@MichaIng
Forum has a way better response atm
First Install Problem using Raspberry Pi image
Re: First Install Problem using Raspberry Pi image
Indeed I recognised as well. Since AFAIK MVS (our VPS provider) cannot do much about the bad IPv6 connection, I'll leave it like this for now. Sad truth for German (also the VPS is located in Germany) internet, but out of our control...
Will check back once MVS releases a new VPS product which allows dedicated drive spaces increase. Currently only the whole VPS can be upgraded (including RAM and CPU) while we only need more SSD space or an additional (virtual) HDD. Once this additional flexibility is available, I'll likely migrate and we'll see if the new underlying system behaves better about IPv6.
