home assistant 404 error
Re: home assistant 404 error
Exactly, no update on HA frontend.. I call it from Webmin for now.
As said, your script/commands do it correct, whereas I'm not sure if webmin does for such a pyenv instance?
it does ok, I like the option to see the update procedure, what on HA frontend it's not possible (yet)
