according official Raspberry documentation, it's still not released for RPi4
https://www.raspberrypi.org/documentati ... des/msd.md
https://www.raspberrypi.org/documentati ... teeprom.md
Pi4: DietPi on sole external SSD Topic is solved
Re: Pi4: DietPi on sole external SSD
Oh - I was under the impression its out of Beta status as when you switch the config to 'stable' its installable.
Note that likely you need to update the EEPROM itself as well before you can do the USB boot, e.g. via dietpi-config > Advanced Options. I also though it was already possible with current version, probably I mixed it up while investigating the new 5.4 kernel in pipeline. Can't check, GitHub is down
After updating your EEPROM you might want to test the new 64-bit alpha image: https://dietpi.com/downloads/images/tes ... -Buster.7z
Some RPi specials might not yet work, beta state as well from RPi Foundation side, but many mid- and long-term benefits over 32-bit Raspbian-based image I expect
that's the latest status
2020-06-17 Promote 2020-06-15 to STABLE
- Promote the latest beta EEPROM and recovery.bin to stable and feature freeze USB MSD support until a production release is ready.
