[Resolved] XU4 fails to power on
Fourdee
Re: XU4 fails to power on
Post by Fourdee »
luzifia wrote:Fourdee, is there a way now to upgrade my running System V130 to V134 without new Installation?
Luzi
Possibly, but i'll need to manually go through everything you have installed with you. DietPi installed software should be fine to copy over, but manual installs outside of DietPi-Software (eg: followed a guide and did some apt-get) wont be possible.
Can you run the following on the system and paste results:
dietpi-software list | grep '[[:space:]]=2'
df -h
blkid
ls -lha /mnt
luzifia
Post by luzifia »
Hi
only unrar i have installed without dietpi
root@DietPi:~# dietpi-software list | grep '[[:space:]]=2'
ID 0 | =2 | OpenSSH Client:  |
ID 3 | =2 | MC: midnight commander, powerful file manager |
ID 7 | =2 | FFmpeg: audio & visual libary |
ID 8 | =2 | Java: oracle java 8 jdk/jre libary |
ID 9 | =2 | Node.js: javascript runtime |
ID 16 | =2 | Build-Essentials: common packages for compile |
ID 17 | =2 | Git Client: git clone etc |
ID 42 | =2 | Plex Media Server: web interface media streaming server | | http://dietpi.com/phpbb/viewtopic.php?f=8&t=5&p=1949#p1949
ID 44 | =2 | Transmission: bittorrent server with web interface (c) | | http://dietpi.com/phpbb/viewtopic.php?f=8&t=5#p46
ID 62 | =2 | DietPi-Cloudshell: system stats displayed on lcd/panel | | http://dietpi.com/phpbb/viewtopic.php?f=8&t=5&start=20#p204
ID 96 | =2 | Samba: feature-rich file server | | http://dietpi.com/phpbb/viewtopic.php?f=8&t=5&start=10#p56
ID 103 | =2 | DietPi-Ramlog: minimal, optimized logging | | http://dietpi.com/phpbb/viewtopic.php?f=8&t=5&start=20#p68
ID 105 | =2 | OpenSSH Server:  | | http://dietpi.com/phpbb/viewtopic.php?f=8&t=5&start=10#p63
root@DietPi:~# df -h
/dev/mmcblk0p2   57G  4.2G   53G   8% /
udev             10M     0   10M   0% /dev
tmpfs           399M   24M  375M   6% /run
tmpfs           996M  4.0K  996M   1% /dev/shm
tmpfs           5.0M     0  5.0M   0% /run/lock
tmpfs           996M     0  996M   0% /sys/fs/cgroup
tmpfs            10M  1.3M  8.8M  13% /DietPi
tmpfs           996M   36K  996M   1% /tmp
tmpfs            20M   28K   20M   1% /var/log
/dev/mmcblk0p1   71M   25M   47M  35% /boot
/dev/sdc1       5.5T  4.4T  834G  85% /mnt/usb_3
/dev/sdd1       5.5T  3.9T  1.3T  76% /mnt/usb_2
/dev/sdb1       5.5T  4.3T  892G  84% /mnt/usb_1
/dev/sde1       5.5T  3.0T  2.2T  58% /mnt/usb_4
root@DietPi:~# blkid
/dev/mmcblk0: PTUUID="000f1766" PTTYPE="dos"
/dev/mmcblk0p1: SEC_TYPE="msdos" LABEL="boot" UUID="96C3-9298" TYPE="vfat" PARTUUID="000f1766-01"
/dev/mmcblk0p2: UUID="e139ce78-9841-40fe-8823-96a304a09859" TYPE="ext4" PARTUUID="000f1766-02"
/dev/sdb1: UUID="86b8d807-340f-4873-8937-acd62adc4c2f" TYPE="ext4"
/dev/sdc1: UUID="cf58423f-08d8-425e-a554-cd2d5190c7af" TYPE="ext4" PARTLABEL="My Book" PARTUUID="e989f620-eeaa-443d-9f13-cffc57f5ad80"
/dev/sdd1: UUID="7b004310-3ce4-4ab1-9bd2-7889b4c4aa7b" TYPE="ext4"
/dev/sde1: UUID="3ae3ad10-05ec-4dd0-8608-68facd31268a" TYPE="ext4"
root@DietPi:~# ls -lha /mnt
total 20K
drwxr-xr-x  8 root root    1.0K Sep 22 18:51 .
drwxr-xr-x 21  502    1000 1.0K Jun 22 15:02 ..
lrwxrwxrwx  1 root root      10 Jul 22 15:20 dietpi_userdata -> /mnt/usb_1
drwxr-xr-x  2 root root    1.0K Jun 22 15:01 ftp_client
drwxr-xr-x  2 root root    1.0K Jun 22 15:01 samba
drwsrwsrwx 12  777 nogroup 4.0K Sep 30 21:28 usb_1
drwxrwxrwx  5  110 nogroup 4.0K Jun 26 13:42 usb_2
drwxrwxrwx  5  110 nogroup 4.0K Aug 22 22:15 usb_3
drwxrwxrwx  4  110 nogroup 4.0K Oct 17 17:39 usb_4
Luzi
Fourdee
Post by Fourdee »
luzifia wrote:Hi
Luzi
Ok, should be fine to do a DietPi-Backup and restore. This will essentially "clone" your system state.
