can't connect Raspberry PI 3 to my PC through Ethernet Cable Topic is solved
kimura
Re: can't connect Raspberry PI 3 to my PC through Ethernet Cable
Post by kimura »
Ping 192.168.0.100
get : from 192.168.0.35 icmp_seq=1 destination Host unreachable
what is IP 192.168.0.35 about ??
kimura
Post by kimura »
Now Ping 192.168.0.100 successful
kimura
Post by kimura »
Now I can ssh into board, But it is failed when I do ping from board
kimura
Post by kimura »
Now I can ping to board from PC but I can't ping to PC from board
Does it means that the dietPI only allow one direction communication?
please advise
kimura
No response, when do ping from Raspberry PI to PC
Post by kimura »
I have Raspberry Pi connect to PC through the Ethernet cable.
After set the static IP for both side, I can ping (or ) SSH from PC to the board successfully.
The issue is that I can't ping from the board to PC. there is no response.
Using Whireshark tool, I can see the IP address of the board continue sending ping request to ip address of the PC without reply from PC
Please help
thanks in advance
Do you have any issues besides the fact that ping is not working from your board to the PC?
kimura
Post by kimura »
No other issue, Just can't ping from the board to PC
The problem is that there is no response from PC when I ping from the board to PC.
Using Wireshark, I can see the IP address of the board keep sending ping request to the IP address of the PC, no response from the PC
Please advise
Well if there are no other issues, it doesn't make sense to further investigate why ping is not working from your board to your PC. Next to it, you see packages arriving from the board on your PC but there are no packages are sent back. Means, in general connection is working. But is seems your PC is not answering on ICMP request. Therefore my guess, that something is blocking this on your PC. Maybe a Security Suite or something else.
donbrew
Post by donbrew »
Pretty amazing that nobody knows about the need for cross over cables. The reason you have one way access is because the PC probably has a gigabit (1000) ethernet adapter, the Pi 3 has a "fast" (10/100) ethernet adapter. If both machines have gigabit there is no need for a cross over cable.
