webmin update reinstall failed
Re: webmin update reinstall failed
yes dpkg --configure -a could take a while is it trying to configure the software
laurentl
Post by laurentl »
ok so I let in run
I'll keep you informed
laurentl
Post by laurentl »
it's still stuck ...
did you get any error message?
laurentl
Post by laurentl »
plop
no error no message just
"Setting up webmin (1.941) ..."
laurentl
Post by laurentl »
So, as I have not found any solution I would like to reverse the installation
does anyone knows what the installation script does ?
laurentl
Post by laurentl »
or force the uninstall script ?
usually you can run dietpi-software to uninstall stuff that was installed with DietPi tools.
laurentl
Post by laurentl »
yeah I know but as the installation failed there is no webmin option in the uninstall menu so I'd like to start the script manually
nothing that can't be fixed ;)
do the following to get webmin available for uninstall
  1. execute the following on command line > nano /DietPi/dietpi/.installed
  2. change status of software titel 115 to 2 > aSOFTWARE_INSTALL_STATE[115]=2
  3. save & exit
  4. execute the following on command line > dietpi-software uninstall 115
