Having two network adapters on the same subnet active, leads to breaking network connections since the system doesn't know with adapter to send requests to (default route). In such case a routing table is required. So either add a different IP to one adapter (of course it cannot connect to the same network then) or disable one before enable the other one.
The 17 minutes most likely is one of the DHCP lease timeouts. E.g. DHCP lease for WiFi is done, which applies default route to WiFi, then DHCP lease for Ethernet times out, new lease overrides previous default route, breaking WiFi connection.
DietPi v6.28.0 Wifi drop update: freezed networking
Re: DietPi v6.28.0 Wifi drop update: freezed networking
@MichaIng
I guess Ethernet was connected temporary only and got removed before system stuck over night
Hmm, btw I think you misinterpreted the logs:
RPi shutdown => fake-hwclock safes current system time to temp file => boot => fake-hwclock restores system time from temp file, which of course is in the past => systemd-timesyncd finishes and updates system time to actual current time => timestamps show a jump in logs.
EDIT: Ah sorry, got it wrong as well, indeed somewhere after 14:3X a reboot seems to have happened, with 14:17 stored as last timestamp...
I think this is what we need to investigate:
This does not mean that the system rebooted at 14:17. The timestamp switch is due to time sync being done.Feb 5 14:17:43 garden systemd[1]: systemd-fsckd.service: Succeeded.
Feb 5 16:52:50 garden systemd-timesyncd[452]: Synchronized to time server for the first time 37.187.104.44:123 (2.debian.pool.ntp.org).
Feb 5 14:36:58 garden wpa_supplicant[9466]: wlan0: CTRL-EVENT-BEACON-LOSS
Found some related bug report where it turns out to be an incompatibility between current wpa_supplicant and certain WiFi adapters: https://bugzilla.redhat.com/show_bug.cgi?id=1703745
@kriznik
Could you please paste: lsusb (it is a dongle, right?)
And if you have, could you try a different WiFi dongle/adapter?
@kriznik
they are usb dongles but from different wendors
one is
- need to point out that this AR9271 was running without these issues for several years already and with dietpi like year or so. Let's assume that whatever is causing this is probably something between version 6.26 and 6.28 (or combination as mentioned below)
second is
but I dont think the real issue is in there anymore.
As I pointed out, yesterday I disabled node-red on first (initial, headless) device. And it's still working fine.
on second testing pi (with edimax) i do have node-red and same flows enabled and it already failed once.
I was trying to remember if it started after upgrade to 6.28 or if I was installing node-red at same time and it might be around same time so I maybe wrongly assumed it's caused by upgrade (but it can be).
What is actually puzzling me is that hourly cron, which only runs at 17th minute triggering ath reboot as we can see in first machine's debug.
but that was yesterday, there is no entry since Feb6 20:17 (I've disabled node-red around 9pm ish)
btw during today kernel headers got update at first device so ... who knows if it helped something.
one is
dietpi@garden:~$ lsusb
Bus 001 Device 005: ID 0cf3:9271 Qualcomm Atheros Communications AR9271 802.11n
Bus 001 Device 004: ID 0781:5571 SanDisk Corp. Cruzer Fit
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Bus 001 Device 002: ID 0424:9512 Standard Microsystems Corp. SMC9512/9514 USB Hub
dietpi@garden:~$
second is
root@DietPi:~# lsusb
Bus 001 Device 005: ID 0781:5571 SanDisk Corp. Cruzer Fit
Bus 001 Device 008: ID 7392:a812 Edimax Technology Co., Ltd
Bus 001 Device 006: ID 1241:1503 Belkin Keyboard
Bus 001 Device 004: ID 04b4:6560 Cypress Semiconductor Corp. CY7C65640 USB-2.0 "TetraHub"
Feb 6 20:17:21 garden kernel: [ 27.232844] ath: EEPROM regdomain: 0x809c
Feb 6 20:17:21 garden kernel: [ 27.232851] ath: EEPROM indicates we should expect a country code
Feb 6 20:17:21 garden kernel: [ 27.232860] ath: doing EEPROM country->regdmn map search
Feb 6 20:17:21 garden kernel: [ 27.232867] ath: country maps to regdmn code: 0x52
Feb 6 20:17:21 garden kernel: [ 27.232875] ath: Country alpha2 being used: CN
Feb 6 20:17:21 garden kernel: [ 27.232881] ath: Regpair used: 0x52
well at least you are the only we are are who has such issues. so it might be something special on your devices, ether software, configuration or hardware
Or combination of everything
@MichaIng
one stupid question regarding fake-hwclock. Why is it saving the 17th minte of a hour?? I would expect the job to be running every full hour
Or I'm totally blond on that one!
second one is purely generic dietpi 6.28, boot on SD, root on USB + node.js + node-red from dietpi-software
and the first is basically the same
anyway this is pretty standard
ok node-red is for now out of suspicion, happened on first machine at 4:17 again
same story, power off/on at 9:04 to gain access to
debug
syslog (complete from 04:16 till 09
daemon.log
debug
Feb 8 04:17:20 garden kernel: [ 0.000000] On node 0 totalpages: 61440
Feb 8 04:17:20 garden kernel: [ 0.000000] Normal zone: 540 pages used for memmap
Feb 8 04:17:20 garden kernel: [ 0.000000] Normal zone: 0 pages reserved
Feb 8 04:17:20 garden kernel: [ 0.000000] Normal zone: 61440 pages, LIFO batch:15
