hard drive space not matching - samba - mac Topic is solved
snoodler
Re: hard drive space not matching - samba - mac
Post by snoodler »
That worked . :D
Thanks a lot !
ok, that way you could add all your 4 directories to SAMBA. Just create a separate entry/section for all 4
/mnt/storage/Media
/mnt/storage/Cloud
/mnt/storage/Home
/mnt/storage/Time_Capsule
