Rtorrent not working
vorrac
Re: Rtorrent not working
Post by vorrac »
It didn’t work, tried port forwarding, DMZ, edit the .rtorrent like the video. Unfortunately it didn’t work. I’m using a tp-link eifi mesh router and it created a sub network with different ips. I don’t know if this is the problem, woll try connecting odroid directly to ISP modem/router.
vorrac
Post by vorrac »
It’s not working. I’ve tried everything I know. :cry:
What does the WebUi tells if you move your mouse over the red bubble?
For me it's like this
and once I open the port on my router, it will be set to green (after refresh the status)
vorrac
Post by vorrac »
Exactly the same thing as the first image.
Hey guys, many thanks for reporting and debugging the issue. Indeed there was a bug our side where we set max memory allocation without adding an "M" for MiB, so I guess the effective value is in KiB now which is of course much too low. Fix is up: https://github.com/MichaIng/DietPi/pull/3531
We'll as well hack this inside v6.30 systems via MOTD, to prevent future users from running into this, until v6.31 release.
Now I am not sure how DHT is related. Probably because it simply requires additional allocated memory. Could you guys try to leave DHT enabled after fixing the max memory string by adding a "M"? Maintaining a "distributed hash table" for trackerless torrents by default makes rTorrent more compatible without the need for user action. Not sure how well "auto" handles it, but of course, if keeping it enabled causes still issues, we'll revert to "auto".
vorrac
Post by vorrac »
MichaIng wrote: Tue May 12, 2020 11:42 am Hey guys, many thanks for reporting and debugging the issue. Indeed there was a bug our side where we set max memory allocation without adding an "M" for MiB, so I guess the effective value is in KiB now which is of course much too low. Fix is up: https://github.com/MichaIng/DietPi/pull/3531
I've reinstalled everything and tried. I had to change DHT to auto otherwise rtorrent wouldn't start, giving an invalid argument error.
Ah lol, indeed "enable" is not a valid value, "on" is instead: https://github.com/rakshasa/rtorrent/bl ... c#L99-L104
