webmin update reinstall failed
spanx20
Re: webmin update reinstall failed
Post by spanx20 »
i can't find that directory
nano /DietPi/dietpi/.installed
i have the 64 bit version of dietpi rasp 4
many thanks for your message. On version DietPi v6.29, all DietPi scripts have been migrated from /DietPi to /boot folder. The file you are looking for is located at /boot/dietpi/.installed now.
