Hi everyone. If OMV has issues running on pi with DietPi, do you all have another solution? I am using Pi for a Plex server and want to be able to add media to the hard drives without unplugging the hard drives from pi manually, plugging them into PC, adding media, then plugging back into Pi.
Thanks.
Manual OpenMediaVault install Topic is solved
Re: Manual OpenMediaVault install
well you can setup SAMBA server on your RPi and copy the media files over network.
