Odroid C1+ Topic is solved
elmar.faber
Re: Odroid C1+
Post by elmar.faber »
@MichaIng
I never work with a serial console so I will show. The led never blink only burn always.
I found no new ip adress but I have "Linux File Systems for Windows (Paragon)" so I
can try to set a static ip adress. :)
elmar.faber
Re: Odroid C1+
@MichaIng Today I will debug the boot with a seriel console and try to setup with a static ip adress. I have a software from paragon
(Linux File Systems for Windows) so I can edit the dietpi.txt :)
So I hope in the evening we know something more then now
elmar.faber
Re: Odroid C1+
@MichaIng First excuse me for the double post...
Here ist the output from the serial console:
QA5:B;SVN:B72;POC:17F;STS:0;BOOT:0;INIT:10;BOOT:1;INIT:0;READ:0;CHECK:0;PASS:1;
* Welcome to Hardkernel's ODROID-C... (Built at 19:33:00 Dec  8 2014) *
CPU : AMLogic S805
MEM : 1024MB (DDR3@792MHz)
BID : HKC1311712
S/N : HKC11122F37F4EB9
0x0000009f
check SD_boot_type:0x1   card_type:0x1
Loading U-boot...success.
U-boot-00000-gb7b8dc2-dirty(odroidc@b7b8dc21) (Apr 03 2020 - 06:07:00)
I2C:   clear pinmux reg1[24]=0
clear pinmux reg1[1]=0
out reg=c1108058,value=fffcfa00
set output en 0xc1108054[21]=0
set output val 0xc1108058[21]=0
clear pinmux reg1[25]=0
clear pinmux reg8[12]=0
clear pinmux reg1[3]=0
clear pinmux reg1[2]=0
set output en 0xc1108054[20]=1
set output en 0xc1108054[20]=0
set output val 0xc1108058[20]=0
out reg=c1108058,value=ffdcfa00
out reg=c1108058,value=ffccfa00
out reg=c1108058,value=ffecfa00
ready
DRAM:  1 GiB
relocation Offset is: 2ff18000
MMC:   SDCARD: 0, eMMC: 1
IR init is done!
*** Warning - bad CRC, using default environment
mmc save env ok
vpu clk_level = 3
set vpu clk: 182150000Hz, readback: 182150000Hz(0x701)
mode = 6  vic = 4
set HDMI vic: 4
mode is: 6
viu chan = 1
config HPLL
config HPLL done
reconfig packet setting done
MMC read: dev # 0, block # 33984, count 12288 ... 12288 blocks read: OK
Error: Bad gzipped data
There is no valid bmp file at the given address
Vendor: Man 1b534d Snr 14a11937 Rev: 1.0 Prod: SDU1
            Type: Removable Hard Disk
            Capacity: 29819.0 MB = 29.1 GB (61069312 x 512)
Partition     Start Sector     Num Sectors     Type
    1                 8192          816001      83
Net:   Meson_Ethernet
init suspend firmware done. (ret:0)
Hit Enter key to stop autoboot -- :  0
exit abortboot: 0
** Unable to use mmc 0:1 for fatload **
Loading file "/boot/boot.ini" from mmc device 0:1 xxa1
3762 bytes read
Loading boot.ini from mmc0:1 (ext4)
Executing the script...