But until we do this, we wont know if the power issue will reoccur on the new installation after we restore, if it does, indicates that files may have also been affected by the corrupt image, in which case, new install only.
  • On the system you have currently setup, run the following command:
    dietpi-backup 1 /mnt/usb_1/dietpi-backup_export
  • Power off system.
  • Unplug all drives, except this one:
  • Grab a spare EMMC or SDcard (we dont want to overwrite this one yet) and write the new XU4 image on it.
  • Boot the system and go through the 1st run setup, say YES to external drive, then N (No) to formatting. Do not change any settings or select any software.
  • When the system is completed, run the following command:
    dietpi-backup -1 /mnt/usb_1/dietpi-backup_export
  • Reboot system
  • Power off and test if the Power issue returns. If its non-existent, use DietPi-Drive_Manager to add the remaining drives.
luzifia
Re: [Resolved] XU4 fails to power on
Post by luzifia »
Hi.
This is something for the Weekend ... i'll try it on Fri or Sat,
Ty by now
Luzi
rlamans
Post by rlamans »
OK - tried the new posted download -
Installed to the same, but reformatted, memory card to eliminate that variable.
Used software manager from Dietpi to install a desktop and tightVNC - then ...
"Poweroff" and restarted with little button. Then "Poweroff", pulled power plug, reinserted power plugt = all worked as expected!
Tried "Shutdown now" and restarted with the little button and did it again then pulled and reinserted the power plug = all worked as expected!
Appears the shutdown/power off/unplug power problem is solved ...
Thanks for the effort.
Fourdee
Post by Fourdee »
rlamans wrote:Appears the shutdown/power off/unplug power problem is solved ...
Yep, confirmed by 3-4 users now. So all looks good: https://github.com/Fourdee/DietPi/issues/558
Thanks to everyone who helped report this issue and with testing!
luzifia
Post by luzifia »
hi
so i've done this and it works now.
there were some troubles, but i hope i've done it the best way.
root@DietPi:~# dietpi-backup -1 /mnt/usb_1/dietpi-backup_export
Installing Rsync, please wait....
Reading package lists... Done
Building dependency tree
Suggested packages:
  openssh-client openssh-server
  rsync
Need to get 376 kB of archives.
After this operation, 615 kB of additional disk space will be used.
Get:1 http://ftp.debian.org/debian/ jessie/main rsync armhf 3.1.1-3 [376 kB]
Fetched 376 kB in 0s (679 kB/s)
Selecting previously unselected package rsync.
(Reading database ... 14622 files and directories currently installed.)
Preparing to unpack .../rsync_3.1.1-3_armhf.deb ...
Unpacking rsync (3.1.1-3) ...
Processing triggers for systemd (215-17+deb8u5) ...
Setting up rsync (3.1.1-3) ...
 DietPi-Backup
 Mode: Restore
 Please wait...
break!!! nothing happens - wait 30Min
2nd putty window and check mountstate
there i found out usb_1 is not usb_1 anymore!
so i modified /etc/fstab for mount usb_1 so i have it done before
UUID="86b8d807-340f-4873-8937-acd62adc4c2f" /mnt/usb_1 ext4 defaults,noatime,nofail 0 0
and take out all other mount records.
reboot
and now restore works
 [Ok] DietPi-Process Tool | Completed
 [Ok] Restore Completed.
root@DietPi:/mnt/usb_1# reboot
login as: root
root@192.168.1.106's password:
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Sat Oct 22 08:11:34 2016
 DietPi     | Update available
 V130       | oDroid XU3/4 (armv7l)
 IP Address | 192.168.1.106
 Created by : Daniel Knight
 Web        : DietPi.com
 Twitter    : twitter.com/dietpi_
 Device image possible thanks to: Meveric
 DietPi's web hosting is powered by: MyVirtualServer.com
 DietPi relies on your donations for funding: http://goo.gl/pzISt9
 dietpi-launcher  = All the DietPi programs in one place.
 dietpi-config    = Feature rich configuration tool for your device.
 dietpi-software  = Select optimized software for installation.
 dietpi-update    = Run now to update DietPi (from V130 to V134).
 htop             = Resource monitor.
 cpu              = Shows CPU information and stats.
but ... surprise surprise ... its v130 again :D lol
so i tried
dietpi-update
and check poweroff issue. did not appear again.
tried to recreate my mountstate as i had before. but it's not possible to remount
every drive i have with the same mountpoint with the drive manager.
so i modified again fstab as i had it before.
UUID="7b004310-3ce4-4ab1-9bd2-7889b4c4aa7b" /mnt/usb_2 ext4 defaults,noatime,nofail 0 0
UUID="cf58423f-08d8-425e-a554-cd2d5190c7af" /mnt/usb_3 ext4 defaults,noatime,nofail 0 0
UUID="3ae3ad10-05ec-4dd0-8608-68facd31268a" /mnt/usb_4 ext4 defaults,noatime,nofail 0 0
but now is running without poweroff issue on v134
thanks for assistance @ all.
luzi
Fourdee
Post by Fourdee »
Excellent, thanks for letting us know!
This confirms the image corruption was most likely caused by misaligned partitions and/or broken partition table, rather than corrupt filesystem. The USB3.0 SD reader I was using solely for Odroid image creation, packed in the other day, so most likely that is the culprit.
note to self: Don't buy a Transcend USB 3.0 SD card reader.
