Sonarr/Radarr and network drives...
codenomics
Re: Sonarr/Radarr and network drives...
Post by codenomics »
Yeah... I could do that... Don't come at me with simpler things to do... Ugh! :P
codenomics
well... I got that squared away...
Now throwing more errors in the logs
DownloadedMovieImportService
Import failed, path does not exist or is not accessible by Radarr: /storaid/temp/completed/Movies/Green.Book.2018.720p.BluRay.x264-x0r English
If it ain't one thing, it's another
you need to ensure the the file patch is existing and that applications users have the proper r/w access. Maybe you can check file permissions.
codenomics
Honestly... At this point, this is really more trouble than it is worth.
I assumed that since this was all automated during setup that this would be pretty simple.
I have changed groups, added users, spent quite a while trying to troubleshoot all this.
I had no issues with my previous setup, I just wanted to do something with the Pi lol.
Of course if you are running everything on one device it's much easier.
codenomics
I understand that. Should be a lot simpler than this though.
codenomics
ok, so I started from scratch. I got Radarr working great, still having issues with Sonarr though.
Couldn't download image /mnt/dietpi_userdata/sonarr/MediaCover/2/poster.jpg for [269586][Brooklyn Nine-Nine]. Access to the path is denied.: Access to the path is denied.
System.UnauthorizedAccessException: Access to the path is denied. ---> System.IO.IOException: Operation not permitted
Couldn't import episode /storaid/temp/completed/TV/Brooklyn.Nine-Nine.S07E01.Manhunter.1080p.AMZN.WEB-DL.DDP5.1.H.264-NTb/78ba89f0224a455e8dd845c01d48dfca.mkv: Access to the path is denied.
This is the /mnt/dietpi_userdata/sonarr/MediaCover/ dir
drwxr-xr-x 4 sonarr dietpi 4096 Apr 13 03:47 sonarr
This is the /storaid/temp/completed/ dir
drwxrwx--- 2 dietpi dietpi 0 Jul 25 2018 completed
In theories, all application users for Sonarr and Radarr should belong to dietpi user group. And this user group should have write permissions to all folder (means 775 permission)
At least on the Sonarr folder it looks like read permission only for dietpi user group.
codenomics
I even tried that with the 0777 perms and sonarr is added to the dietpi group.
Whenever a new dir is added to the MediCover dir it give those same "drwxr-xr-x 2 sonarr dietpi" permissions.
I am still learning about all this so I am at a loss on what is happening here. Enough reading and I will get this squared away.
ok found this one for Sonarr on DietPi user guide
viewtopic.php?f=8&t=5&start=100#p7455
pls have a look to Advanced settings in Sonarr and check if file mask is set to 664 as well as
folder mask is set to 775
