I checked the postinst script:
#!/bin/sh
set -e
if [ -e /usr/share/apache2/apache2-maintscript-helper ]; then
. /usr/share/apache2/apache2-maintscript-helper
php_enable() {
local a2query_ret=0
a2query -m "php7.3" > /dev/null 2>&1 || a2query_ret=$?
if [ "$a2query_ret" -eq 0 ] ; then
apache2_msg "info" "$DPKG_MAINTSCRIPT_PACKAGE: not switching MPM - already enabled"
return 1
elif [ "$a2query_ret" -eq 32 ] ; then
apache2_msg "info" "$DPKG_MAINTSCRIPT_PACKAGE: not switching MPM - disabled by maintainer"
return 1
fi
PHP_MODULE=$(a2query -m | sed -n 's/^\(php[\.0-9]*\) (enabled.*)/\1/p')
if [ -n "$PHP_MODULE" -a "$PHP_MODULE" != "php7.3" ]; then
apache2_msg "err" "$DPKG_MAINTSCRIPT_PACKAGE: $PHP_MODULE module already enabled, not enabling PHP 7.3"
return 1
fi
mpm=$(a2query -M)
case "$(a2query -M)" in
prefork|itk) return 0;;
*) if apache2_switch_mpm prefork; then return 0; fi;;
esac
apache2_msg "err" "$DPKG_MAINTSCRIPT_PACKAGE: Could not switch to prefork MPM, not enabling PHP 7.3"
return 1
else
echo "Warning: Could not load Apache 2.4 maintainer script helper."
php_enable() {
return 1;
fi
# we've registered a trigger to handle extension updates.
if [ "$1" = "triggered" ] && [ "$2" = "/etc/php/7.3/apache2/conf.d" ]; then
apache2_reload restart
fi
exit 0
elif [ "$1" != "configure" ]; then
exit 0
fi
CONFDIR=/etc/php/7.3/apache2/conf.d
if [ "$1" = "configure" ]; then
phpini="/etc/php/7.3/apache2/php.ini"
if [ "apache2" = "cli" ]; then
ucf /usr/lib/php/7.3/php.ini-production.apache2 $phpini
else
ucf /usr/lib/php/7.3/php.ini-production $phpini
fi
ucfr libapache2-mod-php7.3 $phpini
if [ -e /usr/lib/php/php-maintscript-helper ]; then
. /usr/lib/php/php-maintscript-helper
mods=$(phpquery -M -v 7.3)
for mod in $mods; do
php_invoke enmod 7.3 apache2 $mod
done
fi
if [ -n "$2" ] && dpkg --compare-versions "$2" lt "7.0.3-2~"; then
rm -f /etc/php/7.3/apache2/conf.d/20-opcache.ini;
fi
fi
# Automatically added by dh_apache2/UNDECLARED
if php_enable; then
if [ -e /usr/share/apache2/apache2-maintscript-helper ] ; then
for conf in php7.3 ; do
apache2_invoke enmod $conf || exit 1
done
fi
fi
# End automatically added section
exit 0
Lets debug from start. Could you paste:
dpkg -l | grep -E '(php|apache)'
ls -l /etc/apache2/mods-available/php*