Feb 8 04:17:20 garden kernel: [ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
Feb 8 04:17:20 garden kernel: [ 0.000000] pcpu-alloc: [0] 0
Feb 8 04:17:20 garden kernel: [ 0.826542] dwc_otg: Microframe scheduler enabled
Feb 8 04:17:20 garden kernel: [ 0.834430] dwc_otg: FIQ enabled
Feb 8 04:17:20 garden kernel: [ 0.834442] dwc_otg: NAK holdoff enabled
Feb 8 04:17:20 garden kernel: [ 0.834448] dwc_otg: FIQ split-transaction FSM enabled
Feb 8 04:17:20 garden kernel: [ 0.834465] Module dwc_common_port init
Feb 8 04:17:20 garden kernel: [ 3.287940] sd 0:0:0:0: [sda] Mode Sense: 43 00 00 00
Feb 8 04:17:20 garden kernel: [ 28.341016] ath: EEPROM regdomain: 0x809c
Feb 8 04:17:20 garden kernel: [ 28.341023] ath: EEPROM indicates we should expect a country code
Feb 8 04:17:20 garden kernel: [ 28.341031] ath: doing EEPROM country->regdmn map search
Feb 8 04:17:20 garden kernel: [ 28.341038] ath: country maps to regdmn code: 0x52
Feb 8 04:17:20 garden kernel: [ 28.341047] ath: Country alpha2 being used: CN
Feb 8 04:17:20 garden kernel: [ 28.341053] ath: Regpair used: 0x52
Feb 8 04:16:46 garden wpa_supplicant[32338]: wlan0: CTRL-EVENT-BEACON-LOSS
Feb 8 04:17:01 garden CRON[26723]: (root) CMD (cd / && run-parts --report /etc/cron.hourly)
Feb 8 04:17:07 garden wpa_supplicant[32338]: wlan0: CTRL-EVENT-BEACON-LOSS
Feb 8 04:17:10 garden wpa_supplicant[32338]: wlan0: CTRL-EVENT-BEACON-LOSS
Feb 8 04:17:11 garden wpa_supplicant[32338]: wlan0: CTRL-EVENT-BEACON-LOSS
Feb 8 04:17:37 garden wpa_supplicant[32338]: wlan0: CTRL-EVENT-BEACON-LOSS
Feb 8 04:17:46 garden wpa_supplicant[32338]: wlan0: CTRL-EVENT-BEACON-LOSS
Feb 8 04:18:02 garden CRON[26772]: (dietpi) CMD (sudo python3 ~/scripts/lux.py &)
Feb 8 04:18:03 garden wpa_supplicant[32338]: wlan0: CTRL-EVENT-BEACON-LOSS
Feb 8 04:18:07 garden wpa_supplicant[32338]: wlan0: CTRL-EVENT-BEACON-LOSS
Feb 8 04:18:33 garden wpa_supplicant[32338]: wlan0: CTRL-EVENT-BEACON-LOSS
Feb 8 04:19:04 garden wpa_supplicant[32338]: wlan0: CTRL-EVENT-BEACON-LOSS
Feb 8 04:19:29 garden wpa_supplicant[32338]: wlan0: CTRL-EVENT-BEACON-LOSS
Feb 8 04:19:49 garden wpa_supplicant[32338]: wlan0: CTRL-EVENT-BEACON-LOSS
Feb 8 04:20:01 garden CRON[26848]: (dietpi) CMD (sudo python3 ~/scripts/rain.py &)
Feb 8 04:20:01 garden CRON[26849]: (dietpi) CMD (sudo python3 ~/scripts/temperature.py &)
Feb 8 04:20:10 garden wpa_supplicant[32338]: wlan0: CTRL-EVENT-BEACON-LOSS
Feb 8 04:20:27 garden wpa_supplicant[32338]: wlan0: CTRL-EVENT-BEACON-LOSS
Feb 8 04:21:01 garden wpa_supplicant[32338]: wlan0: CTRL-EVENT-BEACON-LOSS
Feb 8 04:21:01 garden CRON[26909]: (dietpi) CMD (sudo python3 ~/scripts/lux.py &)
Feb 8 04:21:11 garden wpa_supplicant[32338]: wlan0: CTRL-EVENT-BEACON-LOSS
Feb 8 04:22:01 garden CRON[26956]: (dietpi) CMD (sudo python3 ~/scripts/water.py &)
Feb 8 04:23:04 garden wpa_supplicant[32338]: wlan0: CTRL-EVENT-BEACON-LOSS
Feb 8 04:23:45 garden wpa_supplicant[32338]: wlan0: CTRL-EVENT-BEACON-LOSS
Feb 8 04:23:58 garden wpa_supplicant[32338]: wlan0: CTRL-EVENT-BEACON-LOSS
Feb 8 04:24:01 garden CRON[27038]: (dietpi) CMD (sudo python3 ~/scripts/lux.py &)
Feb 8 04:24:01 garden CRON[27039]: (dietpi) CMD (sudo python3 ~/scripts/temperature.py &)
Feb 8 04:24:38 garden wpa_supplicant[32338]: wlan0: CTRL-EVENT-BEACON-LOSS
Feb 8 04:25:01 garden CRON[27098]: (dietpi) CMD (sudo python3 ~/scripts/rain.py &)
Feb 8 04:25:15 garden wpa_supplicant[32338]: wlan0: CTRL-EVENT-BEACON-LOSS
Feb 8 04:27:02 garden CRON[27175]: (dietpi) CMD (sudo python3 ~/scripts/lux.py &)
Feb 8 04:17:20 garden systemd-modules-load[71]: Inserted module 'i2c_bcm2708'
Feb 8 04:17:20 garden systemd-modules-load[71]: Inserted module 'i2c_dev'
Feb 8 04:17:20 garden fake-hwclock[83]: Sat 8 Feb 03:17:01 UTC 2020
Feb 8 04:17:20 garden systemd-fsck[93]: e2fsck 1.44.5 (15-Dec-2018)
Feb 8 04:17:20 garden systemd-fsck[93]: /dev/sda1: clean, 58584/938400 files, 436331/3753472 blocks
Feb 8 04:17:20 garden systemd[1]: Started Set the console keyboard layout.
Feb 8 04:17:20 garden systemd[1]: Started udev Coldplug all Devices.
Feb 8 04:17:20 garden systemd[1]: Starting Helper to synchronize boot up for ifupdown...
Feb 8 04:17:20 garden systemd[1]: Started Remount Root and Kernel File Systems.
Feb 8 04:17:20 garden systemd[1]: Starting Flush Journal to Persistent Storage...
Feb 8 04:17:20 garden systemd[1]: Starting Create System Users...
Feb 8 04:17:20 garden systemd[1]: Starting Load/Save Random Seed...
Feb 8 04:17:20 garden systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
Feb 8 04:17:20 garden systemd[1]: Started Helper to synchronize boot up for ifupdown.
Feb 8 04:17:20 garden systemd[1]: Started Create System Users.
Feb 8 04:17:20 garden systemd[1]: Started Flush Journal to Persistent Storage.
Feb 8 04:17:20 garden systemd[1]: Started Load/Save Random Seed.
Feb 8 04:17:20 garden systemd[1]: Starting Create Static Device Nodes in /dev...
Feb 8 04:17:20 garden systemd[1]: Started Create Static Device Nodes in /dev.
Feb 8 04:17:20 garden systemd[1]: Starting udev Kernel Device Manager...
Feb 8 04:17:20 garden systemd[1]: Reached target Local File Systems (Pre).
Feb 8 04:17:20 garden systemd[1]: DietPi.mount: Directory /DietPi to mount over is not empty, mounting anyway.
Feb 8 04:17:20 garden systemd[1]: Mounting /DietPi...
