I am also having major Sonarr failure after recent upgrade to v6.29.2 (I'm glad to see it's not just me, because I had checked some Sonarr specific forums (so many different OS) and no one seems to be having new issues in the past couple weeks).
I find often that Sonarr is no longer running and I must manually start it. When I reboot the whole device, sonarr no longer starts automatically and I must start it manually.
When I go to Add Series and search for something (very common that should have easy results) I get:
New media isn't being grabbed, and when I manually search for an item Sonarr crashes (I can watch it disappear in htop).
. Here is a snippet of the log file:
[v2.0.0.5343] System.Net.WebException: Error: ConnectFailure (Connection refused): 'http://skyhook.sonarr.tv/v1/tvdb/shows/en/296762' ---> System.Net.WebException: Error: ConnectFailure (Connection refused) ---> System.Net.Sockets.SocketException: Connection refused
at System.Net.Sockets.SocketAsyncResult.CheckIfThrowDelayedException () [0x00014] in <4bf78e13a6ea4494a3898e6a836a77f4>:0
at System.Net.Sockets.Socket.EndConnect (System.IAsyncResult asyncResult) [0x0002c] in <4bf78e13a6ea4494a3898e6a836a77f4>:0
at System.Net.WebConnection+<>c.<Connect>b__16_1 (System.IAsyncResult asyncResult) [0x00006] in <4bf78e13a6ea4494a3898e6a836a77f4>:0
at System.Threading.Tasks.TaskFactory`1[TResult].FromAsyncCoreLogic (System.IAsyncResult iar, System.Func`2[T,TResult] endFunction, System.Action`1[T] endAction, System.Threading.Tasks.Task`1[TResult] promise, System.Boolean requiresSynchronization) [0x00019] in <a1ae6166591d4020b810288d19af38d4>:0
--- End of stack trace from previous location where exception was thrown ---
at System.Net.WebConnection.Connect (System.Net.WebOperation operation, System.Threading.CancellationToken cancellationToken) [0x001e1] in <4bf78e13a6ea4494a3898e6a836a77f4>:0
--- End of inner exception stack trace ---
at System.Net.WebConnection.Connect (System.Net.WebOperation operation, System.Threading.CancellationToken cancellationToken) [0x0025d] in <4bf78e13a6ea4494a3898e6a836a77f4>:0
at System.Net.WebConnection.InitConnection (System.Net.WebOperation operation, System.Threading.CancellationToken cancellationToken) [0x000cc] in <4bf78e13a6ea4494a3898e6a836a77f4>:0
at System.Net.WebOperation.Run () [0x0009a] in <4bf78e13a6ea4494a3898e6a836a77f4>:0
at System.Net.WebCompletionSource`1[T].WaitForCompletion () [0x00094] in <4bf78e13a6ea4494a3898e6a836a77f4>:0
at System.Net.HttpWebRequest.RunWithTimeoutWorker[T] (System.Threading.Tasks.Task`1[TResult] workerTask, System.Int32 timeout, System.Action abort, System.Func`1[TResult] aborted, System.Threading.CancellationTokenSource cts) [0x000f8] in <4bf78e13a6ea4494a3898e6a836a77f4>:0
at System.Net.HttpWebRequest.GetResponse () [0x00016] in <4bf78e13a6ea4494a3898e6a836a77f4>:0
at NzbDrone.Common.Http.Dispatchers.ManagedHttpDispatcher.GetResponse (NzbDrone.Common.Http.HttpRequest request, System.Net.CookieContainer cookies) [0x0011b] in <37ab5d62b2134492ad4c99dc85a1751a>:0
at NzbDrone.Common.Http.Dispatchers.ManagedHttpDispatcher.GetResponse (NzbDrone.Common.Http.HttpRequest request, System.Net.CookieContainer cookies) [0x001f6] in <37ab5d62b2134492ad4c99dc85a1751a>:0
at NzbDrone.Common.Http.Dispatchers.FallbackHttpDispatcher.GetResponse (NzbDrone.Common.Http.HttpRequest request, System.Net.CookieContainer cookies) [0x000b5] in <37ab5d62b2134492ad4c99dc85a1751a>:0
at NzbDrone.Common.Http.HttpClient.ExecuteRequest (NzbDrone.Common.Http.HttpRequest request, System.Net.CookieContainer cookieContainer) [0x0007e] in <37ab5d62b2134492ad4c99dc85a1751a>:0
at NzbDrone.Common.Http.HttpClient.Execute (NzbDrone.Common.Http.HttpRequest request) [0x00008] in <37ab5d62b2134492ad4c99dc85a1751a>:0
