Speed up Plex Transcoding on Raspberry
KamikazeePL
Re: Speed up Plex Transcoding on Raspberry
Post by KamikazeePL »
Will this work with Jellyfin?
Yes, it should work the same way, as long as you have sufficient physical RAM to hold all transcoding data. As fast as it swaps, the benefit is lost ;).
Not sure if the cache directory /mnt/dietpi_userdata/jellyfin/cache is used for transcoding as well? If so, that one can be set quite easily via /etc/default/jellyfin.
WarHawk
Post by WarHawk »
I also believe setting transcode directory to /dev/dri points the transcode directory to a temp directory in RAM
I also recommend using ZRAM to help compress if/when needed
Cool that it does help...if you don't have alot of RAM it definitely bogs things down
No, /dev/dri contains the DRM interfaces, and is not a place for volatile files. Either something below /tmp or /run or a dedicated tmpfs should be used. In case of /run, the size needs to be increased as it is only 512 MiB.
Indeed a zram swap space can help if it prevents the need to use a swap file. But it slows down RAM usage as well when used. So as long as the physical memory is sufficient, I'd skip zram. If it's getting close, I can show how to switch to a zram swap space with our tools.
KamikazeePL
MichaIng wrote: Tue Aug 31, 2021 12:21 am Indeed a zram swap space can help if it prevents the need to use a swap file. But it slows down RAM usage as well when used. So as long as the physical memory is sufficient, I'd skip zram. If it's getting close, I can show how to switch to a zram swap space with our tools.
Show how to use zram.
to get it activated, you could run following
/boot/dietpi/func/dietpi-set_swapfile 1 zram
The 1 btw means auto-sized here, in which case the zram space will be 50% of the physical memory in size. This means max 50% of the physical memory can be consumed for the swap space. Due to compression, practically it will only consume ~25% of the physical RAM (highly depending on the type of the swapped data), increasing your overall available memory space (compared to no swap space) to around 1.25x.
