samba server sharing issue
Re: samba server sharing issue
@gregmo
today I installed SAMABA again and was able to access it without issues.
Which user/pw did you used? Did you used
User: dietpi
PW: you global application password
Or did you used something else?
gregmo
Post by gregmo »
I'm sure this is going to make a lot of people cringe, and even without their security worries, I'm sure it's not the most elegant way to do this, but this is what finally gave me something that is usable.
[global]
	workgroup = WORKGROUP
	server string = %h server
	dns proxy = no
	max log size = 1000
	syslog only = no
	syslog = 0
	map to guest = bad user
	load printers = no
	printcap name = /dev/null
	disable spoolss = yes
	guest account = root
[Shares]
        path = /
        read only = No
        guest ok = Yes
	browsable = yes
	public = yes
	writeable = yes
	force user = root
	force group = root
it's as well working using user dietpi. Still the question what user/pw you used on the initial try? did you tried to access the share from a different device, like a mobile phone using a smb app?