Feb 8 04:17:20 garden kernel: [ 0.000000] Booting Linux on physical CPU 0x0
Feb 8 04:17:20 garden kernel: [ 0.000000] Linux version 4.19.97+ (dom@buildbot) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611)) #1294 Thu Jan 30 13:10:54 GMT 2020
Feb 8 04:17:20 garden kernel: [ 0.000000] CPU: ARMv6-compatible processor [410fb767] revision 7 (ARMv7), cr=00c5387d
Feb 8 04:17:20 garden kernel: [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
Feb 8 04:17:20 garden kernel: [ 0.000000] OF: fdt: Machine model: Raspberry Pi Model B Rev 2
Feb 8 04:17:20 garden kernel: [ 0.000000] Memory policy: Data cache writeback
Feb 8 04:17:20 garden kernel: [ 0.000000] cma: Reserved 8 MiB at 0x0e400000
Feb 8 04:17:20 garden kernel: [ 0.000000] random: get_random_bytes called from start_kernel+0x8c/0x494 with crng_init=0
Feb 8 04:17:20 garden kernel: [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 60900
Feb 8 04:17:20 garden kernel: [ 0.000000] Kernel command line: coherent_pool=1M bcm2708_fb.fbwidth=16 bcm2708_fb.fbheight=16 bcm2708_fb.fbdepth=16 bcm2708_fb.fbswap=1 smsc95xx.macaddr=B8:27:EB:9C:FA:95 vc_mem.mem_base=0xfa00000 vc_mem.mem_size=0x10000000 dwc_otg.lpm_enable=0 console=ttyAMA0,115200 console=tty1 rootdelay=10 root=PARTUUID=07eac884-a11d-4168-b01c-4130209852f4 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
Feb 8 04:17:20 garden kernel: [ 0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
Feb 8 04:17:20 garden kernel: [ 0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
Feb 8 04:17:20 garden kernel: [ 0.000000] Memory: 223224K/245760K available (7144K kernel code, 656K rwdata, 2128K rodata, 472K init, 797K bss, 14344K reserved, 8192K cma-reserved)
Feb 8 04:17:20 garden kernel: [ 0.000000] Virtual kernel memory layout:
Feb 8 04:17:20 garden kernel: [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
Feb 8 04:17:20 garden kernel: [ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
Feb 8 04:17:20 garden kernel: [ 0.000000] vmalloc : 0xcf800000 - 0xff800000 ( 768 MB)
Feb 8 04:17:20 garden kernel: [ 0.000000] lowmem : 0xc0000000 - 0xcf000000 ( 240 MB)
Feb 8 04:17:20 garden kernel: [ 0.000000] modules : 0xbf000000 - 0xc0000000 ( 16 MB)
Feb 8 04:17:20 garden kernel: [ 0.000000] .text : 0x(ptrval) - 0x(ptrval) (7146 kB)
Feb 8 04:17:20 garden kernel: [ 0.000000] .init : 0x(ptrval) - 0x(ptrval) ( 472 kB)
Feb 8 04:17:20 garden kernel: [ 0.000000] .data : 0x(ptrval) - 0x(ptrval) ( 657 kB)
Feb 8 04:17:20 garden kernel: [ 0.000000] .bss : 0x(ptrval) - 0x(ptrval) ( 798 kB)
Feb 8 04:17:20 garden kernel: [ 0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
Feb 8 04:17:20 garden kernel: [ 0.000000] ftrace: allocating 25657 entries in 76 pages
Feb 8 04:17:20 garden kernel: [ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
Feb 8 04:17:20 garden kernel: [ 0.000027] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns
Feb 8 04:17:20 garden kernel: [ 0.000085] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
Feb 8 04:17:20 garden kernel: [ 0.000203] bcm2835: system timer (irq = 27)
Feb 8 04:17:20 garden kernel: [ 0.000582] Console: colour dummy device 80x30
Feb 8 04:17:20 garden kernel: [ 0.001104] console [tty1] enabled
Feb 8 04:17:20 garden kernel: [ 0.001180] Calibrating delay loop... 898.66 BogoMIPS (lpj=4493312)
Feb 8 04:17:20 garden kernel: [ 0.090427] pid_max: default: 32768 minimum: 301
Feb 8 04:17:20 garden kernel: [ 0.090918] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
Feb 8 04:17:20 garden kernel: [ 0.090973] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
Feb 8 04:17:20 garden kernel: [ 0.092259] CPU: Testing write buffer coherency: ok
Feb 8 04:17:20 garden kernel: [ 0.093522] Setting up static identity map for 0x8200 - 0x8238
Feb 8 04:17:20 garden kernel: [ 0.094808] devtmpfs: initialized
Feb 8 04:17:20 garden kernel: [ 0.104350] VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5
Feb 8 04:17:20 garden kernel: [ 0.104792] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
Feb 8 04:17:20 garden kernel: [ 0.104859] futex hash table entries: 256 (order: -1, 3072 bytes)
Feb 8 04:17:20 garden kernel: [ 0.106096] pinctrl core: initialized pinctrl subsystem
Feb 8 04:17:20 garden kernel: [ 0.107588] NET: Registered protocol family 16
Feb 8 04:17:20 garden kernel: [ 0.110514] DMA: preallocated 1024 KiB pool for atomic coherent allocations
Feb 8 04:17:20 garden kernel: [ 0.116668] hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
Feb 8 04:17:20 garden kernel: [ 0.116738] hw-breakpoint: maximum watchpoint size is 4 bytes.
Feb 8 04:17:20 garden kernel: [ 0.116885] Serial: AMBA PL011 UART driver
Feb 8 04:17:20 garden kernel: [ 0.119940] bcm2835-mbox 2000b880.mailbox: mailbox enabled
Feb 8 04:17:20 garden kernel: [ 0.140666] raspberrypi-firmware soc:firmware: Attached to firmware from 2020-01-30 13:52, variant start_cd
Feb 8 04:17:20 garden kernel: [ 0.150690] raspberrypi-firmware soc:firmware: Firmware hash is 53a54c770c493957d99bf49762dfabc4eee00e45
Feb 8 04:17:20 garden kernel: [ 0.196094] bcm2835-dma 20007000.dma: DMA legacy API manager at (ptrval), dmachans=0x1
Feb 8 04:17:20 garden kernel: [ 0.198431] SCSI subsystem initialized
Feb 8 04:17:20 garden kernel: [ 0.198730] usbcore: registered new interface driver usbfs
Feb 8 04:17:20 garden kernel: [ 0.198858] usbcore: registered new interface driver hub
Feb 8 04:17:20 garden kernel: [ 0.199098] usbcore: registered new device driver usb
Feb 8 04:17:20 garden kernel: [ 0.201341] clocksource: Switched to clocksource timer
Feb 8 04:17:20 garden kernel: [ 0.292847] VFS: Disk quotas dquot_6.6.0
Feb 8 04:17:20 garden kernel: [ 0.293018] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
Feb 8 04:17:20 garden kernel: [ 0.293342] FS-Cache: Loaded
Feb 8 04:17:20 garden kernel: [ 0.293695] CacheFiles: Loaded
Feb 8 04:17:20 garden kernel: [ 0.311437] NET: Registered protocol family 2
Feb 8 04:17:20 garden kernel: [ 0.312684] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 4096 bytes)
Feb 8 04:17:20 garden kernel: [ 0.312798] TCP established hash table entries: 2048 (order: 1, 8192 bytes)
Feb 8 04:17:20 garden kernel: [ 0.312865] TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
Feb 8 04:17:20 garden kernel: [ 0.312928] TCP: Hash tables configured (established 2048 bind 2048)
Feb 8 04:17:20 garden kernel: [ 0.313118] UDP hash table entries: 256 (order: 0, 4096 bytes)
Feb 8 04:17:20 garden kernel: [ 0.313179] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
Feb 8 04:17:20 garden kernel: [ 0.313586] NET: Registered protocol family 1
Feb 8 04:17:20 garden kernel: [ 0.314641] RPC: Registered named UNIX socket transport module.
