Last image raspberry pi not boot in fresh installation
loro102
Re: Last image raspberry pi not boot in fresh installation
Post by loro102 »
I've already fixed, a virus entered the sd card and broke it, so I went out the image of the sd card damaged .However not know if this is Relevate but I see some errors when starting the raspberry. Add a catch below
Fourdee
Post by Fourdee »
What errors do you see, could you please take a picture of them and attach here?
loro102
Post by loro102 »
Fourdee wrote:Hi,
Sorry, this is the picture, this error appears at the very beginning. Is this normal?
Fourdee
Post by Fourdee »
loro102 wrote: Sorry, this is the picture, this error appears at the very beginning. Is this normal?
Yep thats fine, occurs when running 16MB GPU in which Video Core will fail to initialize: (source https://github.com/raspberrypi/firmware/issues/428)
You'll only need Video Core if your running GPU apps like Kodi. In which case, DietPi-Software will automatically set the required GPU memory splits for you, during installation.
You can also manually change the GPU memory splits, if required, by running dietpi-config > display options > GPU split
