This is home internet, coming from a WISP. I doubt it's ISP or state censorship, and I can't fathom the motive.
'fail to fetch' and DNS related issues? Topic is solved
Re: 'fail to fetch' and DNS related issues?
I did have PiHole as part of this DietPi install, but I have deactivated it, and the Buster image didn't have it installed at all.Joulinar wrote: ↑Fri Mar 27, 2020 4:55 pm at least I would try to open the following on a web browser on same network
http://fuzon.co.uk/meveric/pool/xu3/l/l ... _armhf.deb
At least I don't have issues with it. I can open and download the file from my side. So the Website is working and accessible from internet
same for the other 2 links
https://download.mono-project.com/repo/ ... s/stretch/
https://oph.mdrjr.net/meveric/dists/all/
Do you use any own DNS server like PiHole or something like this?
@trendy
you simply could install traceroute if you are missing it
apt install inetutils-traceroute
I am able to open all 3 of those links and download files on my computer on the same network.
traceroute installed fine, here's some I tried. what does !N mean? I'll start googling...
root@DietPi:~# traceroute google.com
traceroute to google.com (216.239.38.120), 64 hops max
1 192.168.1.1 2.449ms 2.832ms 4.121ms
2 192.168.14.1 11.712ms 7.949ms 16.074ms
3 192.168.13.1 16.001ms 9.857ms !N 8.056ms
root@DietPi:~# traceroute fuzon.co.uk
traceroute to fuzon.co.uk (185.101.93.34), 64 hops max
1 192.168.1.1 3.560ms 3.626ms 2.587ms
2 192.168.14.1 10.421ms 11.889ms 7.822ms
3 192.168.13.1 8.652ms !N 16.452ms 8.777ms
root@DietPi:~# traceroute download.mono-project.com
traceroute to cs9.wpc.v0cdn.net (117.18.232.200), 64 hops max
1 192.168.1.1 5.161ms 2.415ms 2.285ms
2 192.168.14.1 22.075ms 15.654ms 10.913ms
3 192.168.13.1 23.023ms !N 28.733ms 23.428ms
root@DietPi:~# traceroute oph.mdrjr.net
traceroute to main.mdrjr.net (216.155.157.42), 64 hops max
1 192.168.1.1 4.722ms 5.006ms 2.962ms
2 192.168.14.1 31.304ms 13.165ms 16.203ms
3 192.168.13.1 21.770ms !N 19.344ms 23.497ms
honestly your trace looks quite strange. Doesn't matter what you to trace, you have 3 hops only. And all 3 a from a privat network.
https://en.wikipedia.org/wiki/Private_network
And it looks like you never going to reach the target. Do you know what 192.168.14.1 and 192.168.13.1 is about? I assume 192.168.1.1 is your internet router.
For me the trace looks like this
!N means that your machine received ICMP message "destination host unreachable". Could be as well !P or !H
traceroute to google.com (172.217.22.78), 64 hops max
1 192.168.0.1 0.997ms 1.377ms 0.622ms
2 192.168.2.1 2.029ms 1.408ms 1.477ms
3 * * *
4 * * *
5 80.154.91.157 13.306ms 12.221ms 10.923ms
6 217.0.197.229 17.690ms 15.671ms 16.970ms
7 62.157.250.46 17.862ms 16.943ms 16.634ms
8 * * *
9 66.249.94.146 19.761ms 18.627ms 18.906ms
10 108.170.251.209 17.685ms 17.335ms 16.382ms
11 209.85.240.113 17.269ms 16.764ms 16.291ms
12 172.217.22.78 17.289ms 15.951ms 15.797ms
root@DietPiVM1:~# traceroute fuzon.co.uk
1 192.168.0.1 0.995ms 0.470ms 0.430ms
2 192.168.2.1 1.834ms 1.509ms 1.116ms
3 * * *
4 * * *
5 195.145.92.33 13.447ms 11.989ms 12.704ms
6 217.5.116.42 17.404ms 17.078ms 17.300ms
7 62.157.249.186 17.677ms 17.174ms 17.885ms
8 129.250.6.13 25.879ms * *
9 129.250.4.77 18.075ms 18.029ms 16.390ms
10 213.198.72.154 17.311ms 17.008ms 17.001ms
11 93.115.91.22 17.647ms 16.846ms 17.887ms
12 5.254.68.150 18.226ms 16.858ms 16.233ms
13 5.254.14.94 20.057ms 19.495ms 20.138ms
14 62.141.47.20 20.522ms 20.393ms 19.923ms
15 * 62.141.47.65 22.219ms *
16 * * *
17 62.141.47.191 22.717ms 20.487ms 20.864ms
18 194.125.248.134 21.252ms 20.247ms 19.790ms
19 * * *
20 185.101.93.34 23.051ms 20.278ms 21.864ms
root@DietPiVM1:~#
It is not so strange, you had seen this message before when you were trying to apt-get the packages.
Talk to your ISP, they have messed up something and they are rejecting these IP addresses for no apparent reason.
honestly I would go to find out what 192.168.14.1 and 192.168.13.1 is. These are 2 privat IP's and trace stopped somewhere there.
It's common for ISPs, especially WISPs to use private IPs in their backbone. That is not a problem.
well but he never reached the target on his trace
And that is why I advised him to contact his ISP.
If he was reaching the destination we wouldn't be discussing the issue here.
But still the question why he is able to access the website from another computer on the same network while the SBC is failing?
