Next(cloud) error off the rank
Re: Next(cloud) error off the rank
ok I did a test installation with PiHole and NextCloud. Both are working fine. So there seems to be something on your config
http://192.168.20.19/admin is working for your?
http://192.168.20.19/nextcloud is not working correct?
and what about http://192.168.20.19/phpinfo.php
lighttpd error log can be found at /var/log/lighttpd/error.log
can you check witch config files are active
/etc/lighttpd/conf-enabled
and let's check how document root for your web server looks like
ls -la /var/www/
Deleted User 7758
Post by Deleted User 7758 »
Hi @Joulinar,
Thank you for your ongoing help.
Link to PDF of full phpinfo() output
https://app.box.com/s/yz75x8bav4mhb78beb68hmus35zvfojz
this is an empty file
jon@Odroid:~$ /etc/lighttpd/conf-enabled
-bash: /etc/lighttpd/conf-enabled: Is a directory
jon@Odroid:~$ cd /etc/lighttpd/conf-enabled
jon@Odroid:/etc/lighttpd/conf-enabled$ ls -al
total 8
drwxr-xr-x 2 root root 4096 May 11 22:50 .
drwxr-xr-x 4 root root 4096 May 11 17:43 ..
lrwxrwxrwx 1 root root   33 May 11 17:43 10-fastcgi.conf -> ../conf-available/10-fastcgi.conf
lrwxrwxrwx 1 root root   33 May 11 22:50 10-rewrite.conf -> ../conf-available/10-rewrite.conf
lrwxrwxrwx 1 root root   37 May 11 17:43 15-fastcgi-php.conf -> ../conf-available/15-fastcgi-php.conf
lrwxrwxrwx 1 root root   45 May 11 22:50 99-dietpi-dav_redirect.conf -> ../conf-available/99-dietpi-dav_redirect.conf
lrwxrwxrwx 1 root root   42 May 11 22:50 99-dietpi-nextcloud.conf -> ../conf-available/99-dietpi-nextcloud.conf
lrwxrwxrwx 1 root root   58 May 11 17:47 99-dietpi-pihole-block_public_admin.conf -> ../conf-available/99-dietpi-pihole-block_public_admin.conf
lrwxrwxrwx 1 root root   39 May 11 17:43 99-dietpi-pihole.conf -> ../conf-available/99-dietpi-pihole.conf
lrwxrwxrwx 1 root root   38 May 11 17:37 99-unconfigured.conf -> ../conf-available/99-unconfigured.conf
jon@Odroid:/etc/lighttpd/conf-enabled$ ls -la /var/www/
total 84
drwxr-xr-x  4 root     root      4096 May 11 22:49 .
drwxr-xr-x 12 root     root      4096 May 11 11:17 ..
lrwxrwxrwx  1 root     root        10 May 11 17:47 admin -> html/admin
-rw-r--r--  1 root     root     37984 May 11 22:50 apc.php
drwxr-xr-x  4 root     root      4096 May 11 17:42 html
drwxr-xr-x 13 www-data www-data  4096 May 11 22:53 nextcloud
-rw-r--r--  1 root     root     22915 May 11 22:50 opcache.php
-rw-r--r--  1 root     root        20 May 11 22:50 phpinfo.php
lrwxrwxrwx  1 root     root        11 May 11 17:47 pihole -> html/pihole
Hope this helps
Jon
ok, web server seems to be fine. At least it's running. So indeed something wrong on the nextcloud installation. Can you check if all services are working fine
dietpi-services status
Deleted User 7758
ok, the response is
on@Odroid:~$ sudo dietpi-services status
[sudo] password for jon:
 DietPi-Services
 Mode: status
[  OK  ] DietPi-Services | redis-server		active (running) since Thu 2020-05-14 14:16:34 AEST; 1 day 7h ago
[FAILED] DietPi-Services | ● mariadb.service - MariaDB 10.3.22 database server
   Loaded: loaded (/lib/systemd/system/mariadb.service; disabled; vendor preset: enabled)
   Active: failed (Result: exit-code) since Thu 2020-05-14 14:16:38 AEST; 1 day 7h ago
     Docs: man:mysqld(8)
           https://mariadb.com/kb/en/library/systemd/
  Process: 667 ExecStartPre=/usr/bin/install -m 755 -o mysql -g root -d /var/run/mysqld (code=exited, status=0/SUCCESS)
  Process: 668 ExecStartPre=/bin/sh -c systemctl unset-environment _WSREP_START_POSITION (code=exited, status=0/SUCCESS)
  Process: 670 ExecStartPre=/bin/sh -c [ ! -e /usr/bin/galera_recovery ] && VAR= ||   VAR=`/usr/bin/galera_recovery`; [ $? -eq 0 ]   && systemctl set-environment _WSREP_START_POSITION=$VAR || exit 1 (code=exited, status=0/SUCCESS)
  Process: 727 ExecStart=/usr/sbin/mysqld $MYSQLD_OPTS $_WSREP_NEW_CLUSTER $_WSREP_START_POSITION (code=exited, status=1/FAILURE)
 Main PID: 727 (code=exited, status=1/FAILURE)
   Status: "MariaDB server is down"
May 14 14:16:34 Odroid systemd[1]: Starting MariaDB 10.3.22 database server...
May 14 14:16:35 Odroid mysqld[727]: 2020-05-14 14:16:35 0 [Note] /usr/sbin/mysqld (mysqld 10.3.22-MariaDB-0+deb10u1) starting as process 727 ...
May 14 14:16:38 Odroid systemd[1]: mariadb.service: Main process exited, code=exited, status=1/FAILURE
May 14 14:16:38 Odroid systemd[1]: mariadb.service: Failed with result 'exit-code'.
