systemctl status haproxy.service
● haproxy.service - HAProxy Load Balancer
   Loaded: loaded (/etc/systemd/system/haproxy.service; disabled; vendor preset: enabled)
   Active: failed (Result: exit-code) since Tue 2020-06-09 09:07:28 BST; 15s ago
  Process: 1175 ExecStartPre=/usr/local/sbin/haproxy -f $CONFIG -c -q $EXTRAOPTS (code=exited, status=203/EXEC)
Jun 09 09:07:27 Ouroboros systemd[1175]: haproxy.service: Failed at step EXEC spawning /usr/local/sbin/haproxy: No such file or directory
Jun 09 09:07:27 Ouroboros systemd[1]: haproxy.service: Control process exited, code=exited, status=203/EXEC
Jun 09 09:07:27 Ouroboros systemd[1]: haproxy.service: Failed with result 'exit-code'.
Jun 09 09:07:27 Ouroboros systemd[1]: Failed to start HAProxy Load Balancer.
Jun 09 09:07:28 Ouroboros systemd[1]: haproxy.service: Service RestartSec=100ms expired, scheduling restart.
Jun 09 09:07:28 Ouroboros systemd[1]: haproxy.service: Scheduled restart job, restart counter is at 5.
Jun 09 09:07:28 Ouroboros systemd[1]: Stopped HAProxy Load Balancer.
Jun 09 09:07:28 Ouroboros systemd[1]: haproxy.service: Start request repeated too quickly.
Jun 09 09:07:28 Ouroboros systemd[1]: haproxy.service: Failed with result 'exit-code'.
Jun 09 09:07:28 Ouroboros systemd[1]: Failed to start HAProxy Load Balancer.
I'm sure this isn't meant to happen, right?
did you reinstall HaProxy using dietpi-software after you deleted it?
Rilic
Post by Rilic »
Yeah, I did. Would the binary be in a different place, or?
can you run dietpi-software reinstall 98
Rilic
Post by Rilic »
Reinstalling it returns the same problem:
   Active: failed (Result: exit-code) since Tue 2020-06-09 12:39:07 BST; 3min 37s ago
  Process: 5039 ExecStartPre=/usr/local/sbin/haproxy -f $CONFIG -c -q $EXTRAOPTS (code=exited, status=203/EXEC)
Jun 09 12:39:07 Ouroboros systemd[1]: haproxy.service: Service RestartSec=100ms expired, scheduling restart.
Jun 09 12:39:07 Ouroboros systemd[1]: haproxy.service: Scheduled restart job, restart counter is at 5.
Jun 09 12:39:07 Ouroboros systemd[1]: Stopped HAProxy Load Balancer.
Jun 09 12:39:07 Ouroboros systemd[1]: haproxy.service: Start request repeated too quickly.
Jun 09 12:39:07 Ouroboros systemd[1]: haproxy.service: Failed with result 'exit-code'.
Jun 09 12:39:07 Ouroboros systemd[1]: Failed to start HAProxy Load Balancer.
well the error messag changed. You did not get the following anymore
probably you have an incorrect or not consistent config file that prevent HaProxy to start
Rilic
Post by Rilic »
Found this page to help validate haproxy.cfg: https://stackoverflow.com/questions/396 ... aproxy-cfg
I followed the instructions but the commands couldn't find the haproxy binary. I tried restarting the service again but it gave me the file not found error:
   Active: failed (Result: exit-code) since Tue 2020-06-09 12:58:26 BST; 5s ago
  Process: 1009 ExecStartPre=/usr/local/sbin/haproxy -f $CONFIG -c -q $EXTRAOPTS (code=exited, status=203/EXEC)
Jun 09 12:58:25 Ouroboros systemd[1009]: haproxy.service: Failed at step EXEC spawning /usr/local/sbin/haproxy: No such file or directory
Jun 09 12:58:25 Ouroboros systemd[1]: haproxy.service: Control process exited, code=exited, status=203/EXEC
Jun 09 12:58:25 Ouroboros systemd[1]: haproxy.service: Failed with result 'exit-code'.
Jun 09 12:58:25 Ouroboros systemd[1]: Failed to start HAProxy Load Balancer.
Jun 09 12:58:26 Ouroboros systemd[1]: haproxy.service: Service RestartSec=100ms expired, scheduling restart.
Jun 09 12:58:26 Ouroboros systemd[1]: haproxy.service: Scheduled restart job, restart counter is at 5.
Jun 09 12:58:26 Ouroboros systemd[1]: Stopped HAProxy Load Balancer.
Jun 09 12:58:26 Ouroboros systemd[1]: haproxy.service: Start request repeated too quickly.
Jun 09 12:58:26 Ouroboros systemd[1]: haproxy.service: Failed with result 'exit-code'.
Jun 09 12:58:26 Ouroboros systemd[1]: Failed to start HAProxy Load Balancer.