Feb 8 04:17:20 garden kernel: [ 0.314699] RPC: Registered udp transport module.
Feb 8 04:17:20 garden kernel: [ 0.314724] RPC: Registered tcp transport module.
Feb 8 04:17:20 garden kernel: [ 0.314746] RPC: Registered tcp NFSv4.1 backchannel transport module.
Feb 8 04:17:20 garden kernel: [ 0.316731] hw perfevents: no irqs for PMU, sampling events not supported
Feb 8 04:17:20 garden kernel: [ 0.316846] hw perfevents: enabled with armv6_1176 PMU driver, 3 counters available
Feb 8 04:17:20 garden kernel: [ 0.320876] Initialise system trusted keyrings
Feb 8 04:17:20 garden kernel: [ 0.321308] workingset: timestamp_bits=14 max_order=16 bucket_order=2
Feb 8 04:17:20 garden kernel: [ 0.335511] FS-Cache: Netfs 'nfs' registered for caching
Feb 8 04:17:20 garden kernel: [ 0.336810] NFS: Registering the id_resolver key type
Feb 8 04:17:20 garden kernel: [ 0.336900] Key type id_resolver registered
Feb 8 04:17:20 garden kernel: [ 0.336929] Key type id_legacy registered
Feb 8 04:17:20 garden kernel: [ 0.336973] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
Feb 8 04:17:20 garden kernel: [ 0.342264] Key type asymmetric registered
Feb 8 04:17:20 garden kernel: [ 0.342329] Asymmetric key parser 'x509' registered
Feb 8 04:17:20 garden kernel: [ 0.342454] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
Feb 8 04:17:20 garden kernel: [ 0.342922] io scheduler noop registered
Feb 8 04:17:20 garden kernel: [ 0.342973] io scheduler deadline registered (default)
Feb 8 04:17:20 garden kernel: [ 0.343556] io scheduler cfq registered
Feb 8 04:17:20 garden kernel: [ 0.343603] io scheduler mq-deadline registered (default)
Feb 8 04:17:20 garden kernel: [ 0.343631] io scheduler kyber registered
Feb 8 04:17:20 garden kernel: [ 0.346216] bcm2708_fb soc:fb: FB found 1 display(s)
Feb 8 04:17:20 garden kernel: [ 0.349032] Console: switching to colour frame buffer device 2x2
Feb 8 04:17:20 garden kernel: [ 0.349980] bcm2708_fb soc:fb: Registered framebuffer for display 0, size 16x16
Feb 8 04:17:20 garden kernel: [ 0.353874] bcm2835-rng 20104000.rng: hwrng registered
Feb 8 04:17:20 garden kernel: [ 0.354619] vc-mem: phys_addr:0x00000000 mem_base=0x0fa00000 mem_size:0x10000000(256 MiB)
Feb 8 04:17:20 garden kernel: [ 0.356148] vc-sm: Videocore shared memory driver
Feb 8 04:17:20 garden kernel: [ 0.357068] gpiomem-bcm2835 20200000.gpiomem: Initialised: Registers at 0x20200000
Feb 8 04:17:20 garden kernel: [ 0.376245] brd: module loaded
Feb 8 04:17:20 garden kernel: [ 0.388881] loop: module loaded
Feb 8 04:17:20 garden kernel: [ 0.389915] Loading iSCSI transport class v2.0-870.
Feb 8 04:17:20 garden kernel: [ 0.391156] usbcore: registered new interface driver smsc95xx
Feb 8 04:17:20 garden kernel: [ 0.391647] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
Feb 8 04:17:20 garden kernel: [ 0.420034] dwc_otg 20980000.usb: base=(ptrval)
Feb 8 04:17:20 garden kernel: [ 0.620965] Core Release: 2.80a
Feb 8 04:17:20 garden kernel: [ 0.621202] Setting default values for core params
Feb 8 04:17:20 garden kernel: [ 0.621590] Finished setting default values for core params
Feb 8 04:17:20 garden kernel: [ 0.822495] Using Buffer DMA mode
Feb 8 04:17:20 garden kernel: [ 0.822732] Periodic Transfer Interrupt Enhancement - disabled
Feb 8 04:17:20 garden kernel: [ 0.823075] Multiprocessor Interrupt Enhancement - disabled
Feb 8 04:17:20 garden systemd[1]: tmp.mount: Directory /tmp to mount over is not empty, mounting anyway.
Feb 8 04:17:20 garden systemd[1]: Mounting /tmp...
Feb 8 04:17:20 garden systemd[1]: Mounting /var/data...
Feb 8 04:17:20 garden systemd[1]: Mounted /DietPi.
Feb 8 04:17:20 garden systemd[1]: Mounted /tmp.
Feb 8 04:17:20 garden systemd[1]: Mounted /var/data.
Feb 8 04:17:20 garden systemd[1]: Started udev Kernel Device Manager.
Feb 8 04:17:20 garden systemd-udevd[132]: Using default interface naming scheme 'v240'.
Feb 8 04:17:20 garden systemd[1]: Found device /dev/disk/by-partuuid/cb7b86f7-01.
Feb 8 04:17:20 garden systemd[1]: Starting File System Check on /dev/disk/by-partuuid/cb7b86f7-01...
Feb 8 04:17:20 garden systemd-fsck[174]: fsck.fat 4.1 (2017-01-24)
Feb 8 04:17:20 garden systemd-fsck[174]: 0x41: Dirty bit is set. Fs was not properly unmounted and some data may be corrupt.
Feb 8 04:17:20 garden systemd-fsck[174]: Automatically removing dirty bit.
Feb 8 04:17:20 garden systemd-fsck[174]: Performing changes.
Feb 8 04:17:20 garden systemd-fsck[174]: /dev/mmcblk0p1: 293 files, 109791/516191 clusters
Feb 8 04:17:20 garden systemd[1]: Started File System Check on /dev/disk/by-partuuid/cb7b86f7-01.
Feb 8 04:17:20 garden systemd-udevd[130]: Using default interface naming scheme 'v240'.
Feb 8 04:17:20 garden systemd-udevd[130]: Process '/sbin/iwconfig wlan0 power off' failed with exit code 250.
Feb 8 04:17:20 garden systemd[1]: Mounting /boot...
Feb 8 04:17:20 garden systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
Feb 8 04:17:20 garden systemd[1]: Starting Load/Save RF Kill Switch Status...
Feb 8 04:17:20 garden systemd[1]: Mounted /boot.
Feb 8 04:17:20 garden systemd[1]: Started Load/Save RF Kill Switch Status.
Feb 8 04:17:20 garden systemd[1]: Reached target Local File Systems.
Feb 8 04:17:20 garden systemd[1]: Starting Set console font and keymap...
Feb 8 04:17:20 garden systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
Feb 8 04:17:20 garden systemd[1]: Starting Create Volatile Files and Directories...
Feb 8 04:17:20 garden systemd[1]: Started Set console font and keymap.