at NzbDrone.Common.Http.HttpClient.Get (NzbDrone.Common.Http.HttpRequest request) [0x00007] in <37ab5d62b2134492ad4c99dc85a1751a>:0
at NzbDrone.Common.Http.HttpClient.Get[T] (NzbDrone.Common.Http.HttpRequest request) [0x00000] in <37ab5d62b2134492ad4c99dc85a1751a>:0
at NzbDrone.Core.MetadataSource.SkyHook.SkyHookProxy.GetSeriesInfo (System.Int32 tvdbSeriesId) [0x0003b] in <9081a6c8cc0e4467aeb72782609f2deb>:0
at NzbDrone.Core.Tv.RefreshSeriesService.RefreshSeriesInfo (NzbDrone.Core.Tv.Series series) [0x0002b] in <9081a6c8cc0e4467aeb72782609f2deb>:0
at NzbDrone.Core.Tv.RefreshSeriesService.Execute (NzbDrone.Core.Tv.Commands.RefreshSeriesCommand message) [0x000d2] in <9081a6c8cc0e4467aeb72782609f2deb>:0
20-5-9 14:18:35.1|Info|DiskScanService|Scanning disk for Westworld
20-5-9 14:18:35.2|Info|DiskScanService|Completed scanning disk for Westworld
20-5-9 14:18:35.2|Info|ExistingMetadataImporter|Found 0 existing metadata files
20-5-9 14:18:35.2|Info|ExistingSubtitleImporter|Found 0 existing subtitle files
20-5-9 14:18:35.3|Info|ExistingOtherExtraImporter|Found 0 existing other extra files
20-5-9 14:18:35.3|Info|ExistingExtraFileService|Found 0 extra files
20-5-9 14:18:39.3|Info|NzbSearchService|Searching 5 indexers for [Shark Tank : S11E21]
20-5-9 14:19:28.6|Info|Bootstrap|Starting Sonarr - /opt/NzbDrone/NzbDrone.exe - Version 2.0.0.5343
20-5-9 14:19:29.9|Info|AppFolderInfo|Data directory is being overridden to [/mnt/dietpi_userdata/sonarr]
20-5-9 14:19:30.6|Info|Router|Application mode: Interactive
20-5-9 14:19:31.2|Info|MigrationLogger|*** Migrating data source=/mnt/dietpi_userdata/sonarr/nzbdrone.db;cache size=-10000;datetimekind=Utc;journal mode=Wal;pooling=True;version=3 ***
20-5-9 14:19:31.9|Info|MigrationLogger|*** Migrating data source=/mnt/dietpi_userdata/sonarr/logs.db;cache size=-10000;datetimekind=Utc;journal mode=Wal;pooling=True;version=3 ***
20-5-9 14:19:31.9|Info|OwinHostController|Listening on the following URLs:
20-5-9 14:19:32.0|Info|OwinHostController| http://*:8989/
20-5-9 14:19:32.0|Info|OwinHostController| https://*:9898/
20-5-9 14:19:32.4|Info|NancyBootstrapper|Starting Web Server
20-5-9 14:19:36.8|Warn|MonoDebugCheck|Mono is not running with --debug switch
20-5-9 14:19:38.9|Error|ProxyCheck|Proxy Health Check failed
[v2.0.0.5343] System.Net.WebException: Error: ConnectFailure (Connection refused): 'http://services.sonarr.tv/v1/ping' ---> System.Net.WebException: Error: ConnectFailure (Connection refused) ---> System.Net.Sockets.SocketException: Connection refused
at NzbDrone.Core.HealthCheck.Checks.ProxyCheck.Check () [0x00065] in <9081a6c8cc0e4467aeb72782609f2deb>:0
20-5-9 14:19:44.4|Error|TaskExtensions|Task Error
[v2.0.0.5343] System.Net.WebException: Error: ConnectFailure (Connection refused): 'http://services.sonarr.tv/v1/update/master?version=2.0.0.5343&os=linux&runtimeVer=6.8.0.105&active=true' ---> System.Net.WebException: Error: ConnectFailure (Connection refused) ---> System.Net.Sockets.SocketException: Connection refused
at NzbDrone.Core.Update.UpdatePackageProvider.GetLatestUpdate (System.String branch, System.Version currentVersion) [0x000a5] in <9081a6c8cc0e4467aeb72782609f2deb>:0
at NzbDrone.Core.Update.CheckUpdateService.AvailableUpdate () [0x00016] in <9081a6c8cc0e4467aeb72782609f2deb>:0
at NzbDrone.Core.HealthCheck.Checks.UpdateCheck.Check () [0x000f7] in <9081a6c8cc0e4467aeb72782609f2deb>:0
at NzbDrone.Core.HealthCheck.HealthCheckService+<>c.<PerformHealthCheck>b__11_0 (NzbDrone.Core.HealthCheck.IProvideHealthCheck c) [0x00000] in <9081a6c8cc0e4467aeb72782609f2deb>:0
at System.Linq.Enumerable+SelectArrayIterator`2[TSource,TResult].ToList () [0x00014] in <59093ef301a24e5a91cb0295fb832cca>:0
