Getting DietPi on RPi 4 to run headless (NOT headless install) Topic is solved
Legend
Re: Getting DietPi on RPi 4 to run headless (NOT headless install)
Hi, if you have autostart into local desktop session + virtual VNC, you can use index 0 as this will display the live desktop.
But this requires shared desktop mode the be active, doesn't it? There is connects to index 0 automatically, but with TigerVNC it starts a different daemon then. On RealVNC however shared desktop daemon is running by default, hence when using index 0 on the VNC client it should indeed automatically show the local desktop.
