Can't install any plugin on Wordpress Topic is solved
Re: Can't install any plugin on Wordpress
tallbastard
Post by tallbastard »
OK will check that out in next version ... thanks again.. !
any update on similar issues with wordpress ?
I have since tried another install from fresh and similar issue persists that can't write to the uploads directory nor add plugins.. am I the only one mentioning this, can't see other comments in the forum but if I missed something please point me to it
easy
James
I just did a fresh install and installing plugins as well as uploading files works fine. Could you paste the output of the following:
ls -Al /var/www/wordpress/wp-content/