Feb 8 04:17:20 garden systemd[1]: Found device AR9271 802.11n.
Feb 8 04:17:20 garden systemd[1]: Started Create Volatile Files and Directories.
Feb 8 04:17:20 garden systemd[1]: Starting Update UTMP about System Boot/Shutdown...
Feb 8 04:17:20 garden systemd[1]: Starting Network Time Synchronization...
Feb 8 04:17:20 garden systemd[1]: Started Update UTMP about System Boot/Shutdown.
Feb 8 04:17:20 garden systemd[1]: Started Network Time Synchronization.
Feb 8 04:17:20 garden kernel: [ 0.823398] OTG VER PARAM: 0, OTG VER FLAG: 0
Feb 8 04:17:20 garden kernel: [ 0.823740] Dedicated Tx FIFOs mode
Feb 8 04:17:20 garden kernel: [ 0.824717] WARN::dwc_otg_hcd_init:1074: FIQ DMA bounce buffers: virt = ce514000 dma = 0x4e514000 len=9024
Feb 8 04:17:20 garden kernel: [ 0.825325] FIQ FSM acceleration enabled for :
Feb 8 04:17:20 garden kernel: [ 0.825325] Non-periodic Split Transactions
Feb 8 04:17:20 garden kernel: [ 0.825325] Periodic Split Transactions
Feb 8 04:17:20 garden kernel: [ 0.825325] High-Speed Isochronous Endpoints
Feb 8 04:17:20 garden kernel: [ 0.825325] Interrupt/Control Split Transaction hack enabled
Feb 8 04:17:20 garden kernel: [ 0.826737] WARN::hcd_init_fiq:457: FIQ on core 0
Feb 8 04:17:20 garden kernel: [ 0.827044] WARN::hcd_init_fiq:458: FIQ ASM at c0526db4 length 36
Feb 8 04:17:20 garden kernel: [ 0.827409] WARN::hcd_init_fiq:497: MPHI regs_base at cf810000
Feb 8 04:17:20 garden kernel: [ 0.827781] dwc_otg 20980000.usb: DWC OTG Controller
Feb 8 04:17:20 garden kernel: [ 0.828140] dwc_otg 20980000.usb: new USB bus registered, assigned bus number 1
Feb 8 04:17:20 garden kernel: [ 0.828626] dwc_otg 20980000.usb: irq 56, io mem 0x00000000
Feb 8 04:17:20 garden kernel: [ 0.828993] Init: Port Power? op_state=1
Feb 8 04:17:20 garden kernel: [ 0.829232] Init: Power Port (0)
Feb 8 04:17:20 garden kernel: [ 0.829798] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
Feb 8 04:17:20 garden kernel: [ 0.830301] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Feb 8 04:17:20 garden kernel: [ 0.830718] usb usb1: Product: DWC OTG Controller
Feb 8 04:17:20 garden kernel: [ 0.830997] usb usb1: Manufacturer: Linux 4.19.97+ dwc_otg_hcd
Feb 8 04:17:20 garden kernel: [ 0.831428] usb usb1: SerialNumber: 20980000.usb
Feb 8 04:17:20 garden kernel: [ 0.832785] hub 1-0:1.0: USB hub found
Feb 8 04:17:20 garden kernel: [ 0.833141] hub 1-0:1.0: 1 port detected
Feb 8 04:17:20 garden kernel: [ 0.834969] usbcore: registered new interface driver usb-storage
Feb 8 04:17:20 garden kernel: [ 0.835810] mousedev: PS/2 mouse device common for all mice
Feb 8 04:17:20 garden kernel: [ 0.837451] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
Feb 8 04:17:20 garden kernel: [ 0.838269] bcm2835-cpufreq: min=700000 max=900000
Feb 8 04:17:20 garden kernel: [ 0.839798] sdhci: Secure Digital Host Controller Interface driver
Feb 8 04:17:20 garden kernel: [ 0.840196] sdhci: Copyright(c) Pierre Ossman
Feb 8 04:17:20 garden kernel: [ 0.841086] sdhost-bcm2835 20202000.mmc: could not get clk, deferring probe
Feb 8 04:17:20 garden kernel: [ 0.841854] sdhci-pltfm: SDHCI platform and OF driver helper
Feb 8 04:17:20 garden kernel: [ 0.842828] ledtrig-cpu: registered to indicate activity on CPUs
Feb 8 04:17:20 garden kernel: [ 0.843337] hidraw: raw HID events driver (C) Jiri Kosina
Feb 8 04:17:20 garden kernel: [ 0.843902] usbcore: registered new interface driver usbhid
Feb 8 04:17:20 garden kernel: [ 0.844245] usbhid: USB HID core driver
Feb 8 04:17:20 garden kernel: [ 0.845480] vchiq: vchiq_init_state: slot_zero = (ptrval), is_master = 0
Feb 8 04:17:20 garden kernel: [ 0.847874] [vc_sm_connected_init]: start
Feb 8 04:17:20 garden kernel: [ 0.851684] vc_vchi_sm_init: failed to open VCHI service (-1)
Feb 8 04:17:20 garden kernel: [ 0.851699] [vc_sm_connected_init]: failed to initialize shared memory service
Feb 8 04:17:20 garden kernel: [ 0.852497] [vc_sm_connected_init]: end - returning -1
Feb 8 04:17:20 garden kernel: [ 0.854501] Initializing XFRM netlink socket
Feb 8 04:17:20 garden kernel: [ 0.854877] NET: Registered protocol family 17
Feb 8 04:17:20 garden kernel: [ 0.855300] Key type dns_resolver registered
Feb 8 04:17:20 garden kernel: [ 0.857292] registered taskstats version 1
Feb 8 04:17:20 garden kernel: [ 0.857601] Loading compiled-in X.509 certificates
Feb 8 04:17:20 garden kernel: [ 0.869124] sdhost: log_buf @ (ptrval) (4e513000)
Feb 8 04:17:20 garden kernel: [ 0.912306] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
Feb 8 04:17:20 garden kernel: [ 0.930063] of_cfs_init
Feb 8 04:17:20 garden kernel: [ 0.930430] of_cfs_init: OK
Feb 8 04:17:20 garden kernel: [ 0.931485] Waiting 10 sec before mounting root device...
