VNC GUI Topic is solved
Re: VNC GUI
this I don't understand. What you do you mean by
restart the virtual desktop after every reboot
After reboot the VNC Server is already restarted 8)
Or do you mean that you would need to start the VNC service manual?
root@DietPi3:~# systemctl status vncserver
● vncserver.service - Manage VNC Server (DietPi)
   Loaded: loaded (/etc/systemd/system/vncserver.service; enabled; vendor preset: enabled)
   Active: active (exited) since Sun 2020-01-19 17:23:35 CET; 7min ago
 Main PID: 612 (code=exited, status=0/SUCCESS)
    Tasks: 0 (limit: 2229)
   Memory: 0B
   CGroup: /system.slice/vncserver.service
Jan 19 17:23:35 DietPi3 systemd[1]: Started Manage VNC Server (DietPi).
Jan 19 17:23:35 DietPi3 systemd[612]: pam_unix(login:session): session opened for user root by (uid=0)
root@DietPi3:~#
Len
Re: VNC GUI
Post by Len »
The realvpn starts but without a virtual desktop:
Re: VNC GUI
pls can you restart your system and past the following output
lsof -iTCP -sTCP:LISTEN
if lsof is not installed, pls do before
G_AGI lsof
Len
Re: VNC GUI
Post by Len »
Re: VNC GUI
can you try to connect to your VNC server as follow
xxx.xxx.xxx.xxx:0
or just
xxx.xxx.xxx.xxx
Do you have autostart enabled for Desktop?
Len
Re: VNC GUI
Post by Len »
works when the pi is connected to a monitor.
When not connected to a monitor the vcn-connection works but only shows: Cannot currently show the desktop.
Desktop autostart is enabeled.
Re: VNC GUI
pls disable Desktop autostart and set it back to 0 : Manual login (default)
Len
Re: VNC GUI
Post by Len »
I did and rebooted, connection works, but:
Should I change something here?:
Re: VNC GUI
what IP do you use to connect? I mean what do you enter in the VNC Client as VNC Server?
Len
Re: VNC GUI
Post by Len »
Working now...
I don't know what changed!? :lol:
I can connect to xx.xx.xx.xx:1
