DietPi VNC Server Headless....head wrecked! Topic is solved
- feardamhan
Re: DietPi VNC Server Headless....head wrecked!
Tried that and ss -alnp | grep Xvnc-core still returns nada
but what is the output of the manual start? for me the last lines looks like this
Running applications in /root/.vnc/xstartup
VNC Server catchphrase: "Spider state mercury. Carrot diet Henry."
signature: 38-24-c0-46-a4-10-d0-34
Log file is /root/.vnc/DietPi3:1.log
New desktop is DietPi3:1 (192.168.0.12:1)
- feardamhan
'/usr/local/bin/vncserver start' does not appear to restart the vnc server service at all. Running it does not error out but it returns no output
yes that's correct. ths command did not restart the service. It will start the server manually only. Anyhow it should give anything back. For me it's quite a long output. Still something seems to be strange on your VNC installation. can you do ps -ef|grep vnc and post the entire output
- feardamhan
root@raspberrypi-emby:~# ps -ef|grep vnc
root 492 1 0 19:11 ? 00:00:00 /usr/bin/vncserver-x11-serviced -fg
root 494 1 0 19:11 ? 00:00:00 /usr/bin/vncserver-virtuald -fg
root 522 492 0 19:11 ? 00:00:00 /usr/bin/vncserver-x11-core -service
root 1029 949 0 19:12 pts/0 00:00:00 grep vnc
that's all?? I have way more processes running
Do you have a spare SD card and could do a fresh install? Something seems to be wrong
root@DietPi3:~# ps -ef|grep vnc
root 430 1 0 20:17 ? 00:00:00 /usr/bin/vncserver-x11-serviced -fg
root 433 1 0 20:17 ? 00:00:00 /usr/bin/vncserver-virtuald -fg
root 444 430 0 20:17 ? 00:00:00 /usr/bin/vncserver-x11-core -service
root 635 1 0 20:17 ? 00:00:00 /usr/bin/vncserver :1 -geometry 2160x1440 -depth 16
root 637 635 4 20:17 ? 00:00:00 /usr/bin/Xvnc-core :1 -auth /root/.Xauthority -pn -geometry 2160x1440 -depth 16
root 654 635 0 20:17 ? 00:00:00 /bin/sh /etc/vnc/xstartup
root 681 1 3 20:17 ? 00:00:00 /usr/bin/vncserverui virtual 13
root 695 681 1 20:17 ? 00:00:00 /usr/bin/vncserverui -statusicon 5
root 857 777 0 20:18 pts/0 00:00:00 grep vnc
root@DietPi3:~#
root@DietPi3:~#
- feardamhan
yup, thats all of it
This was a fresh install about 60 mins ago. Wiped the SD card, included the RealVNC installation in the dietpi.txt that was on the SD card before first boot. Literally nothing else done since.
The first install also includes
emby
mariadb
vim
samba client
syncthing
I might strip back the rest, and literally just do realVNC (and manually via dietpi-software) and see what happens, in case there is some weird issues during install.
emby
mariadb
vim
samba client
syncthing
Currently it looks like there is no xsession started for VNC
- feardamhan
Ok. So a fresh install, cutting the dietpi.txt for first boot to the bare bones of just the IP address required, plus a manual install of realVPN via dietpi-software, got my ps -ef | grep vnc to display this
Also 'ss -alnp | grep Xvnc-core' looks better
Still can't connect tho. Same error of 'Cannot currently show the desktop'
root@dietpi-server1:~# ps -ef | grep vnc
root 495 1 0 21:00 ? 00:00:00 /usr/bin/vncserver-virtuald -fg
root 504 1 0 21:00 ? 00:00:00 /usr/bin/vncserver-x11-serviced -fg
root 529 504 0 21:00 ? 00:00:00 /usr/bin/vncserver-x11-core -service
root 682 1 0 21:00 ? 00:00:00 /usr/bin/vncserver :1 -geometry 1280x720 -depth 16
root 684 682 0 21:00 ? 00:00:01 /usr/bin/Xvnc-core :1 -auth /root/.Xauthority -pn -geometry 1280x720 -depth 16
root 697 682 0 21:00 ? 00:00:00 /bin/sh /etc/vnc/xstartup
root 732 1 0 21:00 ? 00:00:00 /usr/bin/vncserverui virtual 15
root 755 732 0 21:00 ? 00:00:00 /usr/bin/vncserverui -statusicon 5
root 1260 1188 0 21:20 pts/0 00:00:00 grep vnc
u_str LISTEN 0 0 /tmp/.X11-unix/X1 15363 * 0 users:(("Xvnc-core",pid=684,fd=3))
u_str LISTEN 0 0 /tmp/.vnc-0/Xvnc.CtrlComms.1.0 15389 * 0 users:(("Xvnc-core",pid=684,fd=9))
tcp LISTEN 0 5 0.0.0.0:5901 0.0.0.0:* users:(("Xvnc-core",pid=684,fd=7))
tcp LISTEN 0 128 0.0.0.0:6001 0.0.0.0:* users:(("Xvnc-core",pid=684,fd=1))
tcp LISTEN 0 5 [::]:5901 [::]:* users:(("Xvnc-core",pid=684,fd=6))
tcp LISTEN 0 128 [::]:6001 [::]:* users:(("Xvnc-core",pid=684,fd=0))
Ok that looks good now. You should be able to connect using IP:1 or IP:5901. Thats the port the vnc is running on as you can see on your output above.