Feb 8 04:17:20 garden kernel: [ 0.940956] random: fast init done
Feb 8 04:17:20 garden kernel: [ 0.969053] mmc0: host does not support reading read-only switch, assuming write-enable
Feb 8 04:17:20 garden kernel: [ 0.972260] mmc0: new high speed SDHC card at address 59b4
Feb 8 04:17:20 garden kernel: [ 0.974103] mmcblk0: mmc0:59b4 00000 7.35 GiB
Feb 8 04:17:20 garden kernel: [ 0.976797] mmcblk0: p1 p2
Feb 8 04:17:20 garden kernel: [ 1.051627] Indeed it is in host mode hprt0 = 00021501
Feb 8 04:17:20 garden kernel: [ 1.241428] usb 1-1: new high-speed USB device number 2 using dwc_otg
Feb 8 04:17:20 garden kernel: [ 1.242045] Indeed it is in host mode hprt0 = 00001101
Feb 8 04:17:20 garden kernel: [ 1.461847] usb 1-1: New USB device found, idVendor=0424, idProduct=9512, bcdDevice= 2.00
Feb 8 04:17:20 garden kernel: [ 1.462409] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Feb 8 04:17:20 garden kernel: [ 1.464002] hub 1-1:1.0: USB hub found
Feb 8 04:17:20 garden kernel: [ 1.464445] hub 1-1:1.0: 3 ports detected
Feb 8 04:17:20 garden kernel: [ 1.781431] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
Feb 8 04:17:20 garden kernel: [ 1.911832] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00, bcdDevice= 2.00
Feb 8 04:17:20 garden kernel: [ 1.912373] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Feb 8 04:17:20 garden kernel: [ 1.915918] smsc95xx v1.0.6
Feb 8 04:17:20 garden kernel: [ 2.006707] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-20980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:9c:fa:95
Feb 8 04:17:20 garden kernel: [ 2.101417] usb 1-1.2: new high-speed USB device number 4 using dwc_otg
Feb 8 04:17:20 garden kernel: [ 2.232314] usb 1-1.2: New USB device found, idVendor=0781, idProduct=5571, bcdDevice= 1.00
Feb 8 04:17:20 garden kernel: [ 2.232855] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Feb 8 04:17:20 garden kernel: [ 2.233291] usb 1-1.2: Product: Cruzer Fit
Feb 8 04:17:20 garden kernel: [ 2.233548] usb 1-1.2: Manufacturer: SanDisk'
Feb 8 04:17:20 garden kernel: [ 2.233818] usb 1-1.2: SerialNumber: 4C530000050412116035
Feb 8 04:17:20 garden kernel: [ 2.235258] usb-storage 1-1.2:1.0: USB Mass Storage device detected
Feb 8 04:17:20 garden kernel: [ 2.236786] scsi host0: usb-storage 1-1.2:1.0
Feb 8 04:17:20 garden kernel: [ 2.331415] usb 1-1.3: new high-speed USB device number 5 using dwc_otg
Feb 8 04:17:20 garden kernel: [ 2.482593] usb 1-1.3: New USB device found, idVendor=0cf3, idProduct=9271, bcdDevice= 1.08
Feb 8 04:17:20 garden kernel: [ 2.483133] usb 1-1.3: New USB device strings: Mfr=16, Product=32, SerialNumber=48
Feb 8 04:17:20 garden systemd[1]: Reached target System Initialization.
Feb 8 04:17:20 garden systemd[1]: Started Daily Cleanup of Temporary Directories.
Feb 8 04:17:20 garden systemd[1]: Listening on D-Bus System Message Bus Socket.
Feb 8 04:17:20 garden systemd[1]: Reached target Sockets.
Feb 8 04:17:20 garden systemd[1]: Reached target Basic System.
Feb 8 04:17:20 garden systemd[1]: Starting rng-tools.service...
Feb 8 04:17:20 garden systemd[1]: Started D-Bus System Message Bus.
Feb 8 04:17:20 garden rng-tools[205]: Starting Hardware RNG entropy gatherer daemon: rngd.
Feb 8 04:17:20 garden rngd[208]: rngd 2-unofficial-mt.14 starting up...
Feb 8 04:17:20 garden systemd[1]: Condition check resulted in Turn on SSH if /boot/ssh is present being skipped.
Feb 8 04:17:20 garden systemd[1]: Starting DietPi-RAMdisk...
Feb 8 04:17:20 garden rngd[208]: entropy feed to the kernel ready
Feb 8 04:17:20 garden systemd[1]: Reached target System Time Synchronized.
Feb 8 04:17:20 garden systemd[1]: Started Daily rotation of log files.
Feb 8 04:17:20 garden systemd[1]: Reached target Timers.
Feb 8 04:17:20 garden systemd[1]: Started rng-tools.service.
Feb 8 04:17:20 garden systemd[1]: systemd-rfkill.service: Succeeded.
Feb 8 04:17:20 garden systemd[1]: Started DietPi-RAMdisk.
Feb 8 04:17:20 garden systemd[1]: Starting System Logging Service...
Feb 8 04:17:20 garden systemd[1]: Starting DietPi-PreBoot...
Feb 8 04:17:20 garden systemd[1]: Started System Logging Service.
Feb 8 04:17:20 garden rsyslogd: imuxsock: Acquired UNIX socket '/run/systemd/journal/syslog' (fd 3) from systemd. [v8.1901.0]
Feb 8 04:17:20 garden rsyslogd: [origin software="rsyslogd" swVersion="8.1901.0" x-pid="225" x-info="https://www.rsyslog.com"] start
Feb 8 04:17:20 garden kernel: [ 2.483594] usb 1-1.3: Product: USB2.0 WLAN
Feb 8 04:17:20 garden kernel: [ 2.483854] usb 1-1.3: Manufacturer: ATHEROS
Feb 8 04:17:20 garden kernel: [ 2.484120] usb 1-1.3: SerialNumber: 12345
Feb 8 04:17:20 garden kernel: [ 3.282953] scsi 0:0:0:0: Direct-Access SanDisk' Cruzer Fit 1.00 PQ: 0 ANSI: 6
Feb 8 04:17:20 garden kernel: [ 3.285637] sd 0:0:0:0: [sda] 30031872 512-byte logical blocks: (15.4 GB/14.3 GiB)
Feb 8 04:17:20 garden kernel: [ 3.287589] sd 0:0:0:0: [sda] Write Protect is off
Feb 8 04:17:20 garden kernel: [ 3.288666] sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
Feb 8 04:17:20 garden kernel: [ 3.352965] sda: sda1
Feb 8 04:17:20 garden kernel: [ 3.358810] sd 0:0:0:0: [sda] Attached SCSI removable disk
Feb 8 04:17:20 garden kernel: [ 11.367691] EXT4-fs (sda1): INFO: recovery required on readonly filesystem
Feb 8 04:17:20 garden kernel: [ 11.368163] EXT4-fs (sda1): write access will be enabled during recovery
Feb 8 04:17:20 garden kernel: [ 12.367686] EXT4-fs (sda1): orphan cleanup on readonly fs
Feb 8 04:17:20 garden kernel: [ 12.404211] EXT4-fs (sda1): 5 orphan inodes deleted
Feb 8 04:17:20 garden kernel: [ 12.404567] EXT4-fs (sda1): recovery complete
Feb 8 04:17:20 garden kernel: [ 12.430396] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
Feb 8 04:17:20 garden kernel: [ 12.430986] VFS: Mounted root (ext4 filesystem) readonly on device 8:1.
Feb 8 04:17:20 garden kernel: [ 12.455840] devtmpfs: mounted
Feb 8 04:17:20 garden kernel: [ 12.460189] Freeing unused kernel memory: 472K
Feb 8 04:17:20 garden kernel: [ 12.460502] This architecture does not have kernel memory protection.
