@Joulinar
is there any reason to switch to bullseye? In the meantime there is the second update for WireGuard and not even the older update is available on bullseye, in software development these are light years.
WireGuard Updates not available Topic is solved
Re: WireGuard Updates not available
well if I check my available updates, I see the "old second" packages available. So they are there.
same one the Debian package website
https://packages.debian.org/en/bullseye/wireguard-dkms
The latest updates that are released by Wireguard 3 days ago are not yet available on Bullseye. Even on sid, this packages are available since today only. I checked WireGuard website on weekend and packages where marked outdated but changed today. So I expect Bullseye repro will be updated in next days.
wireguard-dkms/testing 0.0.20200215-2 all [aktualisierbar von: 0.0.20200215-1]
wireguard-tools/testing 1.0.20200206-2 armhf [aktualisierbar von: 1.0.20200206-1]
wireguard/testing 1.0.20200206-2 all [aktualisierbar von: 1.0.20200206-1]
@Joulinar
many thanks for your response. Then I probably missed the last update, I always looked on the website https://packages.debian.org/bullseye/net/wireguard for the latest updates available.
