Sonarr - can't move/rename files Topic is solved
ainuke
Re: Sonarr - can't move/rename files
Post by ainuke »
You know what, my issue is not exactly the same as the OP. I'll start my own thread.
Official Pi4 4GB
LoveRPi POE HAT, ArgonOne Fan HAT, WD SSD over USB3
SAB, Sonarr, Radarr, Lidarr, Deluge, PIA-VPN
Official Pi4 4GB - attempting Mine OS
"The mistakes you learn from don't have to be your own."
