How can I secure connection to nextcloud?
JohnDoeFR
Re: How can I secure connection to nextcloud?
Post by JohnDoeFR »
Yes it is, but the VPN is running on the Dietpi, and keep returning me error when I want to make the certificate
ah yeah that's the challenge. There is no option to stop the VPN for a moment and create the cert?
JohnDoeFR
Post by JohnDoeFR »
Didn't think about it -_-
Going to try right now
Maybe you would need to trigger NoIP client again to have the correct IP assigned. Better to crosscheck on NoIP Website that :)
JohnDoeFR
Post by JohnDoeFR »
It doesn't work neither, maybe port opening ? DDNS update ?
yes, you would need to have port 80/443 TCP open. And check that DDNS is correctly updated.
JohnDoeFR
Post by JohnDoeFR »
I've rerun the NO-IP, but concerning the port opening, on my router it's fine or there is something to do on the rasp ?
JohnDoeFR
Post by JohnDoeFR »
OK so with port forwarding I can connect VIA the DDNS to the nextcloud, that's cool, BUT, I can't edit the certificate :
[FAILURE] Certbot failed with error code (1), please check its terminal output. Aborting...
you just need to ensure that port 80/443 TCP are forwarded from your router to your DietPi device.
Edit: what is the exact error message?
JohnDoeFR
Post by JohnDoeFR »