May 14 14:16:38 Odroid systemd[1]: Failed to start MariaDB 10.3.22 database server.
[  OK  ] DietPi-Services | php7.3-fpm		active (running) since Thu 2020-05-14 14:16:39 AEST; 1 day 7h ago
[  OK  ] DietPi-Services | lighttpd		active (running) since Thu 2020-05-14 14:16:40 AEST; 1 day 7h ago
[  OK  ] DietPi-Services | syncthing		active (running) since Thu 2020-05-14 14:16:40 AEST; 1 day 7h ago
[  OK  ] DietPi-Services | netdata		active (running) since Thu 2020-05-14 14:16:40 AEST; 1 day 7h ago
[  OK  ] DietPi-Services | cron			active (running) since Thu 2020-05-14 14:16:40 AEST; 1 day 7h ago
[  OK  ] DietPi-Services | ssh			active (running) since Thu 2020-05-14 14:16:34 AEST; 1 day 7h ago
[  OK  ] DietPi-Services | fail2ban		active (running) since Thu 2020-05-14 14:15:59 AEST; 1 day 7h ago
[  OK  ] DietPi-Services | pihole-FTL		active (running) since Thu 2020-05-14 14:15:59 AEST; 1 day 7h ago
[  OK  ] DietPi-Services | dietpi-ramlog	active (exited) since Thu 2020-05-14 14:15:58 AEST; 1 day 7h ago
[  OK  ] DietPi-Services | dietpi-preboot	active (exited) since Thu 2020-05-14 14:15:59 AEST; 1 day 7h ago
[  OK  ] DietPi-Services | dietpi-boot		active (exited) since Thu 2020-05-14 14:16:33 AEST; 1 day 7h ago
[  OK  ] DietPi-Services | dietpi-postboot	active (exited) since Thu 2020-05-14 14:16:34 AEST; 1 day 7h ago
[ INFO ] DietPi-Services | dietpi-wifi-monitor	inactive (dead)
ok your database is not running. Let's check what happen there. Pls restart your DB and check the error log
systemctl restart mariadb.service
journalctl -u mariadb
cat /var/log/mysql/error.log
Deleted User 7758
jon@Odroid:~$ sudo systemctl restart mariadb.service
Job for mariadb.service failed because the control process exited with error code.
See "systemctl status mariadb.service" and "journalctl -xe" for details.
what about
Deleted User 7758
jon@Odroid:~$ sudo journalctl -u mariadb
-- Logs begin at Thu 2020-05-14 14:15:54 AEST, end at Fri 2020-05-15 22:59:30 AEST. --
May 15 22:55:49 Odroid systemd[1]: Starting MariaDB 10.3.22 database server...
May 15 22:55:50 Odroid mysqld[9931]: 2020-05-15 22:55:50 0 [Note] /usr/sbin/mysqld (mysqld 10.3.22-MariaDB-0+deb10u1) starting as process 9931 ...
May 15 22:55:52 Odroid systemd[1]: mariadb.service: Main process exited, code=exited, status=1/FAILURE
May 15 22:55:52 Odroid systemd[1]: mariadb.service: Failed with result 'exit-code'.
May 15 22:55:52 Odroid systemd[1]: Failed to start MariaDB 10.3.22 database server.
Deleted User 7758
jon@Odroid:~$ sudo cat /var/log/mysql/error.log
2020-05-15 22:55:50 0 [Note] InnoDB: Using Linux native AIO
2020-05-15 22:55:50 0 [Note] InnoDB: Mutexes and rw_locks use GCC atomic builtins
2020-05-15 22:55:50 0 [Note] InnoDB: Uses event mutexes
2020-05-15 22:55:50 0 [Note] InnoDB: Compressed tables use zlib 1.2.11
2020-05-15 22:55:50 0 [Note] InnoDB: Number of pools: 1
2020-05-15 22:55:50 0 [Note] InnoDB: Using generic crc32 instructions
2020-05-15 22:55:50 0 [Note] InnoDB: Initializing buffer pool, total size = 128M, instances = 1, chunk size = 128M
2020-05-15 22:55:50 0 [Note] InnoDB: Completed initialization of buffer pool
2020-05-15 22:55:50 0 [Note] InnoDB: If the mysqld execution user is authorized, page cleaner thread priority can be changed. See the man page of setpriority().
2020-05-15 22:55:50 0 [Note] InnoDB: 128 out of 128 rollback segments are active.
2020-05-15 22:55:50 0 [Note] InnoDB: Creating shared tablespace for temporary tables
2020-05-15 22:55:50 0 [Note] InnoDB: Setting file './ibtmp1' size to 12 MB. Physically writing the file full; Please wait ...
2020-05-15 22:55:50 0 [Note] InnoDB: File './ibtmp1' size is now 12 MB.
2020-05-15 22:55:50 0 [Note] InnoDB: 10.3.22 started; log sequence number 17126069; transaction id 88068
2020-05-15 22:55:50 0 [Note] InnoDB: Loading buffer pool(s) from /mnt/dietpi_userdata/mysql/ib_buffer_pool
2020-05-15 22:55:50 0 [Note] Plugin 'FEEDBACK' is disabled.
2020-05-15 22:55:50 0 [Note] Recovering after a crash using tc.log
2020-05-15 22:55:50 0 [ERROR] Bad magic header in tc log
2020-05-15 22:55:50 0 [ERROR] Crash recovery failed. Either correct the problem (if it's, for example, out of memory error) and restart, or delete tc log and start mysqld with --tc-heuristic-recover={commit|rollback}
2020-05-15 22:55:50 0 [ERROR] Can't init tc log
2020-05-15 22:55:50 0 [ERROR] Aborting
pls try following
sudo mv /var/lib/mysql/tc.log /var/lib/mysql/tc_bkp.log
