NFS mount fails at reboot Topic is solved
trendy
Re: NFS mount fails at reboot
Post by trendy »
It's quite interesting that on 3 of my DietPis, I have different options in fstab for the nfs. They all are in v6.28 amd fully updated.
Raspi3B and Odroid C1 have `auto,_netdev,nofail`
Rockpi4 has `_netdev,nofail,noauto,x-systemd.automount`
None of them is using the dump and fsck numbers at the end.
Nonetheless they all work fine, but I guess there was some change at some point in the releases.
@trendy
I guess it has something to do with using STATIC or DHCP IP address.
If I'm using DHCP, NFS mount is failing during boot.
root@DietPi3:~# journalctl -u mnt-nfs_client.mount
-- Logs begin at Thu 2019-02-14 11:11:58 CET, end at Thu 2020-03-26 10:11:41 CET. --
Mär 26 10:10:42 DietPi3 systemd[1]: Mounting /mnt/nfs_client...
Mär 26 10:10:42 DietPi3 mount[427]: mount.nfs: Network is unreachable
Mär 26 10:10:42 DietPi3 systemd[1]: mnt-nfs_client.mount: Mount process exited, code=exited, status=32/n/a
Mär 26 10:10:42 DietPi3 systemd[1]: mnt-nfs_client.mount: Failed with result 'exit-code'.
Mär 26 10:10:42 DietPi3 systemd[1]: Failed to mount /mnt/nfs_client.
But if I switch to STATIC IP, the NFS mount will succeed.
-- Logs begin at Thu 2019-02-14 11:11:58 CET, end at Thu 2020-03-26 10:31:22 CET. --
Mär 26 10:30:46 DietPi3 systemd[1]: Mounting /mnt/nfs_client...
Mär 26 10:30:47 DietPi3 systemd[1]: Mounted /mnt/nfs_client.
root@DietPi3:~#
trendy
Post by trendy »
I am using dhcp on all 3 of them.
I rebooted the Raspi3B which has options `auto,_netdev,nofail` and the mount is available immediately.
dietpi@raspi:[~]$ sudo journalctl -u mnt-nfs_client.mount
-- Logs begin at Thu 2020-03-26 11:09:30 CET, end at Thu 2020-03-26 11:11:13 CET. --
-- No entries --
can you have a look to journalctl to see at which stage the nfs mount is done? Because on my test system 3B+ it's done right in the middle of assigned an IP address via DHCP. So for sure the NFS will fail without eth0 up.
btw: @trendy
you provided an empty journalctl -u mnt-nfs_client.mount code snip. So I guess your mount point is different than /mnt/nfs_client
-- No entries --
trendy
Post by trendy »
Yes, it is /mnt/backup and you are right about it. The mount is happening before the dhcp transaction starts, hence it fails. The automated backup kept taking snapshots though and there was something inside the directory, thus my confusion.
I corrected the nfs mount line in fstab and now works properly! Thanks!
I added the topic to an old GitHub entry. Let's see what @MichaIng thinks on it.
https://github.com/MichaIng/DietPi/issues/1898
Guys,
a permanent fix will be provided with v6.29.
jonyskids
Post by jonyskids »
That did it, Thanks.
Will that be permanent if I use the drive_manager to add more drives?
Really Appreciate the help. This has been a glitch for some time.
usually it should, at least if you did not touch this mount. Anyway it will be fixed permanently with upcoming DietPi release.
Yes, fstab changes for network drives are permanent, only physical drive mounts are rewritten when you open dietpi-drive_manager.
And yes I fixed it for next DietPi release, thanks to your report! We already added this fix for NFS pre-v3 and Samba for simply missed the code lines that are responsible for NFSv3 which requires a slightly different fstab entry.
