Hi guys,
I am newbie and I want to know if it is possibile to transfer plugin in Plex media server plug-in folder manually and how:
At the Moment, I have plug-in in download folder and i want to know where I can find on DietPi Plex media server plugin folder and how I can do.
Thanks and I ma sorry if the question is inopportune
Gio
Plex Server Plug-in folder Topic is solved
Re: Plex Server Plug-in folder
It appears you can move it, or copy the plugins in them to another folder
https://support.plex.tv/articles/201187 ... -a-plugin/
Might have to ensure the folder owner is appropriate after the copy/move
Copy or move the plug-in bundle into the Plug-Ins folder on the computer running Plex Media Server
Thank you for your answer but i don't need of that link. I need to know where i can find that folder in dietpi because if i try the command, it doesn't exist.
You can find the location using the following path.