Feb 8 04:17:20 garden kernel: [ 12.460885] Run /sbin/init as init process
Feb 8 04:17:20 garden kernel: [ 13.784144] NET: Registered protocol family 10
Feb 8 04:17:20 garden kernel: [ 13.786596] Segment Routing with IPv6
Feb 8 04:17:20 garden kernel: [ 15.566863] random: crng init done
Feb 8 04:17:20 garden kernel: [ 17.360132] i2c /dev entries driver
Feb 8 04:17:20 garden kernel: [ 20.564288] EXT4-fs (sda1): re-mounted. Opts: (null)
Feb 8 04:17:20 garden kernel: [ 22.828466] Driver for 1-wire Dallas network protocol.
Feb 8 04:17:20 garden kernel: [ 22.863192] gpio-4 (onewire@4): enforced open drain please flag it properly in DT/ACPI DSDT/board file
Feb 8 04:17:20 garden kernel: [ 22.946478] w1_master_driver w1_bus_master1: Attaching one wire slave 28.031661a80eff crc f5
Feb 8 04:17:20 garden kernel: [ 23.058961] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
Feb 8 04:17:20 garden kernel: [ 23.102169] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
Feb 8 04:17:20 garden kernel: [ 23.102196] [vc_sm_connected_init]: start
Feb 8 04:17:20 garden kernel: [ 23.102475] vc_sm_cma_vchi_init: failed to open VCHI service (-1)
Feb 8 04:17:20 garden kernel: [ 23.102487] [vc_sm_connected_init]: failed to initialize shared memory service
Feb 8 04:17:20 garden kernel: [ 24.106835] usbcore: registered new interface driver uas
Feb 8 04:17:20 garden kernel: [ 24.607075] sd 0:0:0:0: Attached scsi generic sg0 type 0
Feb 8 04:17:20 garden kernel: [ 25.239468] cfg80211: Loading compiled-in X.509 certificates for regulatory database
Feb 8 04:17:20 garden kernel: [ 25.655933] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
Feb 8 04:17:20 garden kernel: [ 27.357508] usb 1-1.3: ath9k_htc: Firmware ath9k_htc/htc_9271-1.4.0.fw requested
Feb 8 04:17:20 garden kernel: [ 27.380636] usbcore: registered new interface driver ath9k_htc
Feb 8 04:17:20 garden kernel: [ 27.645250] usb 1-1.3: ath9k_htc: Transferred FW: ath9k_htc/htc_9271-1.4.0.fw, size: 51008
Feb 8 04:17:20 garden kernel: [ 27.904795] ath9k_htc 1-1.3:1.0: ath9k_htc: HTC initialized with 33 credits
Feb 8 04:17:20 garden kernel: [ 28.340940] ath9k_htc 1-1.3:1.0: ath9k_htc: FW Version: 1.4
Feb 8 04:17:20 garden kernel: [ 28.341000] ath9k_htc 1-1.3:1.0: FW RMW support: On
Feb 8 04:17:20 garden kernel: [ 28.752576] ieee80211 phy0: Atheros AR9271 Rev:1
Feb 8 04:17:24 garden systemd[1]: Started DietPi-PreBoot.
Feb 8 04:17:24 garden systemd[1]: Reached target Network (Pre).
Feb 8 04:17:24 garden systemd[1]: Started ifup for wlan0.
Feb 8 04:17:24 garden systemd[1]: Starting Raise network interfaces...
Feb 8 04:17:25 garden wpa_supplicant[339]: Successfully initialized wpa_supplicant
Feb 8 04:17:26 garden systemd[1]: Started Raise network interfaces.
Feb 8 04:17:26 garden systemd[1]: Reached target Network.
Feb 8 04:17:26 garden systemd[1]: Starting DietPi-Boot...
Feb 8 04:17:26 garden systemd[1]: Condition check resulted in fast remote file copy program daemon being skipped.
Feb 8 04:17:26 garden systemd[1]: Starting Permit User Sessions...
Feb 8 04:17:26 garden systemd[1]: Reached target Network is Online.
Feb 8 04:17:26 garden systemd[1]: Starting /etc/rc.local Compatibility...
Feb 8 04:17:26 garden systemd[1]: Started Permit User Sessions.
Feb 8 04:17:27 garden systemd[1]: Started /etc/rc.local Compatibility.
Feb 8 04:17:27 garden wpa_supplicant[392]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=USER type=COUNTRY alpha2=GB
Feb 8 04:17:28 garden dhclient[421]: Internet Systems Consortium DHCP Client 4.4.1
Feb 8 04:17:28 garden dhclient[421]: Copyright 2004-2018 Internet Systems Consortium.
Feb 8 04:17:28 garden sh[317]: Internet Systems Consortium DHCP Client 4.4.1
Feb 8 04:17:28 garden sh[317]: Copyright 2004-2018 Internet Systems Consortium.
Feb 8 04:17:28 garden sh[317]: All rights reserved.
Feb 8 04:17:28 garden sh[317]: For info, please visit https://www.isc.org/software/dhcp/
Feb 8 04:17:28 garden dhclient[421]: All rights reserved.
Feb 8 04:17:28 garden dhclient[421]: For info, please visit https://www.isc.org/software/dhcp/
Feb 8 04:17:29 garden dhclient[421]: Listening on LPF/wlan0/18:d6:c7:10:f6:2d
Feb 8 04:17:29 garden sh[317]: Listening on LPF/wlan0/18:d6:c7:10:f6:2d
Feb 8 04:17:29 garden sh[317]: Sending on LPF/wlan0/18:d6:c7:10:f6:2d
Feb 8 04:17:29 garden sh[317]: Sending on Socket/fallback
Feb 8 04:17:29 garden dhclient[421]: Sending on LPF/wlan0/18:d6:c7:10:f6:2d
Feb 8 04:17:29 garden sh[317]: DHCPREQUEST for 10.10.1.55 on wlan0 to 255.255.255.255 port 67
Feb 8 04:17:29 garden dhclient[421]: Sending on Socket/fallback
Feb 8 04:17:29 garden dhclient[421]: DHCPREQUEST for 10.10.1.55 on wlan0 to 255.255.255.255 port 67
Feb 8 04:17:29 garden kernel: [ 46.126226] wlan0: authenticate with 14:cc:20:97:da:b2
Feb 8 04:17:29 garden wpa_supplicant[392]: wlan0: SME: Trying to authenticate with 14:cc:20:97:da:b2 (SSID='makova.cz' freq=2462 MHz)
Feb 8 04:17:30 garden systemd[1]: Stopping Network Time Synchronization...
