So you would need to set correct values right after flashing your SD card by editing dietpi.txt on your desktop computer where you flashed the SD card before booting first time
I see you have set STATIC IP address
AUTO_SETUP_NET_USESTATIC=1
AUTO_SETUP_NET_STATIC_IP=192.168.0.100
AUTO_SETUP_NET_STATIC_MASK=255.255.255.0
AUTO_SETUP_NET_STATIC_GATEWAY=192.168.0.1
# Enter your Static Network details below, if applicable.
AUTO_SETUP_NET_STATIC_IP=192.168.200.xxx <------ (pls set a free IP from your network replacing xxx)
AUTO_SETUP_NET_STATIC_GATEWAY=192.168.200.1
AUTO_SETUP_NET_STATIC_DNS=192.168.200.1
AUTO_SETUP_NET_USESTATIC=0
