Add a program to autostart
Re: Add a program to autostart
To which directory you installed bazarr?
klingsor
Post by klingsor »
johnvick wrote: Fri Jan 10, 2020 7:29 pm What does # systemctl status bazarr.service say?
This is my systemctl status bazarr.service
bazarr.service - bazarr Daemon
  Loaded: error (Reason: Invalid argument)
  Active: inactive (dead)
I don't know what is the Invalid argument.
In your systemd script put the full path to python3.8.
I think that this is the full path /usr/local/bin/python, I follow this instructions for the instalation of python 3.8:
https://installvirtual.com/how-to-insta ... -raspbian/
Joulinar wrote: Fri Jan 10, 2020 8:03 pm To which directory you installed bazarr?
The path is /opt/bazarr/bazarr.py.
Thanks for all.
somehow your config file for the service looks different than the file described on the Bazarr install guide. You are missing some lines unter [Service]
[Unit]
Description=Bazarr Daemon
After=syslog.target network.target
# After=syslog.target network.target sonarr.service radarr.service
[Service]
WorkingDirectory=/opt/bazarr/
User=your_user(username of your choice)
Group=your_group(group of your choice)
UMask=0002
Restart=on-failure
RestartSec=5
Type=simple
ExecStart=/usr/bin/python /opt/bazarr/bazarr.py
KillSignal=SIGINT
TimeoutStopSec=20
SyslogIdentifier=bazarr
ExecStartPre=/bin/sleep 30
[Install]
WantedBy=multi-user.target
To check which python you are running, you can type the following to command line
which python
