Temperature by email Topic is solved
Re: Temperature by email
hmm can you try the following
0,5,10,15,20,25,30,35,40,45,50,55 * * * * <your script>
maybe */x notation is not understood correctly
If it still seems to be not working after that, change the command to something like:
0,5,10,15,20,25,30,35,40,45,50,55 * * * * date >>/tmp/debug_cron_pax.txt
The */2 notation is interpreted correctly. We use that for implemented minutely timer as well (dietpi-cron > minutely). Have you verified sufficient permissions of the crontab's user to execute the script?
One can also increase cron log level via /etc/default/cron.
huidbui25
Post by huidbui25 »
Joulinar wrote: Fri Feb 07, 2020 4:53 pm
That was a good hint and, indeed, it works. It's not the notation, */5 ... works, too: the txt file is being created and a new line added every five minutes. So the problems seems to be related to my script somehow. :? What would make a script not being run by cronjob?
huidbui25
Post by huidbui25 »
MichaIng wrote: Fri Feb 07, 2020 5:00 pm One can also increase cron log level via /etc/default/cron.
I'll try that and see what I find ...
huidbui25
Post by huidbui25 »
Ahh, I'm getting closer. The error is not caused by cron but by the mailing program, it trys to send to the wrong email address. But not sure why. When executing the script manually it works, when exectuted by cron the mailer uses different mail settings and hence fails.
huidbui25
Post by huidbui25 »
Heureka ... more or less ;) I have to add "sudo" to the cronjob line to make it work:
*/2 * * * * sudo bash /usr/local/bin/temp_mon
I only don't understand the reason why it doesn't work without that "sudo".
probably it has something to do with the user environment the cron is executed with.
huidbui25
Post by huidbui25 »
WarHawk wrote: Fri Feb 07, 2020 4:53 am neat..post it up!
Good idea. Done so here. I'm a Linux novice tho.
