NextCloud 502s on install (Nginx) Topic is solved
Doq
Re: NextCloud 502s on install (Nginx)
Post by Doq »
IP and FQDN still produce the issue--
Joulinar wrote: Mon Apr 20, 2020 1:08 am anything visible on the nginx error.log file?
cat /var/log/nginx/error.log
A revelation has been made! The error.log file gives me three copies of
2020/04/19 16:38:32 [crit] 1220#1220: *9 connect() to unix:/run/php/php7.3-fpm.sock failed (2: No such file or directory) while connecting to upstream, client: 10.0.0.4, server: brooklyn.home.n.burneset.ga, request: "GET /nextcloud/ HTTP/1.1", upstream: "fastcgi://unix:/run/php/php7.3-fpm.sock:", host: "10.0.0.205"
So it is PHP that is broken?
hmm let's have a look. On my system the request files are there. pls do
ls -la /run/php/
Doq
Post by Doq »
[root@brooklyn.home.n.burneset.ga ~]# ls -la /run/php/
total 8
drwxr-xr-x  2 www-data www-data 100 Apr 19 16:37 .
drwxr-xr-x 23 root     root     680 Apr 19 16:38 ..
-rw-r--r--  1 root     root       4 Apr 19 16:37 php7.2-fpm.pid
srw-rw----  1 www-data www-data   0 Apr 19 16:37 php7.2-fpm.sock
-rw-r--r--  1 root     root       4 Apr 19 16:37 php7.3-fpm.pid
It's missing. How did this happen?
hmm looks like something wrong with your PHP7.3 installation. I found a similar issue on the web describing yours exactly
https://superuser.com/questions/1456615 ... on-run-php
solution was to install php7.3-fpm package
apt install php7.3-fpm
package availability on your system could be checked like this
dpkg -l php7.3-fpm
and that the service is running like this
systemctl status php7.3-fpm
Doq
Post by Doq »
After doing some research of my own with this lead, it took me to this Github issue (https://github.com/laravel/homestead/issues/1031) in which it seems to be an issue with php7.3-fpm itself. Adjusting the nginx.conf to use 7.2's fpm makes NextCloud work as intended. Issue resolved!
        # Upstream to abstract back-end connection(s) for PHP
        upstream php {
+               server unix:/run/php/php7.2-fpm.sock;
-               server unix:/run/php/php7.3-fpm.sock;
It seems that this was the reason why only Nextcloud was broken, as in my include config I was defining fastcgi manually.
Thank you for the help!
yes that was the other option to point back to php7.2. anyway, did you tried to install php7.3-fpm??
Doq
Post by Doq »
I had tried using both apt install --reinstall and apt remove, then apt install, but neither of those resolved it either (it just wouldn't regenerate the socket).
ok strange, just keep in mind that active support for php7.2 already ended and it will get security fixes only until end of this year. sooner or later you might need to switch to php7.3 ;)
https://www.php.net/supported-versions.php
