Roon Server database destroyed on each update
AlfaGTV
Re: Roon Server database destroyed on each update
Post by AlfaGTV »
Sure, we can ask the support-team to outline the update process.
I suspect this behaviour might have something to do with DietPi's logging to ramdisk? I'm not sure what i'm talking about here, but DietPi made some change that would prevent corruption of the boot disk on sudden power loss. (Based on the lack of a power-button on most SBC's) Either that or some file access issues...
This is what is written on Roon install guide for logs
If you've customized $ROON_DATAROOT, then they will be located in $ROON_DATAROOT/RoonServer/Logs and $ROON_DATAROOT/RAATServer/Logs
means they should be located at /mnt/dietpi_userdata/roonserver
I quickly installed a Roon server on one of my Demo VM's and yes log file located there. Means on a physical device and not on a RamDisk
root@DietPiVM1:/mnt/dietpi_userdata/roonserver/RoonServer/Logs# ls -l
total 20
-rw-r--r-- 1 root root 19004 Apr 23 14:33 RoonServer_log.txt
root@DietPiVM1:/mnt/dietpi_userdata/roonserver/RoonServer/Logs# df -h .
/dev/sda1       9.8G  2.5G  6.9G  27% /
Are there any logs from update process that could be checked? At least to know what happen during update process.
AlfaGTV
Post by AlfaGTV »
Sorry, i had prepared myself to pull some logs from the update but i forgot to. And when i remembered my database was already gone/corrupted.
Does DietPi do anything else which is out of the ordinary concerning temporary data or user rights?
Personally, I don't think there is something special. As far as I have seen, Roon server is executed as user root and I would not expect issues on file permissions. But you never know. Therefore I would be good to get an understanding on the Roon update process and to have some update logs. Hopefully we than see what happen and went wrong during update. My guess is, that the update is going to copy data from A to B. Maybe there is something overwritten or not copied correctly??
AlfaGTV
Post by AlfaGTV »
Well, as it happens a second service release was published a few minutes ago.
The appropriate log should be attached now.
I plucked it from the dietpi users "roonserver" library, after the download was completed and I was urged to reboot the Roon Server.
Then I rebooted and noted that the three directories that are named Roon* in this picture was erased, and then returned:
As usual, my Roon Controls does not recognize the server after the reboot, it is to them a completely new Server instance.
But i followed my standard procedure, logged in (registered the Core with my account online) and accepted that it's database is completely empty.
I just go directly into Settings-Backup and them do a restore of my latest backup.
After the restore the Server requires one more reboot. This procedure does not take very long, about 45 minutes in total. (I had my backup drive already attached to the Server hardware)
Don't know if this makes any more sense?
And, I haven't got any feedback from the Roon crew with outlining the upgrade procedure.
RoonServer_log.txt.zip
(678.45 KiB) Downloaded 48 times
ok I had a look into youlog file. It seems the full server log. Luckily the update procedure is at the end. This seems to be the procedure
04/23 21:07:36 Info: [base/updater] Installing update
04/23 21:07:44 Info: [stats] 4799mb Virtual, 2431mb Physical, 1096mb Managed, 0 Handles, 82 Threads
04/23 21:07:46 Trace: [base/Roon updater script stdout] Install package is at: /tmp/20192b42-9aca-4c94-9aad-43ae02cff536__RoonServer_linuxx64_100700537.tar.bz2
04/23 21:07:46 Trace: [base/Roon updater script stdout] Installing to: /mnt/dietpi_userdata/roonserver
04/23 21:07:46 Trace: [base/Roon updater script stdout] Removing any old update...
04/23 21:07:46 Trace: [base/Roon updater script stdout] Untarring new install to /mnt/dietpi_userdata/roonserver/.update.tmp
Looks like it's going to remove the old installation and copy a new one in place. Maybe this is remove your config files as well if they are located in these directories that are removed by roon update process.
Aldoszx
Post by Aldoszx »
I have checked roon kb and found this, related to roon server database:
‘ Linux Core
If you used our "easy installer" scripts, then Roon's database is located in /var/roon/RoonServer
If you ran Roon from the .tar.gz package by executing ./start.sh without configuring the ROON_DATAROOT environment variable, then it will be in $HOME/.RoonServer
If you have configured $ROON_DATAROOT manually, then it will be in $ROON_DATAROOT/RoonServer’
In roonserver service on DietPi, we have this:
’Environment=ROON_DATAROOT=/mnt/dietpi_userdata/roonserver’
So, I suppose the database is rewritten on every update because of that.
I think the Roon_Dataroot should not be modified, and the database let to be on var/roon
Well Roon themselves is offering to have it changed as part of their install guide. That's why you have the variable $ROON_DATAROOT as documented on the room guide.
Aldoszx
Post by Aldoszx »
Indeed, they do offer this possibility, but it seems not to be the right solution in this case.
Even it is not explicitly specified, I think that the database shall not be put on the server install folder !
Maybe, changing the roonserver.service file and keeping the default location on var/roon/RoonServer for the database will solve the problem
If not, the best solution will be to manually install roonserver via unmodified easyinstall script.
Or, the install script on DietPi could be modified.
Aldoszx
Post by Aldoszx »
After some research, Roon developers suggested this:
"It sounds like the proper folders might not be persistent on the DietPi build. I would make sure that all of these folders are set as persistent and that the creators of the image haven’t set up a Deep Freeze kind of capability on the image.
This does appear to be a permissions issues and it appears that part of your Roon directories are getting wiped each time since they are not set as persistent. While I can’t comment on where exactly this behavior is happening, you should double check the Linux Install guide to try and find any directories which this will occur at or set your Linux machine to persist on all folders as this is exactly the kind of “Deep Freeze” behavior."
Could someone check if this happening ?
Thank you !