setenv rootdev "UUID=af6a8cf1-6bc1-4047-985c-7405f909db74"
setenv rootfstype "ext4"
setenv m "1080p"                # 1080P@60Hz
setenv vout_mode "hdmi"
setenv m_bpp "32"
setenv monitor_onoff "false" # true or false
setenv hpd "0"
setenv cec "0"
setenv disableuhs "disableuhs"
setenv vpu "0"
setenv hdmioutput "0"
if test -e mmc 0:1 boot/.next; then setenv condev "console=ttyAML0,115200n8"; else setenv condev "console=ttyS0,115200n8 console=tty0"; fi
setenv disable_vu7 "false" # false
setenv max_freq "1536"
if test "${hpd}" = "0"; then setenv hdmi_hpd "disablehpd=true"; fi
if test "${cec}" = "1"; then setenv hdmi_cec "hdmitx=cecf"; fi
if test "${disable_vu7}" = "false"; then setenv hid_quirks "usbhid.quirks=0x0eef:0x0005:0x0004"; fi
setenv bootargs "root=${rootdev} rootwait rw ${condev} rootfstype=${rootfstype} loglevel=3 no_console_suspend consoleblank=0 vdaccfg=0xa000 logo=osd1,loaded,0x7900000,720p,full dmfc=3 cvbsmode=576cvbs hdmimode=${m} m_bpp=${m_bpp} vout=${vout_mode} ${disableuhs} ${hdmi_hpd} ${hdmi_cec} ${enabledac} monitor_onoff=${monitor_onoff} max_freq=${max_freq} ${hid_quirks} ${extraargs}"
ext4load mmc 0:1 0x21000000 /boot/uImage || fatload mmc 0:1 0x21000000 uImage || ext4load mmc 0:1 0x21000000 uImage
Loading file "/boot/uImage" from mmc device 0:1 xxa1
8409664 bytes read
ext4load mmc 0:1 0x22000000 /boot/uInitrd || fatload mmc 0:1 0x22000000 uInitrd || ext4load mmc 0:1 0x22000000 uInitrd
Loading file "/boot/uInitrd" from mmc device 0:1 xxa1
invalid extent block
** Unable to read "/boot/uInitrd" from mmc 0:1 **
Loading file "uInitrd" from mmc device 0:1 xxa1
** File not found uInitrd
ext4load mmc 0:1 0x21A00000 /boot/dtb/meson8b-odroidc1.dtb
Loading file "/boot/dtb/meson8b-odroidc1.dtb" from mmc device 0:1 xxa1
17758 bytes read
fdt addr 21A00000
if test "${vpu}" = "0"; then fdt rm /mesonstream; fdt rm /vdec; fdt rm /ppmgr; fi
libfdt fdt_path_offset() returned FDT_ERR_NOTFOUND
if test "${hdmioutput}" = "0"; then fdt rm /mesonfb; fi
bootm 0x21000000 0x22000000 0x21A00000
## Booting kernel from Legacy Image at 21000000 ...
   Image Name:   Linux kernel
   Image Type:   ARM Linux Kernel Image (uncompressed)
   Data Size:    8409600 Bytes = 8 MiB
   Load Address: 00208000
   Entry Point:  00208000
   Verifying Checksum ... Bad Data CRC
ERROR: can't get kernel image!
Unknown command '▒' - try 'help'
MMC read: dev # 0, block # 1216, count 16384 ... 16384 blocks read: OK
MMC read: dev # 0, block # 1088, count 128 ... 128 blocks read: OK
Wrong Image Format for bootm command
odroidc#
Re: Odroid C1+
Hmm, the error still matches the one mentioned in the forum when the kernel image is too big: https://forum.odroid.com/viewtopic.php?p=282220#p282220
I'll have a closer check as the increased address for dtb file is in place. Good to know also that some other parts of the boot.ini seem to be obsolete (disabling HDMI, as the related parts of the device tree are not present anyway).
Re: Odroid C1+
Last try on Armbian: https://dl.armbian.com/odroidc1/Buster_current_minimal
The image now contains uImage OOTB. The boot.ini however is unmodified. Not sure if something has been fixed or not, however if someone can test it and it boots, I'll create a DietPi image from it, otherwise I'll use ancient Meveric kernel 3.10 image, which should at least boot.
Re: Odroid C1+
New image up: https://dietpi.com/downloads/images/Die ... -Buster.7z
Armbian upgraded their legacy (two partitions, uImage) image to Linux 5.4 and this finally seems to have solved the issue and boots :D.
Raoul
Re: Odroid C1+
Post by Raoul »
And it's working!!!
No cpu temp, but does't matter!
Re: Odroid C1+
Great, finally, many thanks for testing!
Probably we can get CPU temps as well, run the following to check the kernel files:
for i in /sys/class/thermal/thermal_zone[0-9]/temp /sys/class/hwmon/hwmon[0-9]/temp[0-9]_input /sys/devices/platform/coretemp.[0-9]/hwmon/hwmon[0-9]/temp[0-9]_input
do
[[ -e $i ]] && echo "$i : $(<$i)"
done
Raoul
Re: Odroid C1+
Post by Raoul »
The answer to this code :
/sys/class/hwmon/hwmon0/temp1_input : 35312
So its working I think 35 degrees
Re: Odroid C1+
Wow, this was the only output? I was assuming some more files as usually there are more sensors for other parts of the SBC. Probably also a limitation of the CPU ;). Regardless, I'll put that file into our script to show in banner.