Feb 8 04:17:30 garden kernel: [ 46.701122] wlan0: send auth to 14:cc:20:97:da:b2 (try 1/3)
Feb 8 04:17:30 garden wpa_supplicant[392]: wlan0: Trying to associate with 14:cc:20:97:da:b2 (SSID='makova.cz' freq=2462 MHz)
Feb 8 04:17:30 garden kernel: [ 46.706102] wlan0: authenticated
Feb 8 04:17:30 garden kernel: [ 46.711575] wlan0: associate with 14:cc:20:97:da:b2 (try 1/3)
Feb 8 04:17:30 garden kernel: [ 46.715864] wlan0: RX AssocResp from 14:cc:20:97:da:b2 (capab=0x31 status=0 aid=5)
Feb 8 04:17:30 garden kernel: [ 46.727000] wlan0: associated
Feb 8 04:17:30 garden wpa_supplicant[392]: wlan0: Associated with 14:cc:20:97:da:b2
Feb 8 04:17:30 garden wpa_supplicant[392]: wlan0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
Feb 8 04:17:30 garden systemd[1]: systemd-timesyncd.service: Succeeded.
Feb 8 04:17:30 garden wpa_supplicant[392]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=COUNTRY_IE type=COUNTRY alpha2=CZ
Feb 8 04:17:30 garden systemd[1]: Stopped Network Time Synchronization.
Feb 8 04:17:30 garden systemd[1]: Starting Network Time Synchronization...
Feb 8 04:17:31 garden wpa_supplicant[392]: wlan0: WPA: Key negotiation completed with 14:cc:20:97:da:b2 [PTK=CCMP GTK=CCMP]
Feb 8 04:17:31 garden wpa_supplicant[392]: wlan0: CTRL-EVENT-CONNECTED - Connection to 14:cc:20:97:da:b2 completed [id=0 id_str=]
Feb 8 04:17:31 garden systemd[1]: Started Network Time Synchronization.
Feb 8 04:17:37 garden dhclient[421]: DHCPREQUEST for 10.10.1.55 on wlan0 to 255.255.255.255 port 67
Feb 8 04:17:37 garden sh[317]: DHCPREQUEST for 10.10.1.55 on wlan0 to 255.255.255.255 port 67
Feb 8 04:17:37 garden dhclient[421]: DHCPACK of 10.10.1.55 from 10.10.1.1
Feb 8 04:17:37 garden sh[317]: DHCPACK of 10.10.1.55 from 10.10.1.1
Feb 8 04:17:38 garden dhclient[421]: bound to 10.10.1.55 -- renewal in 34274 seconds.
Feb 8 04:17:38 garden sh[317]: bound to 10.10.1.55 -- renewal in 34274 seconds.
Feb 8 04:17:39 garden sh[317]: wlan0=wlan0
Feb 8 04:17:43 garden systemd[1]: systemd-fsckd.service: Succeeded.
Feb 8 09:04:11 garden systemd-timesyncd[448]: Synchronized to time server for the first time 10.10.1.10:123 (10.10.1.10).
Feb 8 09:04:11 garden systemd[1]: Started DietPi-Boot.
Feb 8 09:04:11 garden systemd[1]: Started DietPi-PostBoot.
Feb 8 04:10:58 garden wpa_supplicant[32338]: wlan0: CTRL-EVENT-BEACON-LOSS
Feb 8 04:11:02 garden wpa_supplicant[32338]: wlan0: CTRL-EVENT-BEACON-LOSS
Feb 8 04:11:03 garden wpa_supplicant[32338]: wlan0: CTRL-EVENT-BEACON-LOSS
Feb 8 04:11:08 garden wpa_supplicant[32338]: wlan0: CTRL-EVENT-BEACON-LOSS
Feb 8 04:11:12 garden wpa_supplicant[32338]: wlan0: CTRL-EVENT-BEACON-LOSS
Feb 8 04:11:13 garden wpa_supplicant[32338]: wlan0: CTRL-EVENT-BEACON-LOSS
Feb 8 04:11:17 garden wpa_supplicant[32338]: wlan0: CTRL-EVENT-BEACON-LOSS
Feb 8 04:11:21 garden wpa_supplicant[32338]: wlan0: CTRL-EVENT-BEACON-LOSS
Feb 8 04:11:30 garden wpa_supplicant[32338]: wlan0: CTRL-EVENT-BEACON-LOSS
Feb 8 04:11:31 garden wpa_supplicant[32338]: wlan0: CTRL-EVENT-BEACON-LOSS
Feb 8 04:11:43 garden wpa_supplicant[32338]: wlan0: CTRL-EVENT-BEACON-LOSS
Feb 8 04:12:22 garden wpa_supplicant[32338]: wlan0: CTRL-EVENT-BEACON-LOSS
Feb 8 04:12:28 garden wpa_supplicant[32338]: wlan0: CTRL-EVENT-BEACON-LOSS
Feb 8 04:12:36 garden wpa_supplicant[32338]: wlan0: CTRL-EVENT-BEACON-LOSS
Feb 8 04:13:59 garden wpa_supplicant[32338]: wlan0: CTRL-EVENT-BEACON-LOSS
Feb 8 04:14:01 garden wpa_supplicant[32338]: wlan0: CTRL-EVENT-BEACON-LOSS
Feb 8 04:14:04 garden wpa_supplicant[32338]: wlan0: CTRL-EVENT-BEACON-LOSS
Feb 8 04:14:51 garden wpa_supplicant[32338]: wlan0: CTRL-EVENT-BEACON-LOSS
Feb 8 04:15:05 garden wpa_supplicant[32338]: wlan0: CTRL-EVENT-BEACON-LOSS
Feb 8 04:15:56 garden wpa_supplicant[32338]: wlan0: CTRL-EVENT-BEACON-LOSS
Feb 8 04:15:59 garden wpa_supplicant[32338]: wlan0: CTRL-EVENT-BEACON-LOSS
Feb 8 04:16:00 garden wpa_supplicant[32338]: wlan0: CTRL-EVENT-BEACON-LOSS
Feb 8 04:16:18 garden wpa_supplicant[32338]: wlan0: CTRL-EVENT-BEACON-LOSS
Feb 8 04:16:19 garden wpa_supplicant[32338]: wlan0: CTRL-EVENT-BEACON-LOSS
Feb 8 04:16:32 garden wpa_supplicant[32338]: wlan0: CTRL-EVENT-BEACON-LOSS
Feb 8 04:16:37 garden wpa_supplicant[32338]: wlan0: CTRL-EVENT-BEACON-LOSS
Feb 8 04:16:40 garden wpa_supplicant[32338]: wlan0: CTRL-EVENT-BEACON-LOSS
just to avoid a misunderstanding regarding the 17th minute time stamp. As explained by @MichaIng yesterday, this is coming from the fact that fake-hwclock is saving a timestamp down to disk every hour. This timestamp is used in case of restarts to set an initial time on the device. Time will be corrected as soon as time-sync finished on reboot.
in your syslog you see this line, means time is set on reboot by fake-hwclock
furthermore you see the time jumping backwards in syslog as well due to fake-hwclock
some python script are executed at 4:27, than your system stuck.
During reboot system time was changed back to 4:17
It was corrected as soon as time-sync finished on boot.
so looks like your system get stuck somewhere after 4:27 and just became available again after your power off/on at 9:04.
same you can see in daemon.log. There you have quite a lot of WiFi issues as well starting 4:10 before it stopped at 4:25
so we need to find out why you have this
