DietPi VNC Server Headless....head wrecked! Topic is solved
Re: DietPi VNC Server Headless....head wrecked!
So you have a network mount with specific permission attached to your DietPi system?
feardamhan
Post by feardamhan »
Yeah, ultimately I would like to have multiple users connect to the Pi and haver their own environment to work with.
well I'm not sure if vnc is the right solution because a vnc server has the permissions of the user who runs it. That means for each user you would need to ran an own instance of vncserver with an own display index. That would looks like this on process level
root@raspberrypi-emby:~# ps -ef |grep vnc
root       416     1  0 21:59 ?        00:00:00 /usr/bin/vncserver-x11-serviced -fg
root       418     1  0 21:59 ?        00:00:00 /usr/bin/vncserver-virtuald -fg
root       429   416  0 21:59 ?        00:00:00 /usr/bin/vncserver-x11-core -service
root       737     1  0 21:59 ?        00:00:00 /usr/bin/vncserver :1 -geometry 1280x720 -depth 16
dietpi     739     1  0 21:59 ?        00:00:00 /usr/bin/vncserver :2 -geometry 1280x720 -depth 16
root       742   737  0 21:59 ?        00:00:00 /usr/bin/Xvnc-core :1 -auth /root/.Xauthority -pn -geometry 1280x720 -depth 16
dietpi     743   739  0 21:59 ?        00:00:00 /usr/bin/Xvnc-core :2 -auth /home/dietpi/.Xauthority -pn -geometry 1280x720 -depth 16
root       744   743  0 21:59 ?        00:00:00 /usr/bin/Xvnc -rootHelper 1000 4
root       775   737  0 21:59 ?        00:00:00 /bin/sh /etc/vnc/xstartup
dietpi     776   739  0 21:59 ?        00:00:00 /bin/sh /etc/vnc/xstartup
root       800     1  0 21:59 ?        00:00:00 /usr/bin/vncserverui virtual 13
dietpi     809     1  0 21:59 ?        00:00:00 /usr/bin/vncserverui virtual 14
root       846   800  0 21:59 ?        00:00:00 /usr/bin/vncserverui -statusicon 5
dietpi     847   809  0 21:59 ?        00:00:00 /usr/bin/vncserverui -statusicon 5
root      1276  1204  0 22:00 pts/0    00:00:00 grep vnc
you see, user root is running usr/bin/vncserver :1 while user dietpi us running /usr/bin/vncserver :2
and finally you can connect to user dietpi environment by using <yourIP:2> on RealVNC client. see attached
feardamhan
That looks like a workable solution. Can you point me in the direction of configuration guidance for that?
you would need to double vncserver.service as well as dietpi vncserver config
/etc/systemd/system/vncserver.service
/usr/local/bin/vncserver
like this
root@raspberrypi-emby:~# ls -la /etc/systemd/system |grep vnc
-rw-r--r--  1 root root  319 Apr 30 21:41 vncserver2.service
-rw-r--r--  1 root root  308 Apr 29 15:10 vncserver.service
root@raspberrypi-emby:~# ls -la /usr/local/bin/
-rwxr-xr-x  1 root root 1838 Apr 29 15:10 vncserver
-rwxr-xr-x  1 root root 1840 Apr 30 21:42 vncserver2
that's the service file vncserver2.service
[Unit]
Description=Manage VNC Server (DietPi)
Before=xrdp.service xrdp-sesman.service
After=dietpi-boot.service
[Service]
RemainAfterExit=yes
User=dietpi
PAMName=login
Environment=HOME=/home/dietpi
ExecStart=/usr/local/bin/vncserver2 start
ExecStop=/usr/local/bin/vncserver2 stop
[Install]
WantedBy=multi-user.target
within vnc server config file /usr/local/bin/vncserver2 you would need to replace 2 times the following line at the bottom
DISPLAY=$(sed -n '/^[[:blank:]]*SOFTWARE_VNCSERVER_DISPLAY_INDEX=/{s/^[^=]*=//p;q}' /DietPi/dietpi.txt)
change it to
DISPLAY=2
and enable service for autostart
systemctl enable vncserver2.service
feardamhan
Magic. I’ll give that a go. Does that mean that to change the first vncserver config you would simply edit the first instance of both files and change to an alternate user?
theoretically yes, if you don't need a root instance. or you are going to deactivate the initial first vnc service and manage all users in their own separate files. this way you will keep the possibility to have a root instance if needed
feardamhan
worked perfectly for me. Thanks for all the help Joulinar! 👍
Your welcome. Good that we found a solution for your challenge.
just another option to play around would be using TigerVNC + xRDP. This will allow to use Windows RPD Client. Looks like it allows Multi-User scenario out of the box. 8)
