Odroid Xu4 Apt-get update error SSL... Topic is solved
Re: Odroid Xu4 Apt-get update error SSL...
@trendy
this only helps if the router is playing DHCP server as well.
@joaquinain
what is this IP 192.168.1.25 about? is this your internet router? Which Upstream DNS server you configured in PiHole? Can you check pihole -t. It should display Pihole log and you can watch what PiHole is doing on your DNS request. Probably logging would need to be activated >> pihole logging on
trendy
Post by trendy »
Joulinar wrote: Mon Mar 30, 2020 11:20 pm this only helps if the router is playing DHCP server as well.
Which is the default for all home and soho routers
well I need to use PiHole as DHCP Server because my Router (ISP device) did not support changing local DNS Server. ;)
