42/5000
Thanks, it almost works!
I have this error:
Apr 06 13:18:10 DietPi netdata[1168]: 2020-04-06 13:18:10: netdata ERROR : MAIN
: child pid 1181 exited with code 7.
root@DietPi:~# systemctl status netdata.service
● netdata.service - netdata - Real-time performance monitoring
Loaded: loaded (/lib/systemd/system/netdata.service; disabled; vendor preset:
enabled)
Active: active (running) since Mon 2020-04-06 13:18:10 CEST; 1min
34s ago
Docs: man:netdata
file:///usr/share/doc/netdata/html/index.html
https://github.com/netdata/netdata
Main PID: 1168 (netdata)
Tasks: 17 (limit: 4915)
CGroup: /system.slice/netdata.service
├─1168 /usr/sbin/netdata -D
├─1226 bash /usr/lib/netdata/plugins.d/tc-qos-helper.sh 1
└─1231 /usr/lib/netdata/plugins.d/apps.plugin 1
Apr 06 13:18:10 DietPi systemd[1]: Started netdata - Real-time performance monit
oring.
Apr 06 13:18:10 DietPi netdata[1168]: /usr/lib/netdata/plugins.d/anonymous-stati
stics.sh 'START' '-' '-'
Apr 06 13:18:10 DietPi netdata[1168]: 2020-04-06 13:18:10: netdata INFO : MAIN
: /usr/lib/netdata/plugins.d/anonymous-statistics.sh 'START' '-' '-'
Apr 06 13:18:10 DietPi netdata[1168]: child pid 1181 exited with code 7.
Netdata does not work Topic is solved
Re: Netdata does not work
yes I have seen it as well on my test system but did not find a way around yet. Did it impact your system? are you able to access Netdata?
Great, it works !!!
Thanks!
I had to edit the file /etc/netdata/netdata.conf and change the line bind socket to IP = 127.0.0.1 to match the local network IP
Thanks!
hm strange, because the netdata.conf file was the original one that was created right after first installation. But anyway it's working now.
I also had some issues this evening.
Seems the executable wasn't installed until i re-installed as per posts on page 1 and then I did not get working net data until I followed tec13 and changed the bind address to local server ip.
I guess you are on Debian Stretch as well. On Buster this should not happen. At least that how it was on my tests
ok, I kinda knew that DietPi was a version of Debian. Anyway, mine was downloaded a week ago - the version for Odroid HC1
Can you let me know the image you downloaded exactly? The current official one is based on Debian Stretch but there was already a new Debian Buster image created. It still has the testing flag but should work already. On Buster the issue should be gone.
https://github.com/MichaIng/DietPi/issues/2979
https://dietpi.com/downloads/testing/Di ... -Buster.7z
