Odroid C4 Topic is solved
AxelRHD
Re: Odroid C4
Post by AxelRHD »
Thank you. Works like a charm. :) So, Raspbian is also no own OS or distributian. It's just Debian. ;)
Re: Odroid C4
At least Raspbian is an own APT repository. But yeah it's nearly a 100% copy simply build for armv6hf instead of armv7hf + the other architectures that Debian supports.
So yes DietPi is build up onto the Raspbian repository for RPi and on the Debian repository for all other devices.
Re: Odroid C4
which will change with upcoming Raspi OS 64bit where RPi Foundation will switch to standard Debian repository. Isn't it?
Re: Odroid C4
Exactly, although it runs only on RPi 2 v1.2 and up, so RPi Zero, RPi 1 and my RPi 2 v1.1 need to stay on Raspbian :(.
I was thinking of creating a Debian-based ARMv7 image to use on RPi 2 v1.1 (and up, if for some reason x64 is not wanted/possible), the only real ARMv7 RPi model. There should be minor benefits, e.g. ARMv7 binaries are usually a bid smaller compared to ARMv6 binaries due to thumb-2: https://kmittal82.wordpress.com/2012/02 ... mbthumb-2/
This means in theory faster loading, fewer memory/cache usage. Additionally Debian repo means slightly faster package updates, security+updates+backports suites and when an issue occurs, we don't need to test on Debian first to rule out a Raspbian build issue ;).