at System.Linq.Enumerable.ToList[TSource] (System.Collections.Generic.IEnumerable`1[T] source) [0x0001f] in <59093ef301a24e5a91cb0295fb832cca>:0
at NzbDrone.Core.HealthCheck.HealthCheckService.PerformHealthCheck (NzbDrone.Core.HealthCheck.IProvideHealthCheck[] healthChecks) [0x00025] in <9081a6c8cc0e4467aeb72782609f2deb>:0
at NzbDrone.Core.HealthCheck.HealthCheckService.HandleAsync (NzbDrone.Core.Lifecycle.ApplicationStartedEvent message) [0x00000] in <9081a6c8cc0e4467aeb72782609f2deb>:0
at NzbDrone.Core.Messaging.Events.EventAggregator+<>c__DisplayClass6_2`1[TEvent].<PublishEvent>b__1 () [0x00035] in <9081a6c8cc0e4467aeb72782609f2deb>:0
at System.Threading.Tasks.Task.InnerInvoke () [0x0000f] in <a1ae6166591d4020b810288d19af38d4>:0
at System.Threading.Tasks.Task.Execute () [0x00000] in <a1ae6166591d4020b810288d19af38d4>:0
20-5-9 14:20:07.1|Info|NzbSearchService|Searching 5 indexers for [Shark Tank : S11E21]
20-5-9 14:22:04.0|Info|Bootstrap|Starting Sonarr - /opt/NzbDrone/NzbDrone.exe - Version 2.0.0.5343
20-5-9 14:22:05.4|Info|AppFolderInfo|Data directory is being overridden to [/mnt/dietpi_userdata/sonarr]
20-5-9 14:22:06.1|Info|Router|Application mode: Interactive
20-5-9 14:22:06.7|Info|MigrationLogger|*** Migrating data source=/mnt/dietpi_userdata/sonarr/nzbdrone.db;cache size=-10000;datetimekind=Utc;journal mode=Wal;pooling=True;version=3 ***
20-5-9 14:22:07.3|Info|MigrationLogger|*** Migrating data source=/mnt/dietpi_userdata/sonarr/logs.db;cache size=-10000;datetimekind=Utc;journal mode=Wal;pooling=True;version=3 ***
20-5-9 14:22:07.4|Info|OwinHostController|Listening on the following URLs:
20-5-9 14:22:07.4|Info|OwinHostController| http://*:8989/
20-5-9 14:22:07.4|Info|OwinHostController| https://*:9898/
20-5-9 14:22:07.9|Info|NancyBootstrapper|Starting Web Server
20-5-9 14:22:12.1|Warn|MonoDebugCheck|Mono is not running with --debug switch
20-5-9 14:22:14.2|Error|ProxyCheck|Proxy Health Check failed
20-5-9 14:22:14.8|Error|TaskExtensions|Task Error
20-5-9 14:22:41.2|Info|BackupService|Starting Backup
20-5-9 14:23:01.4|Info|NzbSearchService|Searching 5 indexers for [Shark Tank : S11E21]
20-5-9 14:23:35.2|Info|Bootstrap|Starting Sonarr - /opt/NzbDrone/NzbDrone.exe - Version 2.0.0.5343
20-5-9 14:23:36.6|Info|AppFolderInfo|Data directory is being overridden to [/mnt/dietpi_userdata/sonarr]
20-5-9 14:23:37.4|Info|Router|Application mode: Interactive
20-5-9 14:23:37.9|Info|MigrationLogger|*** Migrating data source=/mnt/dietpi_userdata/sonarr/nzbdrone.db;cache size=-10000;datetimekind=Utc;journal mode=Wal;pooling=True;version=3 ***
20-5-9 14:23:38.5|Info|MigrationLogger|*** Migrating data source=/mnt/dietpi_userdata/sonarr/logs.db;cache size=-10000;datetimekind=Utc;journal mode=Wal;pooling=True;version=3 ***
20-5-9 14:23:38.7|Info|OwinHostController|Listening on the following URLs:
20-5-9 14:23:38.7|Info|OwinHostController| http://*:8989/
20-5-9 14:23:38.7|Info|OwinHostController| https://*:9898/
20-5-9 14:23:39.1|Info|NancyBootstrapper|Starting Web Server
20-5-9 14:23:43.3|Warn|MonoDebugCheck|Mono is not running with --debug switch
20-5-9 14:23:45.6|Error|ProxyCheck|Proxy Health Check failed
20-5-9 14:23:51.0|Error|TaskExtensions|Task Error
20-5-9 14:23:55.4|Warn|SkyHookProxy|Error: ConnectFailure (Connection refused): 'http://skyhook.sonarr.tv/v1/tvdb/search/en/?term=simpsons'
[v2.0.0.5343] System.Net.WebException: Error: ConnectFailure (Connection refused): 'http://skyhook.sonarr.tv/v1/tvdb/search/en/?term=simpsons' ---> System.Net.WebException: Error: ConnectFailure (Connection refused) ---> System.Net.Sockets.SocketException: Connection refused
at NzbDrone.Core.MetadataSource.SkyHook.SkyHookProxy.SearchForNewSeries (System.String title) [0x000d3] in <9081a6c8cc0e4467aeb72782609f2deb>:0