Is something deleting it?
ok I had a look to the installation process and it seems some issues with the current one. At least for me it's giving the following error
make: *** [Makefile:857: haproxy] Error 1
strip: 'haproxy': No such file
Please run 'make' before 'make install'.
make: *** [Makefile:899: install-bin] Error 1
the software is compiled during installation and this did not finished. Therefore haproxy is not created and missing. Anyway I found that there is a newer version of haproxy availably than installed by DietPi. To get this version you would need to update one of the DietPi scripts. As this is a huge script, I recommend to use the search function inside the code.
nano /boot/dietpi/dietpi-software
Go-to line 4276 and adjust version='2.1.7'. Once done, safe the file and reinstall haproxy
On my system, installation finished without error now
Rilic
Post by Rilic »
It's using the new file now:
[  OK  ] DietPi-Software | Checking URL: https://www.haproxy.org/download/2.1/src/haproxy-2.1.7.tar.gz
Upon installing, it seems like it removes a lot of files:
  CC      ebtree/ebmbtree.o
  CC      ebtree/ebsttree.o
  CC      ebtree/ebimtree.o
  CC      ebtree/ebistree.o
  LD      haproxy
removed '/usr/local/sbin/haproxy'
'haproxy' -> '/usr/local/sbin/haproxy'
removed '/usr/local/share/man/man1/haproxy.1'
'doc/haproxy.1' -> '/usr/local/share/man/man1/haproxy.1'
removed '/usr/local/doc/haproxy/configuration.txt'
'doc/configuration.txt' -> '/usr/local/doc/haproxy/configuration.txt'
removed '/usr/local/doc/haproxy/management.txt'
'doc/management.txt' -> '/usr/local/doc/haproxy/management.txt'
removed '/usr/local/doc/haproxy/proxy-protocol.txt'
'doc/proxy-protocol.txt' -> '/usr/local/doc/haproxy/proxy-protocol.txt'
removed '/usr/local/doc/haproxy/seamless_reload.txt'
'doc/seamless_reload.txt' -> '/usr/local/doc/haproxy/seamless_reload.txt'
removed '/usr/local/doc/haproxy/architecture.txt'
'doc/architecture.txt' -> '/usr/local/doc/haproxy/architecture.txt'
removed '/usr/local/doc/haproxy/peers-v2.0.txt'
'doc/peers-v2.0.txt' -> '/usr/local/doc/haproxy/peers-v2.0.txt'
removed '/usr/local/doc/haproxy/regression-testing.txt'
'doc/regression-testing.txt' -> '/usr/local/doc/haproxy/regression-testing.txt'
removed '/usr/local/doc/haproxy/cookie-options.txt'
'doc/cookie-options.txt' -> '/usr/local/doc/haproxy/cookie-options.txt'
removed '/usr/local/doc/haproxy/lua.txt'
'doc/lua.txt' -> '/usr/local/doc/haproxy/lua.txt'
removed '/usr/local/doc/haproxy/WURFL-device-detection.txt'
'doc/WURFL-device-detection.txt' -> '/usr/local/doc/haproxy/WURFL-device-detection.txt'
removed '/usr/local/doc/haproxy/linux-syn-cookies.txt'
'doc/linux-syn-cookies.txt' -> '/usr/local/doc/haproxy/linux-syn-cookies.txt'
removed '/usr/local/doc/haproxy/SOCKS4.protocol.txt'
'doc/SOCKS4.protocol.txt' -> '/usr/local/doc/haproxy/SOCKS4.protocol.txt'
removed '/usr/local/doc/haproxy/network-namespaces.txt'
'doc/network-namespaces.txt' -> '/usr/local/doc/haproxy/network-namespaces.txt'
removed '/usr/local/doc/haproxy/DeviceAtlas-device-detection.txt'
'doc/DeviceAtlas-device-detection.txt' -> '/usr/local/doc/haproxy/DeviceAtlas-device-detection.txt'
removed '/usr/local/doc/haproxy/51Degrees-device-detection.txt'
'doc/51Degrees-device-detection.txt' -> '/usr/local/doc/haproxy/51Degrees-device-detection.txt'
removed '/usr/local/doc/haproxy/netscaler-client-ip-insertion-protocol.txt'
'doc/netscaler-client-ip-insertion-protocol.txt' -> '/usr/local/doc/haproxy/netscaler-client-ip-insertion-protocol.txt'
removed '/usr/local/doc/haproxy/peers.txt'
'doc/peers.txt' -> '/usr/local/doc/haproxy/peers.txt'
removed '/usr/local/doc/haproxy/close-options.txt'
'doc/close-options.txt' -> '/usr/local/doc/haproxy/close-options.txt'
removed '/usr/local/doc/haproxy/SPOE.txt'
'doc/SPOE.txt' -> '/usr/local/doc/haproxy/SPOE.txt'
removed '/usr/local/doc/haproxy/intro.txt'
'doc/intro.txt' -> '/usr/local/doc/haproxy/intro.txt'
sed -e 's:@SBINDIR@:'/usr/local/sbin':' haproxy.service.in > haproxy.service
As you can see from the top-most lines, this includes the binary. Why is being deleted, or is that the old one?
EDIT: It still isn't working. I should have been clearer, sorry
