RootFS is currently Read Only (R/O) mounted. Aborting... Topic is solved
Re: RootFS is currently Read Only (R/O) mounted. Aborting...
Guys, pls follow the GitHub post linked above.
stephen6
Post by stephen6 »
Thanks Joulinar, workaround detailed in https://github.com/MichaIng/DietPi/issu ... -624525544 fixed the issue.
LeVraiRoiDHyrule
RootFS is currently Read Only (R/O) mounted. Everything is blocked.
Post by LeVraiRoiDHyrule »
I'm new to dietpi. I have a problem that I don't understand, that is blocking my entire pi.
I was managing my external drives with Dietpi's Drive Manager, rebooted, and now I've got this :
https://imgur.com/a/pVaz6eu
Not a single software on my pi works now.
It tells me to run the drive manager, but I don't know what to do next :
https://imgur.com/a/SeVCIKo
I searched on the forums about the issue, found someone who sent a fix :
Ok, but how do I get my PartUUID ? I don't know how to apply the solution.
https://imgur.com/a/9l2qhcX
https://pastebin.com/Nhx8Zr4T
Here is my fstab file, I don't know how to manage it but as I understood it manages drives and partition, I guess is could help.
Everything is now blocked. How can I fix this ? Any help is welcome. If you need more details about something, you can ask. I'm new and don't know yet what would be needed to fix the issue. Have a good day
@LeVraiRoiDHyrule
do you transferred your rootFS to an external device or is it still located on your SD card.
LeVraiRoiDHyrule
It is still on my SD card. I didn't moved it.
I see you already in GitHub. pls continue there
LeVraiRoiDHyrule
To people seeing this later, go to https://github.com/MichaIng/DietPi/issues/3511 the solution is there.
majorkuso
Post by majorkuso »
I second the link to https://github.com/MichaIng/DietPi/issues/3511
also backup your fstab before using the drive manager.
to backup cp /etc/fstab /etc/fstab.bak
to restore cp /etc/fstab.bak /etc/fstab
don't forget to make rootFS writable before ;)
mount -o remount,rw /
PiTech
Post by PiTech »
I know it is not much but i made a simple youtube video following the github guide
https://youtu.be/cicFuF9-UNc
