S10
Posts: 23 Joined: Wed Oct 31, 2018 7:06 pm
Post
by S10 » Fri Jun 05, 2020 4:53 pm
It seems im running kernel 4.14.176+
root@DietPi:~# uname -a
Linux DietPi 4.14.176+ #1 SMP PREEMPT Tue Apr 14 20:02:49 UTC 2020 armv7l GNU/Linux
root@DietPi:/lib/modules/4.14.176+# ls
build modules.alias modules.builtin modules.dep modules.devname modules.softdep modules.symbols.bin
kernel modules.alias.bin modules.builtin.bin modules.dep.bin modules.order modules.symbols
Dont know why the directory /lib/modules/4.14.180+ is present, i think i did messed up the kernel upgrade, and am still running 4.14.176+, but the modules were deleted.
Posts: 3688 Joined: Sat Nov 16, 2019 12:49 am
Post
by Joulinar » Fri Jun 05, 2020 5:01 pm
Well you could run apt update to check if there are new packages available.
