WireGuard Update failes Topic is solved
Re: WireGuard Update failes
and did you checked the log file??
Consult /var/lib/dkms/wireguard/1.0.20200506/build/make.log for more information.
Niwre
Post by Niwre »
@Joulinar
Here is the content from the log file
DKMS make.log for wireguard-1.0.20200506 for kernel 4.9.0-9-amd64 (x86_64)
Di 19. Mai 19:45:22 BST 2020
make: Verzeichnis „/usr/src/linux-headers-4.9.0-9-amd64“ wird betreten
LD /var/lib/dkms/wireguard/1.0.20200506/build/built-in.o
CC [M] /var/lib/dkms/wireguard/1.0.20200506/build/main.o
CC [M] /var/lib/dkms/wireguard/1.0.20200506/build/noise.o
CC [M] /var/lib/dkms/wireguard/1.0.20200506/build/device.o
CC [M] /var/lib/dkms/wireguard/1.0.20200506/build/peer.o
CC [M] /var/lib/dkms/wireguard/1.0.20200506/build/timers.o
CC [M] /var/lib/dkms/wireguard/1.0.20200506/build/queueing.o
CC [M] /var/lib/dkms/wireguard/1.0.20200506/build/send.o
CC [M] /var/lib/dkms/wireguard/1.0.20200506/build/receive.o
CC [M] /var/lib/dkms/wireguard/1.0.20200506/build/socket.o
CC [M] /var/lib/dkms/wireguard/1.0.20200506/build/peerlookup.o
CC [M] /var/lib/dkms/wireguard/1.0.20200506/build/allowedips.o
CC [M] /var/lib/dkms/wireguard/1.0.20200506/build/ratelimiter.o
/var/lib/dkms/wireguard/1.0.20200506/build/ratelimiter.c:25:8: error: unknown type name ‘hsiphash_key_t’
static hsiphash_key_t key;
/var/lib/dkms/wireguard/1.0.20200506/build/ratelimiter.c: In function ‘wg_ratelimiter_allow’:
/var/lib/dkms/wireguard/1.0.20200506/build/ratelimiter.c:109:22: error: implicit declaration of function ‘hsiphash_2u32’ [-Werror=implicit-function-declaration]
bucket = &table_v4[hsiphash_2u32(net_word, ip, &key) &
/var/lib/dkms/wireguard/1.0.20200506/build/ratelimiter.c:116:22: error: implicit declaration of function ‘hsiphash_3u32’ [-Werror=implicit-function-declaration]
bucket = &table_v6[hsiphash_3u32(net_word, ip >> 32, ip, &key) &
cc1: some warnings being treated as errors
/usr/src/linux-headers-4.9.0-9-common/scripts/Makefile.build:309: die Regel für Ziel „/var/lib/dkms/wireguard/1.0.20200506/build/ratelimiter.o“ scheiterte
make[3]: *** [/var/lib/dkms/wireguard/1.0.20200506/build/ratelimiter.o] Fehler 1
/usr/src/linux-headers-4.9.0-9-common/Makefile:1544: die Regel für Ziel „_module_/var/lib/dkms/wireguard/1.0.20200506/build“ scheiterte
make[2]: *** [_module_/var/lib/dkms/wireguard/1.0.20200506/build] Fehler 2
Makefile:152: die Regel für Ziel „sub-make“ scheiterte
make[1]: *** [sub-make] Fehler 2
Makefile:8: die Regel für Ziel „all“ scheiterte
make: *** [all] Fehler 2
make: Verzeichnis „/usr/src/linux-headers-4.9.0-9-amd64“ wird verlassen
ok found a similar report on the web fitting yours
https://bugs.debian.org/cgi-bin/bugrepo ... bug=935134
it's not the same version of wireguard but fitting your kernel 4.9.0-9-amd64.
EDIT: your kernel seems not the latest one. On my test system I can see 4.9.0-12-amd64
root@DietPiVM3:~# uname -a
Linux DietPiVM3 4.9.0-12-amd64 #1 SMP Debian 4.9.210-1 (2020-01-20) x86_64 GNU/Linux
root@DietPiVM3:~#
Niwre
Post by Niwre »
@Joulinar
That seems to be the problem, but what can I do now? I don't really understand the linked post.
 root@WireGuardPi:~# uname -a
Linux WireGuardPi 4.9.0-9-amd64 #1 SMP Debian 4.9.168-1+deb9u5 (2019-08-11) x86_64 GNU/Linux
I guess you would need to update your kernel. Usually this should happen automatically by running apt update && apt upgrade
I assume you are running debian Stretch. Correct?
Niwre
Post by Niwre »
@Joulinar
Yes, I'm on Debian Stretch. I tried again with apt update && apt upgrade, unfortunately the kernel is not updated.
are you running a VM or physical box? Just as interest because I see x86?
What else you are running on your system? Anything in addition?
Niwre
Post by Niwre »
@Joulinar
I use a VM on an ESXi 6.0, the VM is only used for WireGuard.
ok in this case, I would recommend to create a new VM on Buster as Stretch is the old Debian version. It will be much faster and shorter instead of figuring out what happen and why the kernel did not update. Next to this Buster is more future proof than continue running Stretch. ;)
You just would need to safe your configs on /etc/wireguard. Once you finished setup and installation on the new Buster systems, simply copy back the files and restart wireguard. I did the same in the past and it was working quite well.
Niwre
Post by Niwre »
@Joulinar
Is there a finished image for Debian Buster as a VM that I can use as a basis for it?
